Question about Garden
Wiring diagram for belle mixer switch - Garden
2 Suggested Answers
SOURCE: I need wiring diagram for
Small BLUE at top right hand corner, then the two rows of two...
top left is BLACK, top right is GREY, bottom left is BLUE from the power supply and bottom right is a short BROWN wire with a spur, which leaves a BLUE to connect to the spur. should be it :)
Posted on Oct 21, 2010
I need a wire diagram for a model 120 Gem mixer-#1010203964? year 2010
Hi Patricia,
Go to this link for the machine manual pdf. On page nine, WIRING DIAGRAM - GEM120A-10.
http://www.fiestafoodservices.com/img/thermalservers/pdf/gem120a.pdf
Fare. Well. My Lady.
Jul 06, 2014 | General GEM 120 Mixer
The wires have come out of the switch
take it to an electronic repair shop in town karen don't fix yourself!
Mar 22, 2014 | Bell Labs Protecta Load-N-Lock Anchoring...
Hi, My cement mixer 240v supply lead has been pulled out of the connection box. Can anyone supply me with a wiring diagram. the only detail on the box is that it was made by POWERFLO drum capacity...
Do you still have the wire with plug end?
The mixer has a switch.
Is the mixer reverse-able?
Or is the mixer 2-speed?
What do you mean about 'one plug' and 'second plug?'
Buy cheap multimeter at hardware. Install battery. Set to read ohms.
Green wire is always ground.
Test each wire to each other.
For example if you test green wire to metal side of mixer, the meter will show full open circuit.
Test each other wire to each other wire. When voltage travels through the motor, then there will be ohm reading.
Move the switch to each position, and see which wires test differently.
Try to identify wires going to switch.
240Volts will have two hot wires.
One or both the Hot wires should connect directly to switch, depending if switch turns one hot wire on-off, or turns both hot wires on-off.
In a two speed system, or reversing system, the switch will send power to different coils on motor.
Sep 27, 2012 | Dryers
I need wiring diagram for Belle 150 cement mixer 110v
Oct 09, 2010 | Garden
Hobart A 200 Mixer
There are four possibilities to look at here. Assuming your mixer has a normal capacitor start motor (older a200's used a different style motor), possibilities are, in order of likelihood:
Motor start capacitor
Start switch (electronic or mechanical)
Burned wiring
Motor start winding
The start capacitor is located at the rear of the mixer. Remove the rear cover (4 screws) and pull the cover towards you. Disconnect one wire from the capacitor and test with any multimeter.
The start switch, if electronic, is able to be tested, but not very easily. Once you've eliminated the other possibilities, it's time to replace the (electronic) start switch. If the motor has a mechanical start switch, it's easy to test: Remove the two wires at the rear of the motor and test for continuity with the motor stationary. A multimeter should show near zero ohms for a good mechanical start switch.
Burned wiring should be easy to spot with some careful inspection around the motor, capacitor, and start switch.
Start winding: Look closely at the stator (stationary part of the motor). If some of the copper windings look significantly darker in color than the others, it's likely the start windings were overheated (the start windings are the thinner copper wires - if you look closely, approximately half of the wires are thinner than the other half). Look for a wiring diagram behind the power switch and determine which wires leading to the start switch and/or capacitor are for the start windings and test for continuity across the start winding. You should read a fairly small value such as 5 - 15 ohms. Values significantly outside this range could indicate a partially open or partially shorted start winding.
Jun 09, 2010 | Hobart A200 Stand Mixer
A - 200 3 speed mixer needs a wiring diaram
how do you know diagram is wrong , you could have wired it wrong the timer kit i belive comes with 3 or 4 different diagrams for that mixer you need to pick the right one
Aug 27, 2009 | Hobart A200 Stand Mixer
A200 electronic start switch
Hi harry,the wires should be marked 1-2-3-4,if not i'll give you the diagram.Let me know.
Feb 09, 2009 | Hobart A200 Stand Mixer
I have a belling cooker switch that has had 3 contacts welded together, i have ordered a new switch but where can i find a wiring diagram to check the conecction for the new switch
have a belling 862 and the grill switch will not regulate can anyone tell me the type of simmerstat that is required?
Jan 15, 2009 | Kitchen Ranges
NEED A WIRING DIAGRAM FOR A A200 HOBART MIXER
I had a look on google and came up with a service manual. not sure if this has the wiring diagram but the only other thing i can suggest is to contact te manufacturer direct. Go to http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
hope this helps.
Feb 02, 2008 | Hobart A200 Stand Mixer
Garden Logo
2,382 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
