Question about Sennheiser EW 300 IEM G2 Microphone
Body pack stays on - Sennheiser EW 300 IEM G2 Microphone
    Problem Solver:
  • 10 Answers
Some bodypacks have a "lock on the on position" check yours for one.If this doesnt resolve the problem.Take the Battery out and replace it with another one and see if that fixes the problem.
Posted on Oct 01, 2010
  • harlycouple5 Oct 01, 2010
    the body pack is a seinheiser ew 300 iem g2 wireless 'in ear' monitor system. The pack was exposed to corrosive batteries which were left to leak in the receiver. I suspect a carbon bridge causing the pack to remain on. Thurough cleaning, new batteries and no 'lock on position switch' have resolved the issue. "Full count, bottom of the ninth. Bunt or swing for the fences?"
2010 dodge journey sxt 3.5l, how do I remove transmission valve body cover and plug
Remove the bolts off the pan, pull the pan off.. The plug stays with the valve body/ solenoid pack. Some of the bolts are a pain to get to, it it all comes out.
Aug 06, 2016 | Dodge Cars & Trucks
Transmission solenoid pack valve
if your refering to the solenoid pack in the valve body then you first drain trans, remove pan, remove old gasket(do not discard unless you have a new gasket or the old is reusable.) only remove bolts that are pertaining to the removal of pack and or vavle body, remember what bolts go where, an then install is reversal of removal.
Jan 25, 2014 | 2001 Chrysler Sebring
Frequency lock Shure microphone body pack
Instructions on locking are in the User Guide.
Mar 19, 2013 | Shure Body-Pack Transmitter UR1J5...
MY 2004 CHRYSLER 300M CHECK ENGINE LIGHT CAME ON AND A P1776 AND P0700 CODES CAME UP, WHAT DO I NEED TO DO??? DEBBIE
p0700 indicates you have trans fault present..p1776 is a trans fault which means solenoid switch valve is latched in low/reverse position..solenoid switch valve is located in valve body of transmission,but for 2001-2004 LH vehicles you need transmission event data read to find out what TRS position the fault set..recommend chrysler dealer for this fault..also build code on solenoid pack in trans must be checked..if in a certain build code range,you replace solenoid pack..not the valve body..valve body must be removed to check build code on solenoid pack..i have seen this problem before..i am a dealer technician, and had one of these fault codes last week and solenoid pack was the problem..solenoid pack is about 375 dollars..total time with diagnostics was about 3 hours..
Jun 13, 2009 | 2003 Chrysler 300M
85 vette starts but will not stay running
there is a sensor on the throttle body it' controls the idel of the vehicle it's called a tps and has a electrical lead to it this should be replaced it will be positioned right behind the butterflyplate of the throttle body
Apr 26, 2009 | 1985 Chevrolet Corvette
Engine cannot stay on
Replace the throttle position sensor and check the wiring going to your coil pack and make sure the plug is in all the way. Clean out your throttle body where the throttle blades are with carb cleaner or throttle body cleaner. You'll see alot of black gunk come out of it. This should get the air flowing through it again and let your car idle by itself. If the tiny air gap and the throttle blade is clogged with dirt, the engine cannot get enough air to run at idle. Hope this helps.
Aug 16, 2008 | 2001 Nissan Sentra
Sennheiser EW 300 IEM G2 Microphone Logo
64 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
