Question about Canon Office Equipment & Supplies
The canon pixma MP520. It says there's a paper jam but I can't clear it and the paper wonlt go through. I've got a horrible feeling something fell in and got wedged deep inside. I've used a torch but can't seee any problem at either end. I've turned it upside down but can't hear anything loose. How can I get a look inside to clear this?
    Scholar:
  • 187 Answers
The only way to get inside it, is to strip it down (there's screws on the bottom). However, I wouldn't recommend doing this yourself unless you are absolutely sure you can put it back together again. Instead, if possible, lift the access flap (where you normally put the printer cartridges), and see if you can see anything in there (you should be able to roll the print roller yourself from there aswell).
Posted on May 26, 2008
I have the following error message:
SOMETHING MOST LIKELY FELL DOWN IN BACK PAPER PATH OR TORN PAPER THAT HAS PAPER SENSOR STUCK. HARD TO SEE SOMETIMES. MIGHT WHAT TO TURN MACH UPSIDE DOWN AND SHAKE BE VERY CAREFULL
Apr 14, 2010 | Canon PIXMA MP830 All-In-One InkJet...
It says "Check printer" error message "6A00".
paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 11, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp520 printer says paper jam but there is no paper there
open the back rear of printer and close it again. check for debris.
Feb 07, 2010 | Office Equipment & Supplies
NO I have the same problem as listed here "the canon pixma MP520. It says there's a paper jam but I can't clear it and the paper wonlt go through. I've got a horrible feeling something fell in and got...
You can try putting and index card or something stiff like that back thru the paper path to push back whatever is stuck. Look real close with your torch thru the spaces in the white guides that are over the long gray platen roller. Also the gray roller could have scratch marks in the area where the object is jammed. Be careful not to push back the sensor lever that is on the right side behind the white guides.
Feb 01, 2010 | Canon PIXMA MP520 InkJet Printer
Canon pixma ip 1600...can't clear paper jam there is no paper jam but it keeps telling me there is
possible that there is a very small piece of paper near the edge or back that the sensor is picking up ... check again and see if there is something there
Jan 10, 2010 | Canon PIXMA iP1600 Printer
Printer had a jam, I cleared it but now the screen flashes 3 and E alternately. I tried turning it off, pulling the plug, turning it upside down in case something fell into it! NO LUCK - anyone have any...
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tonl-i-5
Jul 22, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper feeds halfway through and then 'Jams'
you have something stuck down in your paper path, if you feed a hard piece of plastic down the paper path manually and gently you will feel something is there, a very common problem
Jun 08, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon pixma mp520
turn it upside down and give it a good shake
Mar 30, 2009 | Canon PIXMA MP520 InkJet Printer
Paper jam made horrible noise, now no power
that's the mechanism in side rebelling..I'd recommend you have a qualified service person handle this one.
Aug 04, 2008 | Canon PIXMA MP600 all-In-One InkJet...
260 people viewed this question
old marine
old marine
