Phillips projection television 106
Hi just bought this of a friend and the picture is very cloudy and fuzzy. any ideas?
  • lesleyfair23 May 27, 2008
    How do i go about doing this? is it expensive? - do i need to call in a tv repair person? many thanks
  • 8,617 Answers
Change the coolant in the CRts and the color and clarity will be restored. This is a common problem with phillips CRTs the coolant gets cloudy and needs to be replaced.
Posted on May 26, 2008
  • Sonny Berry
    Sonny Berry May 27, 2008
    I would call around and try to get a repair estimate to change the coolant in the CRTs. Which part of the country do you live in?
How do i fix fuzzy picture
It could be the crt cooling fluid in the tubes. Over time they can become cloudy and discolored, making your picture appear different looking than originally.
Mar 23, 2011 | LG RU-44SZ51D 44" Rear Projection...
Tip
If your picture is fuzzy you need to change the fluid in CRT's. Over time the...
If your picture is fuzzy you need to change the fluid in CRT's. Over time the fluid gets old and cloudy and light cant shine through properly makeing your picture fuzzy
on Jul 30, 2010 | Televison & Video
Dark, fuzzy picture
The fluid in the CRT bulbs is most likely cloudy. Check the blue to see if fluid is clear. If fluid is clear, then likely your flyback transformer is failing. I assume you already check the brightness and contrast settings on the tv.
Feb 18, 2011 | Toshiba 57H81 57" Rear Projection...
My Philips HDTV 60pp9202/17f chassis: DPTV305F picture has problems. It appears "fuzzy" and "cloudy". I've tried to go to picture options and adjust the tint,sharp,brightness, etc.. and havn't come to the...
Thats indicating that the coolant in the three CRT's need replacement. The phillips CRT coolant kit is available from www.tvrepairworld.com which contains the coolant and the CD with instructions.
Aug 09, 2010 | Televison & Video
Philips 46 in rear projection tv has too much green. The bulbs are good but adjusting the color does not help.
this models have coolent issues. I would tke off the front screen very carefully , as it may seperate , get a friend . Do not scrach the screen. then look down inside the units CRT's (Cathode Ray Tube) and see if its cloudy or fuzzy looking . While there look at the blue tube as well. If its fuzzy replace the coolent.
Jul 08, 2010 | Philips 43P8341 43" Rear Projection...
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
We are using the 55 rear tv to display our logo for a talk show.
I assume you purchased the tv in the current condition you are describing. Philips are notorious for having cloudy glyconol coolant. The coolant is situated in a chamber between the light tubes and the lenses and is required in order to keep the tubes running cool or they would otherwise crack from the excessive heat from the light tubes. The coolant normally becomes corrupted in the blue tube first, with the red and green tubes following closely behind it. The Video that is able to project through the cloudy coolant causes a picture that is washed out, fuzzy, and can even cause rainbowy colors depending on how many chambers are cloudy.
If you want further proof that the glyconol is corrupted, you can have someone remove the rear cover and take off the lenses from the light tubes so you can see directly into the coolant chambers to determine which ones are cloudy. Replacing the coolant is an involved process. You should attempt to return the tv to the sales person for a full refund if possible and explain the tv is not okay as he said.
Mar 12, 2009 | Philips 55PW9363 55" Rear Projection...
Fuzzy picture
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become  cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Oct 24, 2008 | Philips 55P8241 55" Rear Projection...
Cloudy Picture
can you psot a pic of what the picture looks like. I should be able to diagnose it if I can see the image and what its doing.
Apr 04, 2008 | Philips 9P5034C 50" Rear Projection...
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
