Question about Dell Latitude D600 Notebook
When I want to type @ I have type Alt and q same time . The keyboard look like messed up When I type question mark it come out like _lower dash ,what can i do
  • 3,940 Answers
+keyboard with Acer AspireE500-A970. How do I access the Euro symbol (lower case with Number 4) on the keyboard? Arthur
To type the Euro sign in Windows, you press the alt key+0128. As for the Sterling pound symbol, you can type it by pressing the alt key+0163. You can have a look at this site where it lists ways to type different currency symbols:
http://www.fonts.com/fontent/fontent_home.asp?nCo=AFMT&con=fyti_currency
Please note that you have to type the 4-digit code on the numeric keypad (do not use the normal number keys) while holding down the Alt key.
Hope this helps.
Jul 05, 2011 | Acer NSK8458AN Keyboard
How to use accents when writing in Spanish in a Dell Precision m4500 laptop?
On Windows XP
  1. Log On
  2. Click the Start button
  3. Click on Control Panel
  4. Click Regional and Language Options - a new window will pop up
  5. Click the Languages tab
  6. Click on the Details button
  7. Click the Add button - a new window will pop up
  8. Select United States-International (keyboard layout menu)
  9. Click OK
  10. Click Apply
  11. Read the instructions for "Using the U.S. - International Keyboard" below.
Note: You will now have a keyboard icon on the taskbar (usually on the right side). To switch between keyboard layouts click the keyboard icon on the task bar and choose which layout you want to use. Changing the keyboard layout will only affect the log on profile used. No other users will be affected.
Windows Vista
  1. Start-->Control Panel-->Clock, Language, Region-->Change Keyboards
  2. New Window: Click the Change Keyboards button
  3. New Window: Click the Add button
  4. Select United States-International keyboard
  5. Click OK
  6. From drop down menu (Default Input Language) select United States International
Using the U.S. - International Keyboard If you followed the above directions carefully, your keyboard will now react slightly differently than it did before. First of all, notice that if you strike the single apostrophe (') key, nothing happens. To type the single apostrophe now, you must strike the single apostrophe key and then strike the space bar. When you strike the spacebar, the apostrophe will appear.
The next thing to note is that the quotes (") key behaves the same way as the apostrophe key. You must first strike the quotes key and then strike the space bar in order to create the (") symbol. These two minor inconveniences are more than made up for by the ease with which you can now type the special characters.
To type the special characters, two keystrokes are required. To type the ?, you need only strike the apostrophe key and then the letter a. The other characters are just as easy:
  • ? = ' + a
  • ? = ' + e
  • ? = ' + i
  • ? = ' + o
  • ? = ' + u
  • ? = ~ + n
  • ? = " + u
To type the special punctuation characters, you need to hold down on the Alt key while you strike the appropriate punctuation mark. On some keyboards, only one of the two Alt keys will work for this.
  • ¡ = Alt (hold down) + !
  • ¿ = Alt (hold down) + ?
Using Cryptic Codes If, for some reason, you don't want to change your keyboard, you can always type in the troublesome cryptic codes. Using this arcane system, the following codes apply:
  • ? = Alt + 0225
  • ? = Alt + 0233
  • ? = Alt + 0237
  • ? = Alt + 0243
  • ? = Alt + 0250
  • ? = Alt + 0241
  • ? = Alt + 0252
  • ¡ = Alt + 0161
  • ¿ Alt + 0191
When using this utterly out-dated system, there are two important things to remember. First, when you type in the numbers, some keyboards require that you use the "numeric keypad" located to the side, rather than the numbers along the top. Second, on some keyboards, only one of the two Alt keys will work for this.
May 02, 2011 | Computers & Internet
CANT FIND OUT HOW TO TYPE IN UNDERSCORE DASH ON MYFRENCH KEYBOARD
With Num Lock on, press the "Alt" key plus "9" and "5" (in short, Alt+95) on the keyboard's numeric keypad. This will produce your much desired underscore dash.
Apr 28, 2011 | Computers & Internet
Compaq presario 700 the keyboard seems all messed up. For example when I press G it types O, when I press S it types a period etc. What would cause this?
Hold the ALT Key and hit the number lock key, It should go back to a normal keyboard.sometimes you need the Fn + NumLk key depends on laptop
Jul 13, 2010 | Compaq Presario 700 470024-192 Notebook
My cap lock will not let me type in lower case letters and every letter that I must hit twice will stop after my first letter befor I can go on the same with foward and back spacing
You might have enabled the Windows "Accessibility" features, i.e., instead of pressing CTRL-ALT-DELETE at the *SAME* time, you can press CTRL, release it, press ALT, release IT, press DELETE, release it, to emulate the three-finger salute.
Reboot your computer, to start without the "Accessibility" feature active.
Also, try a different keyboard.
And try the keyboard in a different computer.
Jun 12, 2010 | Gateway 2520915 Keyboard
Can not get the question mark to work
turn off your PC and check all the connection are OK
then restart the PC
start >> Run > Notepad
there you check all keys of your keyboard
In case any of the keys are not working you will come to know.
Secondly
meanwhile you can use the Alt code for typing
Alt 63 ?
Alt 123 {
Alt 125 }
Like that
all the best
like that
Jan 07, 2009 | Logitech 967437-0403 Keyboard
Logitech s510 keyboard
I had this problem for a very long time as well. Turns out this is an encryption issue. It's off-balance. You need to reset the encryption, and here's how:
On the LEFT side of your wireless keyboard press and hold Ctrl+Alt, and press F12, then release all three buttons. Now push the Connect button on your Wireless Receiver, then the connect button on your wireless keyboard. Now press Esc. Try it. See if it works. It did for me.
Nov 09, 2007 | Logitech Wireless Access Duo Optical...
Messed up keys
try hitting the left alt and the left shift button together, then try it out by pressing shift question mark. I had the exact same problem and i think you can alternate between french and english keys by hitting these two buttons together.
Jan 18, 2007 | BenQ X805 Wireless Desktop Companion Pro...
Dell Latitude D600 Notebook Logo
Alun Cox
