Question about Whirlpool Refrigerators
We have a bottom mount freezer section and the defrost cycle (I assume) melts whatever ice is in the tray of the ice maker then it is refrozen into a solid block.
  • Whirlpool Master
  • 3,289 Answers
Most defrost circuits are turned off by a either a timer or defrost terminator (a thermal cut out switch that is mounted to the evaporator coil in the freezer compartment). The circuit is designed so that once the temperature of the evaporator coil reaches about 50 degrees F, the heater is shut off by the thermal cut out switch. If it fails to reach that temperature in about 30 minutes time, the timer will shut off the defrost heater.
Since neither shut off device is working as expected, I suspect that one failed some time ago, unbeknown to you. This left the remaining device to stop the defrost cycle since that time. Now, this second device is is having issues, and you're just now seeing the result.
This is a repair that can be done be by the homeowner - BUT - may require working on live circuits for testing and potential of freezing skin due to accidental contact with refrigerant gas. As such, a pro should be called if not completely confident of performing the work.
Posted on Oct 01, 2010
GE side by side refrigerator model no TFG20JAWWW 627 litre is occasionally leaking water
Check the drip tray in the freezer section where defrost water drips from the defrost heater melting frost during the defrost cycle. If ice blocks the drain hole in the tray inside the freezer(usually behind the evaporator cover) the defrost water will travel into the bottom of the freezer & onto your floor. Some models also have a second evaporator in the fresh food section. A blocked drain or clogged defrost drain tube can cause the problem.
Apr 16, 2018 | GE Refrigerators
Why does ice build up in the bottom of the freezer, then leak on the floor.
You did not post the make and model number but there is a defrost cycle that the unit uses to defrost the freezer. When it goes into that cycle the ice on the coils melts and is supposed to run down a tube to a tray in the bottom area behind the kick panel. If that tube is plugged or the tray is full, the water ends up in the bottom of the freezer. Unless you have an ice maker in the unit that is not working right.
Feb 24, 2017 | Refrigerators
When the freezer defrosts,water drips into the refrigerator. I assume a tube is disconnected. How do I get to the area between the freezer section and refrigerator section to look at it.
sounds like the defrost drain line is blocked,what is the model number?is it a top mount freezer on top?if so remove the back inside wall of the freezer,unplug the fridge or if you have the tech sheet usually found on the bottom kick plate it will tell you how to put the machine into defrost,this will help melt out the ice,when you remove the back wall melt out the ice with a hair dryer,next you have to clean out whatever is blocked in the drain,below the evap coil you'll see a hole,that's the drain,i use a steamer to blow through the drain,this works the best,you can try a turkey baster or anything that will blow through the line,when you think the line is clear,pour hot water down the drain,if it drains through you're done,if not keep at it until water will drain through.
Mar 20, 2011 | GE Refrigerators
We accidentally left the freezer door just barely open overnight. The freezer started to thaw somewhat, but we caught the problem before anything had to be thrown out. In other words, there wasn't a lot...
yes ice formed in the bottom of the ice bin locking the auger from turning to dispense ice. Defrost the ice bin and wipe clear of any left over water from the melt.
Appliance 911 Sea Breeze
Mar 14, 2017 | Whirlpool Refrigerators
Ice build-up in bottom of freezer section.
your defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle. Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My subzero 650 has melted and refrozen cubes under normal cubes - I have emptied the ice cube tray three times, made sure it is dry before putting it back, and each time there is eventual frozen water...
maybe the water valve keep open. try replace the water valve. the ice maker energized the water valve. and release water. MAYBE in each cycle after energized the valve this one keeps open. ttry replace is really simple..... good luck...... leave a comment if it this good for you
Jan 12, 2010 | Sub-Zero 650 / O Bottom Freezer...
DSS25KSRD SS GE Adora refrigerator- ice in tray melts and refreezes at the bottom of freezer. food defrosts also, seems like maybe defrost may be running too long and heating up the ice storage bin? Have...
