Pilot lights up but burners and blower do not come on, and pilot is still clicking. I cleaned it last year and it was working perfectly
  • 1 more comment
  • Kim Yearick
    Kim Yearick Oct 02, 2010
    framus855,
    If you can supply the model and type of heater (gas or kerosene) I may be able to help.
    Thanks for using FixYa.
    hardrocko
  • framus855 Oct 02, 2010
    too late and I do not believe I will ever use this site again
    and here is why, I figured it out myself without having to spend a couple of hundred of bucks
    hardrocko, thank you for being here, and at least your effort to offer help to me :o)
    I post on other sites and they will soon know of my experience here
    my question was simple
    In my previous comment I was a little harsh, and I would return to seek help
    thank you to anyone who takes the time to help it is much appreciated
  • Heating & Co... Master
  • 2,597 Answers
Clean the flame senser if fitted could be dirty , use some steel wool to clean it ,or try jumping out the pressue switch see if that works
Posted on Oct 02, 2010
    thank you for the info paul :o)
    just for the sake of helping anyone else, I thought that it had to be a sensor so I followed the wire to the back of the sensor and was ready to replace it. I wanted to see how hard it would be to reach and how it was connected and low and behold with a gentle wiggle and litle push of the wire it made a better contact and the furnace is working just fine
Fireplace burner won't stay on
try cleaning the pilot sounds like its a short pilot and when the burner comes on it pulls the gas from the pilot light .
Feb 22, 2013 | Heating & Cooling
Bryant plus 90 intermittent start-up
That's an intermittent problem. Could be: dirty filter, dirty blower wheel, dirty secondary heat exchanger, dirty evap. coil, weak or damaged high temp safety, loose wire connection, fault at control board, poor air flow. Just about 100 guesses! Could be's don't solve anything. Check for cleanliness. Clean flame sensor(flame rod that burner flame comes in contact with). These are the first I would try.
Mar 10, 2017 | Heating & Cooling
I have a Dayton furnace in my garage. It is well over 20 years old and it is a gas one. Long and narrow with blower on the top and burner on the bottom. Last year I had someone come to look at it because...
I would check and see if the heat exchanger is not spilt and the blower on top is blowing out the pilot .Also clean pilot and check thermocouple .
Mar 13, 2017 | Dayton (3E386) Heater
Right stove top burners won't ignite
Your right side burners probably have small vertical lighting holes that are clogged where the pilot lights the burner. Use a sewing needle to poke each hole clean. While you're at it, poke clean the horizontal burner holes just to make sure they are not clogged either. Are there also little tunnels from the burners to each pilot flame? Make sure those are clean inside and attached properly on each end. The pilot flame should be approx 3/8" tall. Compare the working pilot flame to the non-working pilot flames and adjust as necessary. Each pilot has a small aluminum tubing running to it, the adjustment screw will be on this tube. You'll just need a small flat head screw driver to turn it counter-clockwise to increase flame. Hope this helps. Let us know if we can be of further assistance. Douglas
Jun 05, 2010 | Amana ACF3325 Gas Kitchen Range
Pilot light will light, burner & blower comes on for a few minutes, pilot & burner go out, blower stays on.
Sounds like a bad or dirty flame sensor. Look for a sensor located in the flame of the very last burner that ignites. Take a toothbrush and scrub it a little. Then try again. Do not scrub the igniter as it is very brittle.
Feb 11, 2010 | Heating & Cooling
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
I have a coleman propane furnace in my home that is 30 yrs old. you can light the pilot but when you turn up the thermostat so that the burner will light and the fan will blow the pilot goes out after a...
watch your flame on the burners and see if the flame changes when the blower starts if it does and makes the flame jump around you have a busted heat exchanger
Nov 22, 2008 | Heating & Cooling
Blower works but no heat
If in fact you have the above listed furnace, you do not have a pilot but electronic ignition. You will need to remove the front cover on the furnace, tape down the door safety switch and then have someone help you by turning up your thermostat to a very high setting. Watch and listen inside the furnace. There should be some blinking going on at the control board followed by a small blower fan starting up. Then after 10-15 seconds there should be a click followed by an orange glow viewed thru the viewing window to the burner section. In a few seconds the gas valve should click and the burners will ignite. There is a safety switch that will sense flame and then keep the gas going to the burners. If it does not sense it, it will shut it off within 10 seconds. If all is well so far, your blower will turn on in about 90 seconds after flame. There is a diagnostic code chart on the back side of the access door if you get an error code (blinking) on the control board.
Always check little things like air filter, condensate drain and broken or loose wires.
Nov 05, 2008 | Goodman GMS90703BXA Heater
Heater blower motor cycles on and off (frequently). I have a class 2 LR95329 Honeywell Thermostat
The clicking noise is a relay or switch of some sort. You are right about that. I have 2 questions. 1) does the thermostat have a mercury bulb in it? 2) when the fan shuts off and on, does the burner stay on?
Nov 05, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
