Question about Akai Televison & Video
Hello i have a akai dvd player 4006 im using it to see avi.and wmv files via disk on key i have 2 problems first one is most of the time the pic stops 4 a few seconds while sound is playing this hapens quite a bit!!!! 2 problem is big files 700mb or more some times play only 3-6sec then stops totaly needles to say it doesnt happen on my pc or other dvd players i have in the house i was wondering is there anything i can do to fix these problems thanks
    Top Expert:
  • Akai Master
  • 12,962 Answers
Nope - your dvd player has outlived its usefulness and needs to be retired.
Posted on Jun 15, 2017
Benimur
  • 6966 Answers
SOURCE: VHS player stops after 5 seconds
Hi, Based on your post/description, sounds like a mechanical problem with the take-up spool. As this would involve mechanical diagnosis and repairs, your best bet may be to seek the services of a qualified professional. Should you want to venture do-it-yourself, you need to remove the top cover and expose the inner mechanism of the VHS tape player. Of course the usual safety precautions when working with electrically powered devices. Once the inside mechanism is exposed, you will notice that there are 2 spools where the tape would be sitting when fully loaded. The right side is the take-up spool responsible for winding the tape when played or fast-forwarded. When fast forwarding during stop-mode it is direct gear driven however during play and fast-play, the take-up spool is driven by a clutch sandwiched between the top portion and the bottom wider portion. You need to disassemble the take-up spool. It may be held in place by hard press, force-fit, lock or retaining clip. Normally there is a spring near the top. Upon disassembly, you will notice the clutch which is a white fabric/cloth/cotton appearance. This has to be replaced. Probably available in eBay. In my location, such spare part is not readily available and we have to make do with work-around (not necessarily technically right but as long as it works and for your info only). Things we try:, Stretch the spring, the idea is to put more pressure on the clutch when assembled back; roughen the contact portion where the clutch mates with the spool assembly; worst case scenario, forget the clutch, dab a drop of rubber adhesive on both sides of the clutch. In certain models/versions, it is possible that a slipping belt is causing the problem. In some instances, it could be the driving motor. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 18, 2007
SOURCE: Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Posted on Dec 21, 2007
pgh_pa_guy
  • 2992 Answers
SOURCE: Sony CD/DVD Player DVP-NS50P not playing my avi files DVD+RW
You need to convert avi files to dvd format before burning, otherwise the player won't recognize them. Google "avi to dvd" and you'll find a number of free or pay programs that will do the conversion for you.
Posted on Nov 19, 2008
SOURCE: how to make wmv files to get play on this DVD player.
break the cd into two pieces and throw it on the dust bin.
Posted on Jan 16, 2009
praky16
  • 744 Answers
SOURCE: DVD player picture freezes
hi u can purchase a sony DVD lense cleaner which can make ur dvd player lense perfect for running various kind of dvd... pls rate me
Posted on Jan 21, 2009
Is this DVD player DV220 plays MKV files from disks as well as from the DISK ON KEY? Thank you
The following article just aims to provide a step by step guide on how to convert 1080p or 720 p MKV to DVD format as well as burn MKV to DVD for playing MKV on DVD player successfully at How to Play 1080p or 720p MKV on DVD Player?
This guide can easily help to:
Convert 1080p MKV to DVD format to burn 1080p MKV to DVD
Convert 720p MKV to DVD format to burn 720p MKV to DVD
Convert MKV files in other resolution to DVD to burn MKV to DVD for play MKV on DVD player
Convert and burn MKV to DVD for successfully playing MKV files on any kind of DVD player
Convert and burn other video files including AVI, WMV, MP4, MPG, FLV, AVCHD, MOV, 3GP, WTV, MXF, and etc to DVD
Jan 15, 2011 | Pioneer DV-220V-K DVD Player
How do you copy Youtube videos to DVDs using 123 Copy DVD Gold?