It sounds like the # 4 thermistor is bad . You will have to remove the lower inside rear freezer panel ( 2 or 4 screws ) and on the top of the coils , you will see a 1 " long torpedo looking piece , clipped on , with 2 white wires going to it . Part number WR55X10025 . This thermistor , tells the maon control board , the temperature of the freezer coils ( evaporator ) and when to defrost and when to stop defrosting and turn the compressor back on . There is also a defrost thermostat which cuts the heater off to keep from over heating , but I do not believe this is part of your problem . You should also replace the # 5 thermistor , located behind the oval grill , mounted on the lower right side of the freezer . This thermistor , tells the main control board , the temperature of the freezer section .
Oct 20, 2009 | GE Refrigerators
Water leaking into fridge
Unless you have a lot of confidence in your ability as a handy person and plumber, it may be better to leave this to a pro. Here's the story.
When the freezer automatically defrosts, water from the melted ice collects into a tray behind the back panel of the freezer. There is a drain in this tray, and the drain empties into a pvc tube that carries the water down into an evaporation tray that extends from front to back on the bottom right side of the refrigerator. A fan blows air over the evaporation tray to dry the water in the tray before the next defrost cycle.
Over time, the drain tube gets partly clogged with gunk, the water in the upper collection tray doesn't drain completely into the lower tray, and when the defrost cycle ends, the water still in that upper tray freezes. After a few defrost cycles, enough ice forms in the collection tray so it blocks the drain completely, and this plug won't melt during the defrost cycle. Now every time there is a defrost cycle, water collects, overflows, and drips down through the air channel at the back of the fridge into the refrigerator section.
The fix is to clear the drain tube leading from the upper collection tray to the lower evaporation tray. Here's how (if you have the know-how to tackle the job):
First, move the fridge away from the wall, unplug it, and remove the fiberboard panel that runs across the the bottom back. From the front of the fridge pull out the trim grill that runs across the bottom. Locate the evaporator tray on the right, but don't remove it yet.
Empty the freezer, and be sure to safely store the removed items in another freezer, or an insulated cooler, if you can complete the job in an hour or two. Be careful with ice cream and such, which cannolt be allowd to defrost, even partially.
Remove the ice maker if you have one, remove the screws holding down the bottom panel of the freezer, remove it, and remove the screws holding the back panel, and remove it.
Leave the refrigerator door closed, to keep the food in it from spoiling. If this job is going to take you more than an hour or two, move the food in the fridge to another fridge.
Now you need to let the freezer defrost (a hair dryer will make it go faster, but don't let it get wet), and sponge out all the water, There will remain an ice plug in the drain at the bottom of the collection tray at the back. Use hot water to dissolve the ice plug, use a drinking straw inserted into the drain (don't let it drop!) to be sure the ice plug is melted.
You still have to clear the plastic drain tube of collected gunk. This is like snaking out a drain pipe. I found that 8 feet of 1/8 pvc tubing works well. Before you clear the drain tube, remove the lower evporation tray. There is a finger hole at the front. Use it to lift the tray up and forward (be carelful, it may contain water).
Put the pvc "snake" down into the drain in the upper collection tray, and gently work it down through the drain tube. You are done when the snake emerges from the bottom of the drain tube, at the back bottom of the fridge, above where the evaporator tray sits. . Snake up from the bottom, and then back down again from the top, to be sure the drain tube really is clear. Replace the evaporator tray, and slowly pour 2 cups of water into the collection tray at the top, and confirm that it drains quickly and completely into the lower tray.
Empty the lower tray, replace it, and reverse all the disassembly steps.
This is not a permanent fix, because the drain tube could clog again, but should be good for a few years before you have to repeat this operation. At least now you know the cause and the fix, and can deal more effectively with a repair tech, even if you don't tackle the job yourself.
Jun 20, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore elite french door freezer on bottom
Odds are due to the fact the ice maker was left on for an extended time with a full tray of ice the mechanisms froze. You can take a hand held hair dryer and defrost the parts, just be careful not to get too over zealous and melt the plastic parts. It should only take a few minutes to defrost.
To avoid this problem from occurring again, I turn the ice maker off when the ice tray is full.
Regards,
Ann
Nov 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
May 21, 2007 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
