Question about Sony Cameras
My Sony HVR-HD1000U camcorder will not allow tapes to be inserted. Pushing down on carrier/elevator does not click and lock it in. Can't close access door.
  • adobe611 Oct 01, 2010
    The access door is open and the carrier has moved up and elevated the tape for removal. Upon trying to load another tape, the elevator will not click shut regardless of where you push and so of course the carrier will not retract and load the tape.
    This has happened before and sometimes it would work and then not. I did learn that if the camera was set on VCR function instead of OFF, a new tape could be loaded but now that does not work.
  • 10,594 Answers
This is problem of MiniDV mechanism in camcorder that will be replaced to fix its issue.
I can provide you part number of required tape mechanism but replacement of that mechanism is job of qualified camera tech.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Oct 02, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with gently knock on the push button simultaneously opening the cassette holder and insert the cassette. Now push on the right side and gently push the holder back in position and press play, fast forward and backward one by one. The Camcorder will now accept the cassette. If still the issue is not resolved then visit an authorized repair centre to get it serviced as it is not recommended a user level repair. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 01, 2010
How to fix Sony HVR-HD1000U camcorder if it is not charging
hi,
the fault should be in side the cam, start test from the charger connecting socket, measure the power in the mother board, if any of the fusible resistor or the regulator SMD found faulty, must replace.
Dec 01, 2015 | Sony HVR-HD1000U Camcorder
Why is my sony hvr hd camcoder not switching on
hi,
Tape door on my sony HVR-HD1000 will not go down
hi,
the tape deck mechanism is faulty, the remedy is to change the mechanism. if you can repair it open take out the mechanism, remove the head, eject housing,and the sensors mechanism locking plate etc, then peel out the flexible cable from the mechanism, and change it.
Nov 18, 2015 | Sony HVR-HD1000U Camcorder
HVR-HD1000E, The tape is locked-check the tab
hello, i think the tape tab is jammed if you will need help to: Disassembly,Repair, Maintenance or adjustments and more you can download the factory service manual from the below link:
http://goo.gl/ubSnD
Good Luck
May 01, 2013 | Sony HVR-HD1000U Camcorder
Im having trouble playing back my tapes on my sony hvr hd 1000u it was working fine untill this morning when i wanted to play back some tapes before i uploaded them. What can i do to fix the problem could...
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Feb 01, 2011 | Sony HVR-HD1000U Camcorder
I have a sony hvr-hd1000u - I am getting an error message that says reinsert the cassette. Please let me know what you think the issue is. My camera will not work now because of this message. The cassette...
Hello.
This problem is solved by replacing the cassette complet mechanism, part number A1437006A MD (N220) SUB ASSY (S) A
... the cause: the flex is broken.
you can buy it on this website: https://www.servicesplus.sel.sony.com/sony-part-number-A1437006A.aspx
Hollmann.
serviciotecnico@videosistemas.com
Nov 27, 2010 | Sony HVR-HD1000U Camcorder
How to cleane comcoder head
You will need a cleaning cassette- the same type that you record on, but with a cleaning tape in it instead of recording tape.
Nov 02, 2010 | Sony HVR-HD1000U Camcorder
Sony HVR-Z1U problem inserting mini DV tape: door won't open all the way, will not close back either
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
Oct 24, 2010 | Sony HVR-Z1U Mini DV Camcorder
Cameras Logo
101 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
