Question about Philips 32PT5441/37 32" TV
Philips tv i have horizonal lines across the top going 3inches down my sreen of my 33 inch tv.  when i tud it on a red ,gren lines apear under the line., and fade after it is on. but the other lines stay. how do i fix this?
  • Nick_in_Wi Mar 26, 2009
    Techman,
    I'm a EE, know my way around boards and soldering, but don't have any schematics or prior TV-specific experience (flourescent lights and VFD's, no problem). Where should I look for vertical sweep circuit? I'm assuming that it's a ~25kV cap?
    Also, any suggestions on where to get the part? I know there are lots of sites online, but I've never bought from any of them, so a personal recommendation always goes a long ways towards a shop's legitimacy....
    Thanks in advance,
    Nick
    President:
  • 3,130 Answers
You have bad capacitors in the vertical sweep circuit. If you have no electronic repair experience, you will have to take the set into a repair shop as these parts are soldered into a printed circuit board and need to be tested with an ESR cpacitor meter. Good luck
Posted on May 27, 2008
Changed crt coolant, better picture. red squiggily line starting at top center of screen, runs about a third of the way down. thought i saw scratch or small crack in green crt "c" lens. would this cau
Sounds like you may have just left one of the wires loose from the red tube. Not likely an issue from the gren tube but you can always cover the top of the lens and let just green shine up. That may help narrow it down also.
Here is more detailed info for you also.....
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Jan 17, 2013 | Philips 60P8341 60" Rear Projection...
Lines across my tv where the picture is reversed
You have bad capacitors in the vertical deflection. And you will have to resolder the vertical IC as well. Replace the caps in the area of the vertical IC. Find a TV tech or hobbiest to do this!
Apr 14, 2010 | iLO IWT3206 TV
Red and Green and Yellow lines inthe Picture
Is this an LCD TV or and LCD Projection TV.
This sound like a convergence problem that sometimes can be adjusted in the user menu. Definintely can be adjusted in the Service Menu.
May 18, 2009 | Philips Televison & Video
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
55 inch Philips
I have 50" philips magnavox big screen. I recently started to have a problem with the edges of my tv. They became blurry. the center of the tv is clear and the edges are blurry. what should I do to fix this problem.
Sep 06, 2008 | Philips 9P5034C 50" Rear Projection...
Red line in top corner of screen
Sounds like an IC on the LCD panel went out of TV. Only thing to do is replace panel (it won't go away only get worse) It will probable be cheaper to just get another tv.
Apr 21, 2008 | Philips 42HF7444T 42 in. Plasma TV
Horizonal line
I think you have a fault on the picture frame board. If you can check for this yourself or find a competant technician. Hope this helps.
Apr 02, 2008 | RCA F32650 32" TV
Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Jan 17, 2008 | Apple MacBook Pro Laptop Computer with...
No picture
hi, the problem is in the vertical ossilation.. let me know
Dec 18, 2007 | Sansui DTV2760 27" TV
Philips 32PT5441/37 32" TV Logo
298 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
