Question about HP Computers & Internet
Hi I have a HP dv4305us that overheated, cleaned out dust removed battery did a hard start ran HDD test in bios. Quick test passed, but the comprehensive test result was #2- 07 failed. Please explain failure code? Thank You, Mike
  • msjs422 Oct 04, 2010
    Thanks for your help. If I ever need help again you guys will be the first to know. Thanks again, Mike
  • 10,515 Answers
Unfortunately, this means that the hard drive has failed and needs replacement. You could take your laptop to Bestbuy if you would like to try to possibly retrieve the data from it.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 04, 2010
My HP Pavilion Entertainment PC won't boot up but displays error code 1720 - S.M.A.R.T. Hard Drive detects imminent failure.
Replace the hdd, install your OS and copy off your date. Reinstall your programmes to recover your backups.
Nov 07, 2016 | HP Computers & Internet
It said problem on hard disk, install hard disk.. how to install where to get it my netbook has no dvd/cd compress HP mini
Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer. If the computer has two hard drives, you should select the multi-bay test option and test each drive separately.
  1. Plug the AC Adapter into the computer.
  2. Turn off the computer and wait 5 seconds.
  3. Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
  4. Use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
  5. Select Primary Hard Drive Self Test , and then press the Enter key to start the test. NOTE: The exact wording of the option for your particular BIOS may be slightly different.
The Hard Drive Self Test performs a Quick Test followed by a Comprehensive Test . During each test, the window displays a status bar and an estimated time to completion. See HP Notebook PCs - Testing a Hard Disk using the Built in Self Test for additional information.
  • If any test fails , contact HP service and support for instructions on how to order a replacement hard drive.
  • If all of the tests pass, the hard drive is not damaged. As a rule, HP will not replace a hard drive under warranty that does not fail the HP Hard Drive Self Test.
  • If there is no physical problem with the hard drive or memory, then try reinstalling your Windows operating system to troubleshoot the problem.
Instruction on how to Install a new HDD
Please follow the link
Thanks
Proton
Sep 03, 2010 | Computers & Internet
Hard drive crashed
NOTE:
If it fails then you need to replace the HDD. If you can provide me the product no. then I would be able to find the exact part no.of the HDD.
Dreamkam
May 28, 2010 | HP Pavilion dv1000 Notebook
Problem with hp compaq nc8430 no see my hard drive Went I reinstall windown xp my hard drive it not present
Go into the BIOS setup (press f10 during boot process), then SYSTEM CONFIGURATION and disable SATA NATIVE SUPPORT. Try installing XP again and it should see your hard drive.
(If it will work then please vote for me).
Thanks
May 17, 2010 | HP Compaq nc8430 Notebook
Compaq 615 froze with no display and fan whirring.
1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
2. Shut down the computer if it is running.
3. Press the power button to turn on the computer.
4. Press f10 when the HP/Compaq logo displays.
5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
6. Select HDD Self-Test options .
7. Press enter to display a list of HDD/Self-Test options.
8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If test reports pass then perform installation of OS
else hard drive has gone bad
Apr 16, 2010 | Compaq Computers & Internet
Computer will only start in safe mode hp cue root and hp help and restore are not working? what is the best resolution? hard drive failure?
I have included some directions from HP about using an embedded Hard drive test. This is done using the BIOS. Try this to rule out a hard drive problem. This is supposed to also repair some hard drive issues. Then, we can go from there.
Brian
Perform a hard drive self test Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer. To use the HP Hard Drive Self Test, follow the steps below. NOTE: If the notebook computer is configured with two hard drives, then it may be necessary to test each drive separately.
If any test fails , contact HP for instructions on how to order a replacement hard drive. If all of the tests pass, the hard drive is not damaged. As a rule, HP does not replace a hard drive that is under warranty if it does not fail the HP Hard Drive Self Test.
Mar 01, 2010 | HP Pavilion dv9000z Notebook
I have HP nc6220 Laptop, I have this error whenever Im booting the laptp Drive lock multibay password
Hi there.
This is a common problem with HP laptops.
The best way to deal with it is remove the hard drive, CD/DVD rom and the battery for around an hour.
While the HDD and the CD/DVD are out clean the contacts and the lens of the CD/DVD also clean the compartments and the air vents of dust. when the hour is up reassemble the HDD and CD/DVD and it should let you log into windows, when you are in windows go to HP support website and download a bios update for your model and install it, reboot the laptop and the problem should not come back.
HP say that the most likely cause is dust but a bios update is recommended.
Good luck and thanks for using FixYa!!
Apr 06, 2009 | HP Compaq nx6110 PC Laptop
HDD SMART Problame
SMART [Self Monitoring, Analasys, and Reporting Technology] is on the actual hard drive and its telling your bios its on its way out
Basically, even if comp tests pass, if theres anything important on it or its an important pc change the hard drive asap...
let me know... Matt
Jan 25, 2009 | HP Pavilion dv1000 Notebook
HP Cpmpaq Presario V6000
XP wont be able to detect your hdd as you are using a SATA drive. You have two options here
1. Disable SATA function in the bios (easier to do) and use again your XP cd to install the software, it should be able to detect the hdd this time around
2. You have to slip stream the SATA driver to your XP CD and recreate another CD from it. (harder to do). Google "SATA driver slipstream XP" you will be directed to the proper sites
Apr 05, 2008 | HP Compaq Presario V6000T Notebook
Computers & Internet Logo
145 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
