Question about Dell PowerEdge 1600SC Server
My dell server 1600sc power edge is not booting with warning led in power supply
    Scholar:
  • 64 Answers
If the system has no redundant power supply.
basically you will need to replace it with the same make and model from Dell or a working 2nd hand model.
Posted on Oct 07, 2010
  • shimmix Mar 16, 2011
    I have the same problem with the same model, but the two power supplies having the warning led, any suggestion?
Cloned Drive won't boot on Dell 1600SC
If you are using an image made from the IBM and it has a different processor and the board specs are different that can cause the drive not to boot it will act like it is then go into a perpetual boot. I would try to re image it again to insure that is ok on the drive also check the board If one is and AMD and the other an Intel then that would be part of the problem.
Aug 05, 2017 | Dell PowerEdge 1600SC Server
Hi i have connected a floppy disk drive to my Dell PowerEdge 1600SC Server but the pc cant find it. i know that the drive forks cos if i insert the ide cables the other way the disk drive led turns on but...
Not sure what "the drive forks" actually means.
The floppy drive usually connects via a dedicated connector on the motherboard by a ribbon cable similar to the IDE cables but physically smaller and of course to the power supply. If the drive, the cable and the motherboard is ok it should appear in the bios list ready to be enabled and added to the boot order.
If the floppy drive doesn't appear in the list you should refer to the motherboard manual as there might be some jumpers to reset or perhaps it is only suitable for a usb floppy drive.
Take the number from the motherboard and do an internet search which should direct you to a place where you can download a manual which will contain all the information you need.
Nov 11, 2017 | Dell PowerEdge 1600SC Server
No power to dell poweredge 1600sc. Redundant power supplies have no lights.
Either the power supplies have both failed, which is unlikely, or they are not connected to a hot outlet. Frequently servers are connected to uninterruptible power supplies (UPS) instead of being connected directly to a wall outlet. Make sure the UPS is on and functioning.
Dell provides lifetime phone support for their servers so you should give them a call if you need more help tracking down the problem. (800) 945-3355
If this helps please vote for my solution.
Feb 12, 2010 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server occasionally beeps when running
Check out this site:
http://bioscentral.com/postcodes/dellbios.htm
Write down the exact number of beeps and how long they last to find what the error means. The are call BIOS post codes and they resemble Morse Code. (ie. one long, 3 short, 2 long = RAM issue) Good luck!!
Sep 26, 2008 | Dell PowerEdge 1600SC Server
How to install win2003 server freshly on dell power edge 1600sc?
You'll need to load the SCSI hard drive controller driver.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PWE_PNT_XEO_1600SC&os=WNET&osl=en&catid=&impid=
Aug 06, 2008 | Dell PowerEdge 1600SC Server
Automatic power on
Hi
I do not know why you need the automatic power on for your server. Server should be on all the time 24/7 .
If it is a PC , then you should know that even though shutdown , they are still on (you can see a light) .
This means you can use magic bullet to wake it up (wake up on lan).
Read up on magic bullet.
Good luck,
David
Jun 11, 2008 | Dell PowerEdge 1600SC Server
No Video Signal on 1600sc
Disconnect from the network and all other accessories, and power up the system, this might be due to a faulty device attached to the system, eg: when you connect a usb faulty device the boot takes very long time, sometime it does not boot up.
Dec 30, 2007 | Dell PowerEdge 1600SC Server
No Boot on 1600sc
The easy answer is: Did you ensure the CPU fan connector is attached to the PROPER motherboard CPU fan power pins? The 2nd easy answer is: Are you sure your CPU is properly placed inside the socket? Could it be tilted slightly up on one side? The more complicated 3rd answer is: I've seen people use the spray can of AIR, which, believe it or not causes a moisture problem AND can overly cool a component. Although the motherboard looks fine, it won't boot or power on until the part(s) rewarm to room temperature or the moisture dissipates. This is how I solve this problem. I remove the motherboard or open it completely up to clean it with 80psi of compressed air. (remove all components) If it had previously been cleaned with a can of AIR, I let it sit for half an hour. When putting the parts back together (leave the HD, the CD, the floppy disconnected), (oh...ensure your front panel connectors are properly on the correct motherboard pins too.) 1)take extra caution with both the video card and the memory chip slots!! Inspect the video card gold edge and video card slot for a few strands of carpet fiber or DUST bunnies wedged or attached to the card/slot (which causes the computer to not power ON) 2) Inspect the memory sticks and memory slots in the same manner. (I had to see it with a magnifying glass, to see the problem) Once back together, if it boots, I'm done. If it didn't boot, I replace the power supply. If that didn't solve it, I reposition or change the RAM memory. Attention to detail is the key to success. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server Logo
221 people viewed this question
Alun Cox
