Question about Agfa DC-730i / AP1100 Digital Camera
AGFAPHOTO DC730i NEWLY PURCHASED. USING A 4GB SD CARD, GET ERROR MESSAGE "CARD ERROR" ON STARTUP (CARD INSERTED SEVERAL TIMES) AND ALSO WHEN I ATTEMPT TO FORMAT GET "FORMAT ERROR". SD CARD WORKS OK IN ANOTHER CAMERA (SAMSUNG S760). I BOUGHT 2 OF THE 730i AND BOTH EXHIBIT THE SAME ERROR SO IT'S NOT(?) AN INDIVIDUAL CAMERA FAULT. COULD IT SIMPLY BE THAT THE 4GB SD CARD IS TOO BIG ? OR COULD PREVIOUS FORMATTING IN THE SAMSUNG RENDER THE CARD 'UNREADABLE' IN THE AGFA ? NEED THESE FOR NEXT WEEK SO ANY CURE/ADVICE WOULD BE GREATLY APPRECIATED !! THANKS
    Brigadier General:
  • 11,967 Answers
If your new card is actually an SDHC card, your camera can't use it....only SD up to 2GB.
Posted on Oct 01, 2010
How do I cure memory card error even though the card isnt locked?
The S50 works with SD cards. Your new 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
May 16, 2012 | Pentax Optio S50 Digital Camera
I have a JXD661 with me. Whenever I insert the SD card that I bought along with it, the player gives me an error message that states ''Access SD card error''.
Hi dude utkarsh...
You did not mention what size SD memory card you are using, according to the website below, you can only use up to a 4 GB SD card.
If your using over a 4 GB card then the player will not work properly.
If you are using a 4 GB card or less, try using another card in the machine, it may be a malfunction in the card you bought.
Please take time to rate me
http://www.audio-mania.co.uk/shop/JXD/4Gb-JXD-661-2.5-PMP-MP4-Player
Jun 25, 2011 | Audio Players & Recorders
I inserted a new 4gb sandisk memory card and get a "card error" message with a "00001" in top right corner of display. any advise? thanks.
The 5022 is specified to work with SD cards. Your 4GB card is actually an SDHC card. While it will fit into the slot, it is electronically incompatible and will not work in the 5022. You need to use SD cards, 2GB and smaller.
Oct 11, 2010 | Vivitar ViviCam 5022 Digital Camera
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
May 15, 2010 | Pentax Optio S50 Digital Camera
I have purchased several sd memory cards and every time i insert one it gives a message "card error"
Having received no response in over a month, I assume this is no longer a problem.
May 12, 2010 | Samsung NV10 Digital Camera
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
New 4gb sd card will not work. card error
Is the slide switch in the unlocked position? Are you formatting it in the camera? Are the card contacts dirty?
Dec 07, 2009 | Casio Exilim EX-Z40 Digital Camera
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cannot get pictures off of SDHC Card 4GB
Could be it only supports SD cards up to 2gb but not SDHC.
Jun 16, 2009 | SanDisk 4GB microSD High Capacity Memory...
Agfa DC-730i / AP1100 Digital Camera Logo
170 people viewed this question
Top Agfa Cameras Experts
CHIVOIU...
CHIVOIU...
Larry Stiles
Larry Stiles
Are you an Agfa Camera Expert? Answer questions, earn points and help others
