Question about Dishwashers
Hi just had new dishwasher put in its a diplomat intergrated dishwasher aca9102, only used it once and started beeping towards the end of the cycle. thought it might be coz i didn't put salt in it, and had tablets instead of detergent so put salt in and detergent in but couldn't get rinse aid. started the program on normal wash but started beeping 10 beeps straight away and the first three lights out of 6 are flashing on the control panel. could it be coz theres no rinse aid in it? please someone help me
  • tracy83 May 26, 2008
    put rinse aid in but is still flashing
Dear tracy83,
we have an aca9102 diplomat dishwasher since april 08. we now have a fault with dishwasher but cannot locate our manual. could we arrange rto have a copy of your manual? sorry for being up front but cannot obtain another manual as mfi are in adminstration now. tele EY 07947 838384. thanks.
Posted on Mar 03, 2009
  • 868 Answers
Rinse aid is always needed for ALL dishwashers to properly operate.
Posted on May 26, 2008
My diplomat ADP8352 started the cycl then stopped and was continually beeping. the three lights at the left hand side flashing. help???
Check the manual and see if it can diagnose the problem. Or you may need to have it checked. http://www.manualslib.com/manual/277803/Diplomat-Adp8352.html
Oct 26, 2014 | Dishwashers
Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Feb 03, 2008 | Dishwashers
We have a whirlpool ADG 7800 dishwasher ,getting a beeping sound and start button flashes 12 times? Any help
Hi
Ok try this and see what happens.
Hold the start button again till it beeps
Then select the first cycle on the left which should be the rinse cycle
Then turn the dishwasher off
Then press and hold the start button and with this held in turn the dishwasher on.
Once the start light is flashing let go
Now press the start button once and close the door.
Now it will run a 12 minute test cycle. If it goes wrong it will drain the water out and beep. So open the door and count the number of flashes from the start light inbetween the pause and let me know.
Regards
Oct 11, 2014 | Whirlpool Dishwashers
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
My Diplomat dishwasher ADP8352 keeps stopping
Switch off the machine at your plug end and switch ON.
Check incoming water flow. Check and fill rinse-aid liquid in the dispenser. Check dish washer salt dispenser and fill.
These are the only actions an user can try.
May 27, 2010 | Dishwashers
Water not draining after last cycle
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 13, 2010 | Hotpoint 24 in. HDA3740G Built-in...
Diplomat adp8322 dishwasher has start button flashing 7 times and rinsne cycle light on what does this mean
This is stating that no water is entering the dishwasher.
My solution was to turn the power off at the wall and wait for 10 minutes.
Turned it back on. Pressed the Start button and held til it beeped and reset, then started as normal and all was fine.
Jan 02, 2010 | Dishwashers
Diplomat Dishwasher motor cutting out on hot mid cycle
Hi ,This problem is your main wash motor the origonal is an ascol
motor ,but the replacement is a motor with copasiter costs
around £80.00 for new motor
Nov 19, 2009 | Dishwashers
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
The power light is on. no leak, checked drawer, which is dry..no other lights
do you feel a warm sensation if you put your hand inside the unit?if no,then the heater is busted.do you hear a sound like a fan or feel airflow inside the unit?if still no, bring it to a tech.
May 28, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishwashers Logo
817 people viewed this question
Top Dishwashers Experts
