Question about HP Compaq 6735s Notebook
I have a hp6735s it just switches off without any warning i think it may be over heating had it for 14 months now i think fan needs cleaning but can't get any accsess to it any ideas
I had the same problem with over heating turned out the fan was clogged with dust turn your laptop off and vacuum the keyboard and where the fan is on the side. worked a treat for me hope this helped
Posted on Oct 17, 2010
  • gozone Oct 17, 2010
    thanks for the advice but i ended up taking my laptop to bits cleaned it all out air intake was clogged with dust working great now better than ever
Overheating
When was the Thermostat changed last? Try that.
Fan?? Fuse/Relay? Check you have power at Fan, Relay, Fuse, etc.
Good luck.
Jan 31, 2014 | 2002 Honda VTR 250
It runs at first 10 mins then it suddenly turns off without warn?
hi this sounds like you might have either a overheating fault or the "switch" ( not a real switch more like a little silver tube looking item) on the motherboard may be at fault, you need to check the CPU heat sink and fan are up to the job, also check the graphics card if you have a separate one, it might be overheating, turn it on with the case open and just check the CPU fan see if is turning fast or even better still access the bios and go to the CPU utility and check the fan ratio there it shouldn't be less than 2500 to 3500 rpm depending on the board and CPU ok...hope this helps please vote thanks
Jun 09, 2010 | Gigabyte Computers & Internet
When i power on my ps3 it flashes yellow then turns off
have you tried the fan test i think its more than a fan test i think it resets over heating warnings because some of the broken consols i buy and fix have the same thing and when i do the fan test it boots right up
to do this
turn the power switch to the "off" possition on the back of the ps3 then hold your finger on the eject button and while still holding the eject button flip the switch on the back "on"
sometimes you need to leave the system powered off by the switch for about 1 min before you do this to get it to work.
Sep 18, 2009 | Sony Playstation 3 (PS3) Console
Dell Latitude D610 Shuts off with no warning...
the problem is not the battery; what has happened is the coolant paste that pulls the heat away from the cpu (main) chip to the fan has dried up. you must remove the fan/heat exchanger off the motherboard and, put new paste on the chips that the heat exchanger sits on
radio shack sells the paste
Aug 29, 2009 | Dell Latitude D610 Notebook
Laptop switched off while i was working on it
After the notebook shuts down do not turn it back on for 15 minutes and then test it again. Will the notebook work longer if you let it cool down for a while? Isn’t it hot if you touch the bottom? Can you hear the fan running?
Most likely you experience a laptop overheating problem and it would be fixed by cleaning the cooling module – the heat sink and the fan. The notebook processor produces a lot of heat when the notebook is turned on. The cooling module helps to keep the CPU cool when the laptop is working. The cooling module includes two parts: the heat sink and the cooling fan. The heat sink is attached to the CPU and helps to conduct the heat from the processor to the radiator. The cooling fan blows on the radiator and helps to disperse the heat produced by the CPU. The laptop will overheat if the heat sink radiator is clogged with lint and dust or if the cooling fan stopped spinning.
If your laptop shuts down after some time without any reason and warning, check if the cooling fan spins. Usually it makes some noise and you can hear it. If the fan works fine, then check if the heatsink is clogged. In some cases you can clean the heat sink with compressed air, just blow inside the fan openings on the laptop bottom. If the heatsink is completely clogged, then it is necessary to remove the heatsink for cleaning.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!  uva
Mar 25, 2009 | Gateway 830GM PC Desktop
Heater Fan Quit working without warning no smoke no blown fuse.
Oh no, say it isn't so. I'm in the middle of the same task on my 85 model. I just got my parts from IPD, which I hope is not the source of your parts. I would start with the fuses and check for a blown one. Make sure you check closely as they can have fine cracks that can get missed.
Any chance you have a loose wire? - with all that have to come out for the repair it's possible you lost a groundwire connection.
Write back as I will have questions of my own on how you got yours put back together.
Jan 05, 2009 | 1987 Volvo 240
Once it heats up the warning blaring sound comes on
Had a similar issue. I think if you pull the plug, remove the cover (about 4X6) inches and inspect all wires and connections you will find your culprit. Look for evidence of arcing at a connection. If evidence of arcing is present the terminal must be thouroughly cleaned and maybe a new lug attached to the wire.
ddr_2u@charter.net
Jan 05, 2009 | Presto HeatDish Compact Heater
Compaq presario v6000 laptop powering down with no warning
If not, then the keyboard cable has probably come loose.
Look for some way to remove the keyboard. Sometimes a screw from underneath, sometimes two or three small catches at front of keyboard (small gaps in metal plate in front of space bar). Sometimes top plastic bar above keyboard slides sideways.
Keyboard cable uses goes into a header socket - to refit:
Switch off and remove battery and power first!
1. Prise up each end of the socket with a blunt knife - the outer part of the socket should move up a few mm
2. Push keyboard cable down fully
3. Push down each end of the header socket so it is flush with the lower part of the socket.
4. Test keyboard
Aug 20, 2008 | Compaq Presario Notebook
Constant Rebooting and System Error Messages
I suspect you could have a heat sink fan not working remove side of case and when you turn computer on check fans heat sink and video card are working
With computer OFF
remove heat sink fan and check that the heat sink is not clogged up with fluff and dirt.
I regularly clean both fan and heat sink every 2 months also check the fan in power unit and blow it out
Aug 16, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
HP Compaq 6735s Notebook Logo
203 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
