Question about KitchenAid KERC507 Electric Kitchen Range
I have a Kitchenaid Range # KERH507YBLO. The center coil area for the Broiler went out. It does not work under oven or Broil. The Replacement part is a Whirlpool #AP2926636. My question is is this user replaceable ... It looks like a screw holds a cover plate and based on the drawing, it just plugs in - out. Can you confirm this procedure is some I can do without a tech? Thanks, Bob
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Oven/Broiler Igniters for KitchenAid range KGST307
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Posted on Apr 02, 2007
jsrock516
  • 5911 Answers
SOURCE: Oven not working, but broiler is...
Very well could be. I'm assuming the bake burner is the problem, right? Does the igniter glow at all? If it is glowing, but the burner does not light, is it usually a symptom of an igniter that has become weak. If it does not draw enough current the gas valve will not open and the burner will not light. This is a safety feature to prevent free flowing gas without ignition. If the broil burner is functioning properly, then more than likely the gas valve and regulator are working fine. In most ranges both burners are fed from the same source. You could try swapping igniters between the broil and bake burners to prove the theory. Or, you could just replace the igniter all together. Current readings are as follows: Round shaped glow igniter: 2.7 to 3.2 amps Square shaped glow igniter: 3.2 to 3.7 amps If you can give me the exact model number off your range (usually located around the oven door or on the back of the range) I can give you the correct part number you will need. Most appliance repair stores carry the igniter. I hope this helps you.
Posted on Sep 14, 2007
  • 126 Answers
SOURCE: Broiler will work, but oven wont
Could be the bake igniter is bad and broil igniter is still good. may need to replace the bake igniter you will need a complete model number off range to determine the part number of the igniteryou may need.
Posted on Jan 07, 2009
TheMobilian
  • 8220 Answers
SOURCE: kitchenaid oven won't fully heat
Most of the time even though the ignitor is glowing it is weak and you cannot tell it unless you do a amp check.
I have repair photos: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 17, 2010
Kitchenaid oven won't fully heat
Feb 17, 2010 | KitchenAid KGRK806PSS Gas Kitchen Range
Jennaire broiler doesnt work on slidein range after using self clean oven. Its only 14 mo. old
if just your broil element does not work and the bake element does work after using a self clean cycle then your broil element must have went out , self clean is a torture proccess for any self clean oven and it runs both elements at 500 deg. F, it may be still under warranty , if not then replace the broil element for the fix.
Phil
Jun 10, 2009 | Jenn-Air JES9860 Electric Kitchen Range
I have an old (20 years +) Tappanr 4 burner range with a double oven. I am missing the knob for the cleaning cycle but it says it is self cleaning. I need a replacement. I'd also like to find replacement...
chances ar erte hlower oven door , is your broiler, the older models didnt have a seperate broiler inside oven, rather they used 1 burner bar ,and depending on wher oyu place the food you would either bake(above) or broil( under) made sense, just pain in the rear to bend down to use it. as far a knob and gasket , perhaps you can find a model number under the main top assy so we can look up for you
Mar 07, 2009 | Tappan MPF500PBW Gas Kitchen Range
Jan 07, 2009 | KitchenAid KGST307 Gas Kitchen Range
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 09, 2008 | Ovens
Broiler
can you hear the convection fan motor turn on? if not that would be your problem.
Apr 10, 2008 | KitchenAid KGST307 Gas Kitchen Range
8 year old kitchenaid gas range nom fire in the oven
I went to the kitchenaid web site for parts and found a trouble shooting section. I read about how a electronic glow coil works and discovered that mine was just old and did not reach the right voltage to open the gas flow valve.
Feb 20, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven not working
Check continuity on gas valve. the middle connector is common, upper is broil and bottom is bake. Resistance between common and bake should be about the same as between common and broil. I believe you'll need to set the ohmmeter to KOhms (or x1000.
If no continuity between any of the connectors - replace gas valve (not much fun, and part is expensive).
Jan 21, 2008 | KitchenAid KGRC707 Gas Kitchen Range
Apr 02, 2007 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid KERC507 Electric Kitchen Range Logo
94 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
