Question about Philips 2252 Twin Cordless Phone
Philips Dect 225, single handset
Lost the manual (of course!) and forgotten how to set outgoing answer machine message. Hopeful for your help - many thanks.
Rosie.
  • Anonymous Jul 21, 2008
    lost manual cannot set answer machine
Press the key marked "OGM" for two seconds and wait for the tone. OG will start blinking. When done press stop.
Posted on Aug 02, 2008
How do I set a security code for outgoing calls
how do i call out from the message people have left me
Jan 23, 2013 | Uniden DECT 1580-6 DECT 6.0 Phone...
I have the uniden dect 6.0 3 handset. I lost my manuel and do not know how to record my answer message
Which specific Uniden DECT 6.0 phone do you have? There are a number of them. Uniden has the manuals available here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . Phones are listed in alphabetical and numerical order.
If the answering system is off, turn it on before proceeding to the following steps.
If you are at home, there are usually two methods to access the answering system. Some Uniden phones let you set the outgoing message from the base or the handset. Others will only let you set the message from the handset. (Calling in remotely is more complicated.)
To access the answering system menu from a handset, on some models, push the Mute/Messages button. Then let your current message play or press 5 to stop the recorded announcement. Then either use the up/down arrows to select Record New Greeting (or the number that matches the sub-menu item). It's number 8 on the DECT1480. Then wait for the prompt (tone or "Record Greeting") and then speak into the handset clearly. Press 8 to stop recording and press End to save the message. Press 6 to select the outgoing greeting if a default greeting is available.
On other Uniden DECT phones, press Menu and go to Ans Setup. Then choose the line for the greeting (if it's a multi-line phone) and then select Record Greeting. Press Start, wait for the prompt and then press Stop when done. Press Stop again to save the message. If there is an optional pre-recorded greeting, use the Greeting Option submenu to select the greeting to play. (This applies to the DECT4086.)
From the base, you'll do something similar. However, you should stay about 9" from the microphone while recording. Messages can be between 30 seconds and 3 minutes 30 seconds for most systems.
I hope this helps.
(recording a new greeting during a remote call can be done but consult the manual for details.)
Dec 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
I do not have a manual for directions on recording a personal message
For most of the Uniden DECT phones, you set up the outgoing message from the handset. Make sure the answering system is on. For the DECT1480, press Messages/Mute on the handset when the handset is in standby to enter the answering system menu. Then press 5 (or wait until the current message ends). Then press 8 (record new message). Wait for the prompt and then speak your message. When finished, press 8 again. Then listen to the play-back of your message. Press End to save and exit the menu. Alternatively you can scroll through the list of commands and press Menu/Select to enter the sub menu or command.
There are several models of Uniden DECT 6.0 phones. If you have a different phone, you should check your manual. The entire list of Uniden phone manuals is available here: http://www.uniden.com/scat/cordlessphones_mnl . Scroll down to your product and click on the version in your language.
I hope this helps.
(most of the Uniden phones that I know have the same set of directions for the answering system outgoing message.)
Jul 07, 2011 | Uniden DECT 6.0 Cordless Phone ID
I am trying to record my personal greeting on my message machine with the DECT 6.0...can you please explain to me how I can record my greetings?
Which model phone do you have? For the CL82509 and related DECT 6.0, you need to set the outgoing message from the handset when the answering machine is on. (It can be turned on from the handset).
For the outgoing message: with the handset in Idle mode, press Menu/Select. Use the up (Dir) and down (CID) arrows to highlight Ans Sys Setup. Then press Menu/Select. Use the same arrow keys to select Announcement and press Menu/Select again. Press 7 to record a new announcement. At the tone, speak your message clearly then press 5 when you have ended the message. The message will play back.
This model's manual is available here: http://att.vtp-media.com/ecp/documents/product_Product/132/UserManual/5995/cl82509_manual_USA_i6.pdf . See page 15 to set the answering system outgoing message. (This is different than Voicemail. To set up Voicemail, you will need to see your telephone provider's documentation.)
Most AT&T phone manuals are available here: http://telephones.att.com/att/index.cfm/product-support/manuals/ .
I hope this helps.
Apr 01, 2011 | AT&T DECT 6.0 Cordless Phone System with...
Lost the manual....don't know how to set up outgoing answering message....
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Mar 16, 2011 | Uniden DECT 6.0 Cordless Telephone...
Have lost instructions and do not know how to record an outgoing message on the answering machine portion. Everything works great but need help please? It is a dect6.0
Sep 24, 2010 | Uniden DECT 6.0 Cordless Telephone...
Need help in setting time and answering machine.Dect2188 Can't see where to set time or how to set outgoing message on this new phone.
You may download a copy of the manual here. The day/time instructions are on pages 9-10. The outgoing message instructions are on page 21.
Aug 25, 2010 | Uniden DECT 6.0 Cordless Telephone...
Lost manual, need to change my outgoing msg on aswering machine..
You can download a copy of the manual from the manufacturer's web site at http://uniden.com/index/manuals_results.cfm?cat=59
Oct 11, 2009 | Uniden DECT 6.0 Cordless Telephone...
Answering Machine on the dect 225
The dect 225 is set to toll saver by default (press the ring button (-) and read the display). It answers on 2 rings if you have messages and 4 rings if you don't.
If you hold down that button for 2 seconds, you can use the up/down keys to adjust it for 2-7 rings.
Here's a manual if you don't have one. Check out page 30.
http://www.p4c.philips.com/files/d/dect2252g_37/dect2252g_37_dfu_aen.pdf
Carl
Oct 05, 2008 | Philips DECT 2252S Cordless Phone
Philips dect answer machine cd2352s/05
Answer machine cut off , it may related to parallel phone detection, setting. So try not parallel any other phone with the DECT phone.
Jun 14, 2008 | Philips DECT 2252S Cordless Phone
Philips 2252 Twin Cordless Phone Logo
145 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