You usually download youtube vids as FLV files, there are plenty of free file conversion programs to change flv to avi or whatever format you want, you can then burn them onto a disc.
I have never used your software, so i am not sure if it handles flv files.If your dvd player will play avi/divx files, you could convert then to avi and burn them as a data disc using ant burning software, i use free software for this. CD burner XP and imgburn.
It sats this about your software..
  • Copy ANY DVD.
  • Burn YouTube videos to DVD.
  • Copy episodic shows like The Sopranos or *** and the City.
  • Autofit technology gives you the best possible quality.
  • Convert ANY DVD to DivX, AVI, Windows Media (WMV), and MPEG.
  • Burn videos downloaded from the internet to DVD.
  • Blu-Rays Upgradeable (Copy Blu-Ray Movies).
  • Copy DVD to Hard Disk.
So your software should be able to burn your dvd, there should be a HELP menu on the software.
Sep 10, 2010 | Navarre 123 Copy Dvd Gold for PC
NEED TO USE THE PHILIPS MEDIA CONVERTER APPLICATION PROVIDED TO CONVERT FILES TO FORMAT THAT THE PLAYER CAN READ
All support for the SA6045/02 is on this page:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA6045/02&slg=en&scy=GB
Scroll down to Software and drivers to see the Media Converter software.
Click the zip file and best would be to save the file to a location on your computer.
After the download finished, unzip the file with WinZip or Winrar.
Open the folders of the extracted files:
under folder
MC_2.0.2.80_SA33xx_SA61xx_Intl_GM_CD02004_0928 start Setup.exe to install Media Converter Software, ArcSoft.
MediaConverter for Philips converts following formats to player, into WMV :
AVI (Microsoft video I format), MPEG-1, 2, 4, DVD (*.vob), MOV, WMV, RM etc.
Needs Quicktime (for MOV) and Windows Media Player 11 (for WMV)
installations.
SA6045/02 manual:
http://download.p4c.philips.com/files/s/sa6045_02/sa6045_02_dfu_eng.pdf
Jul 24, 2010 | Philips GOGEAR SA6045 MP3 Player
Created a DVD from my FS100, unable to get sound when playing it on my home DVD player however have sound on Laptop using WinDVD. Do I need to change format of DVD and if so to what file type ? thanks much
It's the format of the movie clip (.mod). The files need to be converted to .mpg in order to get your sound working with WMC or other video player. Google for a .mod file converter and you'll find several out there.
Oct 07, 2009 | Canon FS100 Flash Media Camcorder
DVD Jumper digital copy is wmv -loaded on mosaic,
your player seems not to support the .wmv video format,
to watch it on pc try another video.player like KLMcodec, update the windows media-player codecs or useother freeware videoplayer software.
some programs give you the chance to change
the video formst of a film,
change the format of file from .wmv to .avi and reupload onto player
Jun 13, 2009 | Creative Labs Zen Touch MP3 Player
I want to convert an avi extension video file to wmv
"will converting an avi extension file to wmv make it work on a dvd player??"
No, a DVD player uses .VOB files
"I have a Philips GoGear SA 3020 and it only supports wmv files. Can I somehow convert an avi extension to wmv?"
Your device is only 2GB so it won't hold a lot of video content but wmv files are generally smaller then .avi.
Go to http://www.videohelp.com/guides?searchtext=&tools=&madeby=&formatconversionselect=AVI+to+WMV&howtoselect=%3B&orderby=Date&listall=1&hits=25&archive=0&search=Search+or+List+Guides
That will give you a place to start. Have fun :)
Feb 13, 2009 | Samsung DVD-R135
Watching wmv files on DVd
MPEG-2 video is the file format you’ll need to convert to, but you cannot simply burn the MPEG-2 to a DVD and automatically play it in a DVD player.
The easily way is to buy software that will make the transition smooth; I recommend VSO Convert to DVD.
Nov 15, 2007 | Televison & Video
Televison & Video Logo
106 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
