Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Mildew We "inherited" our Maytag Neptune from the previous occupants of our house. It had a small bit of mildew around the rubber seal of the door. Despite my attempts to clean and dry it out, it grows. In the last three days we've been getting residue on our clothes after the wash cycle that looks like mildew pieces, as if there is mildew in the barrel and it becomes loose during the wash cycle and enters the area where our clothes are. How can I get rid of all of this?
  • 868 Answers
Allow the drum to air dry ,thats by leaving the door partially open.You will see a huge difference.And yes ,all the time.
Posted on May 26, 2008
Mold and mildew and a musty odor. I can see black mold around the door seal, primarily at the lower side of the door seal. Can I attempt to clean by using bleach? What are your recommendations to correct...
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((^^&&
Sep 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Neptune washer leaves an odor in my clothes
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!^^^
Jun 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Have a Neptune washed since 2001 -- has an odor, b...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@^^
May 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Superstack water accumulation and odor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!%5
Jan 27, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
I have a Neptune MAH5500BWW front-load washer. The first load of clothes sometimes has a mildew odor. How do I prevent this?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Dec 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mildew smell
PLEASE KKEP IN MIND THAT THE MAYTAG NEPRUNE FRONT LOAD WASHER IS WHAT GOT MAYTAG IN TROUBLE!!!!!!
Whirlpool bought MAYTAG about 3 year ago.
THe mold is because of the rubber boot in the front of the door. PLEASE check to see if the rubber seal has a small hole in the lower bottom of the seal to let small portions of water drain out. If you DO NOT have this small hole, you need to replace the rubber boot with one that has a hole.
NOW, WORD TO THE WISE and this is what I tell ALL FOLKS that have a FRONTLOAD WASHING MACHINE:
AFTER you washer in the washer LEAVE THE DOOR OPEN so that the washer can ventilate and remove any moisture that is within.
ALSO, every 2 months, get a WHITE CLOTH with WARM WATER and a littl;e bit of BLEACH and CLEAN THE RUBBER BOOT!!!!!!
Nov 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
2002 Maytag Neptune front load washer has an odor like a burnt rubber odor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!@@
Nov 17, 2009 | Maytag MAH6500 Neptune Front Loading...
Problems with mildew around the rubber and terrible odor to the laundry after washing. Also, hear water sloshing when turn the drum by hand.
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Oct 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Musty odor removal; also "mold" black in color around rubber seal
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$^*#
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer dispenser unit has mold and mildew inside top of dispenser compartment.
You can pour the bleach in the drawer every time you do white loads and it will stay clear too!
Just flush it out good before you do colored clothes or you may get a small bleach spot on a red shirt !
Neil
Ps. Give me a problem solved rating here on fixya.com
Aug 19, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
187 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
