Question about HP Compaq ProLiant ML350 G3 Server
I have server 350ml g3 i have no flopy disk how instal scsi driver
darshanks
  • 40 Answers
SOURCE: I am trying to install Vista Ultimate on a HP
its looking for the drivers in the motherboard CD that was given to u at the time of purchase
Posted on Jul 03, 2009
  • 13 Answers
SOURCE: While i was formatting a TC2120 server, i used low
This error message usually relates to the wrong third party scsi drivers being use.
Check what SCSI card you have installed and make sure you have the correct drivers and that you select the correct driver from the list at the appropriate time.
It is also possible that the SCSI card itself has a problem, but it is far more likely to be the wrong driver.
Posted on Aug 11, 2009
  • 17 Answers
SOURCE: configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Posted on Mar 12, 2010
  • 33 Answers
SOURCE: ProLiant ML110 Server: i NEED WINDOWS XP dRIVERS FOR HP PROLIANT G3...
Why the Machine is not ment to use as Desktop try using windows 2003 server driver from cd supplied with it that will work for xp
Posted on May 07, 2010
Mikenet2620
  • 106 Answers
SOURCE: I want to install windows
1. turn the server on, when you see the smart array controller posting
hit f8 to enter the controller settings, here create the array (1, 5,0)
2. insert the windows cd and follow the normal installation procedure
or download the smart start cd from here for a guided installation
with SSCD just insert the cd and follow the directions
Posted on Sep 02, 2010
How to installed xp2 in server hp proliant ml 350 my hard drive ok
You may need raid controller driver for HP proliant ml 350. Copy raid controller driver in flopy disc, insert it in flopy drive, insert cd in cd driver, boot server from cd and start installation process, as soon as you see Press F6 if you need to install third party scsi drivers or raid controller, press F6 and follow the instruction. It will then ask you to select RAID driver file and then will continue to windows xp installation.
Regards,
Kaushik Patel
Aug 24, 2013 | Computers & Internet
Proliant does not boot from raid controller if external SCSI drive is powered on.
Try to disable boot to other device on your bios setting.
Make sure that your Smart Raid is set on the first boot device.
Nov 01, 2011 | HP Compaq ProLiant ML350 G3 Server
How to install scsi driver for hp prolaint ml 350 server and then install server 2003,because my os 2003 is currpted.
windows server 2003 enterprise edition with SP1 or SP2 , can detect
SCSI driver automatically.
Apr 22, 2011 | HP Compaq ProLiant ML350 G3 Server
I want to install a new scsi but when my os windows small business server 2003 it gives me "setup either detected multiple disk in your machine that are indistinguishable or detected raw disk(s). Setup has...
using the ACU (array configuration utility) create a raid 0 with this drive after the hard drive is being formatted and is configured as raid 0 (no redundant) restart the server and the hard drive should be detected as a new logical volume with a assigned letter "D" "E"
ACU
Jul 30, 2010 | HP ProLiant ML370 G3 Server
Configure & install two scsi disks scsi disks in ML 150 G2
Feb 24, 2010 | HP ProLiant ML150 G2 Server
While i was formatting a TC2120 server, i used low level formatting with Ctrl+A option after that the server is not detecting the SCSI hard disk although i've tried to install the third party driver with...
Jun 29, 2009 | HP Server Tc2120 (335874-001)
Can not install windows server 2003 on Acer Altos G710
Hi! Turn off computer check cable & power cable connection. Windows 2003 Operating System will not support SCSI Drives.
Apr 08, 2009 | Acer Altos G710 Server
SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Apr 07, 2009 | IBM eServer xSeries 346
I canĀ“t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant ML350 G3 Server Logo
26 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
