Question about Garmin nuvi 1350 Car GPS Receiver
My garmin nuvi 1350 send a error message ....no map data available
tech curly
  • 298 Answers
SOURCE: Garmin Nuvi 750 GPS
Have you tried this?
You can try this step that I found. If you tried loading other mapas try this.
You will need to erase a file from the units memory. Connect your GPS system to your computer; go to start then ‘My Computer’, and double click on your device file (mass storage system), there you will see a folder named ‘Garmin’.
In this folder are several different files, look for file named gmapsupp.img. Right hand click on this file and delete as this file is causing the maps to lock.
Posted on Aug 03, 2008
sharcnet
  • 2130 Answers
SOURCE: "No Map Data Available" - Garmin Nuvi 350
This is because your map file has either been deleted or corrupted and needs to be replaced. Please see this link for more info. Too much info to copy & paste here:
http://www.sharc.net/nuvi_lost_map.htm
- Jim
Posted on Dec 13, 2008
  • 6 Answers
SOURCE: No map dat a available
who need to hook it up to the computer and download the maps back in to the Nuvi. Kinda reprograming if you will. the Garmins usually dont come with the usb cord to conect to the computer but you should be able to buy one. hook it up and download all the maps and you should be good to go. Oh by the way they have lots of cool fetures to download on the Garmin website cool cars and voices, although i prefere for mine not to talk. Good LUck
Posted on May 24, 2009
  • 279 Answers
SOURCE: garmin nuvi 660 lost map data
Hi Bruce. The same thing happened to me . I called customer support
1-800-800-1020 and they were able to link ino my computer, go through it and into my GPS. Hopefully this will work for you!!!
Tom
Posted on Sep 20, 2009
SQUIRESXX
  • 486 Answers
SOURCE: Well my Garmin nuvi 1300 was working fine
it sound like someone has "unticked" maps go to settings then maps and map info and look for the screen that says city navigator, and tick box that should work unless someone has attached to pc and wiped maps
Posted on Dec 27, 2009
Garmin nuvi 1350 map cannot update
may have to download plugin, garmin communicator off my.garmin.com
Nov 06, 2013 | Garmin nuvi 1350 Car GPS Receiver
Tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1350 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1350 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1350 Manual Download
Garmin Nuvi 1350 QuickStart Download
Garmin Nuvi 1350 Webupdate
Garmin Nuvi 1350 Favorites Backup
on May 15, 2010 | Garmin nuvi 1350 Car GPS Receiver
Tip
Garmin Nuvi 1350 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1350 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
on May 15, 2010 | GPS
Garmin Nuvi 1350LMT Nuvi 1350 W map update error
Run the Garmin WebUpdater once more and apply any updates. Consider downloading and installing the lifetime map update to the computer and then use the Garmin Mapquest or Basecamp computer program to send the map data to the nuvi. Overall, it takes a little longer, but is better than trying to download directly to the GPS itself. If you're not having luck, it will probably be wise to contact Garmin Tech Support. It would be wise to mention the funky "once / month" GPS reboot issue with Garmin at this time too.
May 10, 2012 | Garmin Nuvi 1350LMT
No mapdate available
Map updates become available every 3 to 4 months for garmin satnavs. If when you log in to myGarmin and click on the myMaps tab you see a message "No updates available" it's because you have the latest map. When a new version is released it will change to "Get Update"
Jun 02, 2011 | Garmin nuvi 1350 Car GPS Receiver
Tip
I hope that helps.
Tip
Download Garmin Nuvi 1350 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1350 GPS?
Would you like a digital copy of the Garmin Nuvi 1350 Users Guide for easy searching of terms and quick reference?
The Nuvi 1350 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
No map date available.
My garmin nuvi 1350 shows message "no map data"
The solution to this problem is at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
There's probably more information there than you need so you should be able to start at paragraph 2.
Oct 26, 2010 | Garmin nuvi 1350 Car GPS Receiver
Garmin nuvi 1350 Car GPS Receiver Logo
2,521 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
