Question about Envision EN9410 19" Flat Panel LCD Monitor
Screen flashes on and then off continously, won't stop,
  • 732 Answers
Doug will692, What "duration" of time would you say a "flash" is??? 1 second "ON" and 1 second OFF, or 2 seconds "ON" and 8 seconds "OFF" ?? I think the internal "switch-mode-power-supply / CCFL inverter circuit may be "cycling" in and out of "shutdown mode" because the SMPS has detecte a "fault condition with itself or another circuit. You or electronics technician will need to troubleshoot the unit. Just do some reading and follow the links in the FIXYA PROFILES of "budmrtn" "buddymc" "12fixlouie" and then visit YOUTUBE for video clips. As always, Check the power supply board for bad capacitors and poor soldering. Document any work with digital pic's and or video recording. 12fixlouie
Posted on Oct 01, 2010
What causes a red light on an TB Wood Etrac XFC 1001 inverter and the motor will not start Is there an internal fuse Do I need 3 phase for the input
Is that red light flashing or continous lighting? You do not need 3 phase input for that model. Do you have the input wiring diagram? If the red light is flashing maybe the emergency stop input is active. If the red light is on continously then it maybe in stop mode or torque limit, ask electrician to check the wiring.
Dec 31, 2016 | Inverter Electronics - Others
PN50B550T2FXZA won't power up
The continous red light merely means power is getting to your TV. From your description, it is likely the internal power supply has failed
Dec 31, 2012 | Samsung Televison & Video
Stop screen flashing on nike trax fury
Nike Triax Fury 100 Super
Yes you need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Nov 29, 2011 | Nike Triax Watches
My garmin was automaticly flashing differnt modes continously. Now it won,t turn on at all.
whoa, mine just starting doing that too. Today on a run it just started flashing through the 3 screens and I couldn't turn it off. It kept logging the run so I kept going. Then it would stop flashing sometimes during the run and I'd press the up or down arrow and it'd start flashing again. Now it's in the cradle and I can't sync it up but the battery is charging. Any ideas how to fix this?
Aug 10, 2011 | Garmin Forerunner 305 GPS Receiver
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
Mar 05, 2011 | Epson Stylus C48 InkJet Printer
Trane gas furnace with White Rodgers 50A50-474 board is flashing a 2 flash code which is a system lockout. The furnace blower contines to run, but the heat stops. I can reset the furnace and the system...
If this is a direct vent unit, check the PVC air intake at the furnace for debris. There is a screen at the furnace connection and as cold air enters into the burner chamber it frosts up on it. If there is any blockage, it restricts the air inlet. If the furnace ignites, it melts the frost and works fine. It happens mostly at night. Let me know if you find this. Thanks.
Jan 09, 2010 | Heating & Cooling
Continous "charging flash" when trying to snap a picture
Connect the camera to the charger and take the picture. If the charging flash stops after a couple of seconds, it means that you need a new battery.
Jan 08, 2010 | HP Photosmart R707 Digital Camera
Controller (control panel) is flashing continously
see if flashing fl1 and flashing if so shorted temp sensor
Feb 04, 2018 | Jandy Lite2 LJ125 Ceramic Gas Heater
Message Light flashing continously
Resetting the New Message LED
If the LED remains on after you’ve retrieved your messages, you may need to reset
the indicators. With the phone is in standby mode, press and hold find handset on
the base until the paging sound stops (about 5 seconds).
Dec 12, 2006 | Uniden TRU8865-2 Expandable System...
Envision EN9410 19" Flat Panel LCD Monitor Logo
105 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
