Question about Craftsman 25cc Gas Line Trimmer
How do you adjust carb needle valve?? Seems to be flooding while trying to start.
  • Craftsman Master
  • 7,482 Answers
DO NOT ADJUST THOSE SCREWS FOR NOW...
Your problem is not the adjustments for the carburetor, your problem is the float needle valve inside of the carburetor has some debris under the needle and the carburator has to be cleaned of this debris because it is allowing the carburetor to flood.
You may have to replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 01, 2010
My 2002 ktm125sx runs awesome revs great until carb bowl fills up then it floods and runs terrible I turn the gas off and it'll scream until it starts running out I've cleaned carb checked float
Hi, Dewayne and the usual suspects are:
1. Dirt or other foreign matter between float valve and its seat.
2. Float valve sticking.
3. Float valve and/or valve seat worn or damaged.
4. Float misadjusted.
5. Float cracked, leaky or damaged.
6. Excessive "PUMPING" of hand throttle grip.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
KTM Flooding won start Why
How to Tune Adjust KTM 2 Stroke Carburetors
KTM Keihin Carb How To Jets Needle Clip Floats PART 1
1999 2003 KTM 125 200 SX MXC EXC Service Manual Moto Data Project
May 15, 2016 | GAS Motorcycles
Honda gc 190 starts then floods and stops. Wont start again till plug is taken out and dried then repeats same thing
Float level or a sticking needle valve, check float level as if it is adjusted incorrectly it can cause the main jet to allow fuel to flood through, the needle valve can do the same.
Jul 28, 2014 | Honda Engine Gc160 Gc190 Gcv135 Gcv160...
The float valve sometimes sticks or stays open and the carb floods and then the engine I've had carb off checked float and valve seems ok but still floods CAN ANYONE HELP v-h-b cheshunt...
The needle valve has a very fine neoprene tip which especially with newer gas (they sneak a lot of alcohol in) deteriorates and leaks.
Replace the needle and seat, check your float and be sure it's not leaked(if metal, give it a shake next to your ear, listen for gas sloshing) or the float saturated (composite float, take it off put it in a jar of gasoline, if it sinks its bad).
If you really want to be sure, check the float height according to specs and adjust as necessary by bending the tang where the float and needle meet. Best of luck to you
Sep 09, 2013 | Motorcycles
Gas floods into carburetor even with a new carburetor
The only thing that stops gas going into the carb is the needle valve and seat in the bowl of the carb.
Doing the same thing with 2 different carbs sounds like trash in the gas tank flowed into the carb and is holding the needle valve off the seat allowing gas to flow all the time.
Clean the tank. Clean the trash out of the needle valve/seat. Add a small engine fuel filter between the tank and carb.
You should be good to go.
Oct 07, 2017 | Troy-Bilt Troy Bilt Bronco CRT Garden...
Walbro Carb flooding 13 hp Kohler
the needle valve in the carb is not seating change the needle valve and seat also check the oil when this happens gas drains into the crankcase if so you will need to change that as well
Jun 28, 2012 | Garden
Toro lawnmower will not start because it floods out
sounds like the needle valve in the carb is not seating take it apart clean it and change the needle and seat inside the carb
Jun 27, 2012 | Toro Power Lawn Mower
My rzt 50 mower carb. flooding when i try to start it
sounds like the needle valve in the carb is not seating change the needle and seat
Apr 27, 2012 | Mustang Garden
My 300 utility seems to flood out everytime I try to start it. I have rebuilt the carb, including replacing the needle valve. After it turns over for 4-5 times, gas starts pouring out of the carb. I do not...
the needle is not seating with the float which is causing the carburetor to flood. either the needle is not attached to the float(some snap into a plastic groove, others have a spring) or the float is bad. Hope this helps Tim
May 29, 2011 | Desa International Garden
Flooding walbro carb from blower.
The problem centers around the carburetor. The question lies in the condition and operation of the carb initially.
It appears you may need to double check your assembly of diaphragms and gaskets. check for loose welch plugs, adjustment needles in the wrong holes, inlet needle set too high.
*note: metering side diaphragm goes on top of the gasket, fuel pump diahragm has the gasket on top of it.
Nov 10, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Carburettor float level setting
Usually if the float is adjustable you will set it so if there is a flat surface on top or side of the float it will be parallel with the bottom surface of the carb body when the needle valve just closes (before depressing the spring in the needle)
Jordan
Oct 03, 2009 | 1982 Honda VF 750 S
Craftsman 25cc Gas Line Trimmer Logo
915 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
