Question about Muratec MFX-1430 Copier
I am attempting to set up a Muratec MFX-1430 printer for a client and it does not seem to be communicating via the network. I have it plugged directly in to the Belkin wireless router that the desktop PC is plugged in to. The network settings are configured with an appropriate IP address and the gateway and subnet mask both match what is on the computer. However, when I try to ping the printer from the computer (or vice versa) the other device does not respond. I have link lights on the network port on the printer (1 green one is steady, the other one blinks red every once in a while). I have tried both with DHCP enabled and with a static IP with no luck. When I try to print I get an error message relating to the port. In addition the scanner keeps printing out error messages when I try to scan to an e-mail address. Any thoughts? Sorry for the long post but I wanted to put in as much info as possible.
    Genius:
  • 1,218 Answers
IF YOU HAVE THE INSTALLATION CD THAT WAS SUPPLIED WITH THE MACHINE THERE IS A "MANUAL SECTION" IN IT THAT EXPLAINS HOW TO SET UP THE INSTALLATION.
iF YOU DONT HAVE THE CD YOU CAN DOWNLOAD IT FROM MURATECS WEB SIT AT THIS FOLLOWING LINK http://www.muratec.com/new/support/manuals-for_muratec0o34534021023994938849.asp
Posted on Oct 08, 2010
  • abp20 Oct 08, 2010
    Sorry I sent you to the site for users manuals....you require driver downloads...got to muratecs web site www.muratec.com then go to driver downloads and select the "Officebrige" installation cd.
Can't dend a fax via e-mail
Have you ever been able to do this,...was it ever set-up properly to have this feature working.???
Check the installation instructions are set up properly and things like your e-mail address and POP accounts are set properly.
Jun 10, 2011 | Muratec MFX-1430 Copier
Printing problem
You cannot use the "add-printer" wizard to install the 1430...unless you got the machine with the PCL Print option installed; the unit comes standard with only GDI printing.
For the GDI printer port to be created on your PC you must install the machine using the installation disc provided with the machine.
Jul 27, 2010 | Muratec MFX-1430 Copier
Muratec MFX 1430 Fax / Printer / fax does nto turn on.
UNFORTUNATELY YOU MAY HAVE LOST A PCB. IF THERE IS NO DISPLAY AT ALL YOU WILL PROBABLY NEED A SERVICEMAN. WOULD STRONGLY SUGGEST YOU GET EQUIPEMENT LIKE THIS ON A "SURGE-PROTECTOR". ITS A LOT EASIER TO REPLACE A $25 SURGE PROTECTOR THAT POSSIBLY HUNDREDS FOR A NEW PCB.
Jul 08, 2010 | Muratec Copier
I need a lid hinge the number on the side is 07do4l do you know where i can get this part
The lid hinge on the mfx-1430 which "tends" to be the one that breaks is part #Z906461000 which is the hinge on the L.H.S. as you are looking at the machine from the front. Contact any copier dealer locally who deals with Muratec and they should be able to provide the part.
Feb 10, 2010 | Muratec MFX-1430 Copier
Where can i find document rollers for document feeder?
document rollers is located immediately beside entering the paper or on paper if you use presenting with pallet
Oct 08, 2009 | Muratec MFX-1430 Copier
Reset drum counter on a muratec mfx 1430
Drum counter is reset by installation of a "NEW" drum.
There is a small fuse at the rear of the drum on the top( you will see the 2 brass contacts) When a new drum is installed, the fuse blows and resets the drum counter. Installing a used drum will not reset the counter as the fuse is already blown.
Sep 15, 2009 | Muratec MFX-1430 Copier
My computer does not detect MFX 1430 printer. I think I need the usb driver for the usb cable.
Yes you will need drivers to run a "Local" set-up which is what a usb connection is called. Install drivers BEFORE connecting usb cable. You can download drivers from Muratecs web site www.muratec.com
Jun 30, 2009 | Muratec MFX-1430 Copier
Networking Copier
Was a new set-up on the network done??, its probable you have new ip addresses and the 1430 has to have a static ip address to function... therefore it is likely a new set-up/installation would have to be done.
Oct 04, 2008 | Muratec MFX-1430 Copier
Problem scanning on MFX-1430
I am not sure why all scan to email is deleted, but you cant use scan-to-email or any of those scanning features using a USB anyways. Must be connected to the network
If connected by USB, you can download some twain scan utility (purchase one or download free one online) on your computer and install/set it up to use the Muratec as the scanner. Anytime you want to scan, open and use that utility.
Jun 22, 2008 | Muratec MFX-1430 Copier
586 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
