Question about Intermatic Inc. ST01C Digital In-Wall Timer
I set timer back from 9pm to 6pm to turn on. no lights activated the last two nights. Is there an on and off button hidden somewhere? ------Jim thanks
  • Larry Oct 01, 2010
    can you double check the part number I cannot seem to find that number
1) Use manual override to see if ST01C timer is functioning:
Push door that covers buttons -or- open door and push ON/OFF button ... timer should make audible clicking sound >> and lights will turn On and Off.
Look on LED screen ... left side of screen is small light-bulb icon ... when lights are ON, icon is black ... when Off, icon is outline
2) Review troubleshooting steps in Manual
a) You might be in Random MODE ... Press MODE button until AUTO appears (AUTO mode lets programs to run)
b) Battery can be too low to operate timer, even if BATT warning does not show on screen >> Change SR2 battery and re-set Time-Date (Time-Date disappears if battery is dead, but programming remains in timer forever until timer is reset)
c) Timer will skip conflicting programming ... For example ST01C has 40 programs ... if Program1 says ON at 7 and Off at 8 ... and Program2 says opposite .. timer will skip these programs
d) Timer will not work on circuit where load (lights, fan. motor) is farther than 100' from timer
e) Timer might not work with underground wiring
f) Circuit breaker clicked off > reset breaker
g) Timer may be carrying too much load: 960 Watts flourscent; 1440 Watts incandescent
h) Timer has 1 year limited warranty > things wear out
i) Circuit has loose wire >> check your connections > review wiring diagrams
j) Timer connected to three-way switch, and other switch has malfunctioned
k) Last resort: Reset timer and reprogram
Posted on Oct 02, 2010
How do I set the timer for a TorkT920L that controls our parking lot lights. it use to turn on at 6pm and off at 6am every day, not its turning on at 8:45 every night and off at around noon every day.
SCHEDULING: CIRCUIT 1: ON automatically at dusk, OFF at individual preset times each day, including skipping days when desired. Unit can be set to turn ON before dawn for early morning lighting.
CIRCUIT 2: ON at dusk, OFF at dawn automatically, daily
Jun 02, 2018 | Hardware & Accessories
How do I set an unidentified timer for on at 6pm and off at 9pm?
there in lies a problem we have no idea what make it is .
Nov 24, 2015 | Hardware & Accessories
Garrison RCT100 DIGITAL TIMER
Yes.
Timers usually don't last more than a few years, unless you buy the heavier duty box timers that last decades.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 20, 2011 | Hardware & Accessories
Verve Digital Water Timer as sold at B&Q have lost the operating instructions.
Verve water timers might be Melnor:
Open following link for manuals.
http://www.melnor.com/instructions.php
Links to other water timer manufactures and manuals are found on following link:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Jun 14, 2011 | GARDENA Water Timer
One year old Amana ASZ 16 (replaced inside and outside units last year) - works fune until the last two weeks, now home at 5pm, reset the thermostat from 82 degrees to 76 or 77 to cool off house (which...
Sounds like the system is either over charged with freon or under sized. Call the same people back out ask for a supervisor to come out and check out the system any other company will charge you.
Jun 10, 2011 | Amana Heating & Cooling
Cant figure out which outlet is which number on Zilla timer. Turned on the yellow switches and then they turned back on at the time I have set for outlet 7. I thought the yellow ones were 1 and 2 or 1 and...
Open following link for Zilla timers
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Zilla timers are unique for home-type timers.
They are two-channel timers, which means that timer has 2 independent programs.
In the case of Zilla, 1 program controls yellow outlets for daytime hours (6am to 6pm). Once daytime hours are over, the yellow outlets are OFF.
The other program controls blue outlets for nighttime hours (6pm to 6am). Once nighttime hours are over, the blue outlets are OFF.
So if you have a light for example, and light is plugged into yellow outlet, then you can program light to turn on-off during the daytime hours only. You cannot also set a nighttime program for the same light unless you plug light into blue outlet.
Zilla timers are for aquariums, where day and night plays important role in life cycle and activity of different types of aquatic beings.
Add a comment and say exactly which Zilla timer you have, and say what specifically you have done so far, and where you are stuck, and what loads you want to control.
May 02, 2011 | Coralife Zilla Aqualight Power Center
Pool timer is set but when i turn the switch to on
leave it in the off position and wait til ten to see if it comes on. typically the timer will flip the switch on itself..
Mar 14, 2010 | Intermatic T104 24h 208-277v Mechanical...
I have a noma outdoor timer N1506 I lost the instructions how to program it could you email me telling me how it is done thanks JIm
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} 1- Plug in the timer.
2- Set the time of the day (on the hour, example. 2. Pm) using the top TIME button. For pm there will be a dot to the lower right of the 6.
3- Once the time is set push the MODE button, this will replace the 6pm with a flashing P.
4- Push the TIME button again to set the time you want the timer to come on. (Remember for 6pm there will be a dot to the lower right of the 6.
5- Push the MODE button once the desired time is set, an E will appear.
6- Push the TIME button again to select the time you want the timer to go off (example 10.pm).
7- Push the MODE Button again. The time of day 2. (Pm) will be displayed. If the timer loses power just repeat the above steps.
Dec 04, 2009 | Kitchen Appliances - Others
Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Nov 19, 2009 | Heating & Cooling
Can't figure out how to set Intermatic timer 111c up to nightlight
Hello. I can help you with this times.
Step one - insert the pins at the times you want the night light to come on and go off. The green pins will turn on the night light and the red pins will turn it off. If you just want one on time and one off time just use one pin of each color.
After you have the pins inserted, set the correct time on the timer and plug it into an outlet that is always on [not one that is controlled by a wall switch].
The override switch will turn the device off if it is on, but just one time. As the next time it turns on it will once again be controlled by the times.
If ou want the night light to come on and off in the evening and again in the morninng, use two green pins and two red pins. Push in a green pin at each time where you want the night light to come on and push in a red pin at each time you want it to go off.
Get back if you need additional clarification.
Jun 02, 2009 | Intermatic & Lighted Dial Timer
Intermatic Inc. ST01C Digital In-Wall Timer Logo
132 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
