Question about Philips Televison & Video
Can't copy from hard drive to disc and draw on dvd jammed
How can I place DVD in tray, play and transfer to library?
Posted on May 26, 2008
  • Herky3314 May 26, 2008
    How can I place DVD in tray, play and have it entered in library
DVD Fab isn't copying DVDs anymore.
Try. reinstalling your media program.
Nov 20, 2016 | Televison & Video
Tip
How to copy DVD Movie on Mac OS X?
This step-by-step guide is dedicating to demonstrate how to backup DVD movie (copyright protected included) to computer and copy DVD to a new DVD disc with no protections on Mac OS X (leopard included)
The tool you need is Aimersoft DVD Copy for Mac, which you can download for free from here.
It’s very easy to use, just with three simple steps then you can easily copy DVD on Mac.
Step1. Select DVD Source
After you install and lunch Aimersoft DVD Copy for Mac, put the DVD disc into your DVD drive. Click the “Select Source” drop-down list to browse your computer and located your source DVD movie (either in a folder or from your DVD-ROM).
Step2: Select DVD Copy Method
Aimersoft DVD Copy for Mac allows you to back up DVD to a folder on your hard drive or directly copy DVD to a new DVD disc. In the “Select DVD Copy Method” field, select a method to output the selected DVD movie according to your need:
If you want to back up your DVD movie to a folder on your hard disc, you can select the “Output DVD Folder” option, and specify a directory to save the copied DVD movie.
If you want to directly copy your DVD movie to a new DVD disc, you can just select the DVD Burner where you have inserted a blank DVD disc.
Note: If you are copying a DVD disc from your DVD Burner to a new DVD disc, Aimersoft DVD Copy for Mac will ask you to insert a blank DVD disc when the program gets ready to burn. Then you can just take the original DVD disc out and insert a blank DVD disc.
But if you have two or multiple DVD Burner, you just need to change object DVD to another DVD burner and insert a blank disc into it , then Aimersoft DVD Copy for Mac will automatically copy DVD movie to the new DVD disc. No need to wait for the conversion to insert a new blank DVD disc.
Step3: Program Settings (optional)
Set Buffer Directory: Specify a directory on your hard drive as the buffer directory to store the temporary files generated during the conversion. We recommend that you select a folder on a hard drive that has relatively big free space.
Select Language: Select an interface language for the program. The currently available languages are English and Simplified Chinese.
Step4: Start Copying DVD
After all things done, click the Start button to start copying your DVD movie or burning it to a new DVD disc. That’s all.
on Feb 10, 2010 | Computers & Internet
Can hdd be copied
If computer detect your hard disc, you can.
May 02, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Cd drive and burner are not working
Test the disc by using the command prompt to copy files loadTOCNode(2, 'whattotry'); Try to copy files from the disc to the hard disk. If the hard disk cannot copy files, the disc might be damaged. If the files are copied successfully, there may be file types on the disc that the hard disk cannot read, or there may be a problem with the CD or DVD drive.
To test the disc by using a command prompt to copy files, follow these steps:
  1. Create a test folder on the hard disk, and then give the folder a folder name such as "cdtest." This is the folder to which you will try to copy files.
  2. Click Start, and then click Run.
  3. Copy and paste (or type) cmd in the Open box, and then press ENTER.
  4. Copy the files from the CD or DVD drive to the test folder on the hard disk. To do this, type xcopy DiscDrive:\*.* HardDiskDrive:\cdtest /v /e at the command prompt, and then press ENTER. Make sure that you replace “cdtest” with the name of your test folder.
    Note In this step, DiscDrive is the drive letter of the CD or DVD drive with which you have problems. HardDiskDrive is the drive letter of the hard disk drive to which you want to copy these files.
  5. If you are asked whether cdtest specifies a file name or a directory name, press F.
  6. If you successfully copied the files from the disc to the hard disk, the disc is not damaged. To remove the copied files, type rd /s cdtest at the command prompt, and then press ENTER.
    If you cannot copy the files, the disc may be damaged. Contact the manufacturer of the damaged disc to obtain a replacement.
Jul 05, 2010 | Microsoft Computers & Internet
Driver needed for TSST Corp CDDVDW TS-H653N SCSI CdRom Device please. DVD drive shown in My Computer, and MS says I have the correct driver for this device. But, it doesn't work.
If the computer still cannot read a disc, there may be a problem with the drive. Go to method 3 to troubleshoot the CD or DVD drive. If the computer can read the other disc, there is a problem with original CD or DVD. Contact the manufacturer of the damaged disc to obtain a replacement. Method 3: Try a different disc drive If the disc is clean and undamaged, check whether there is a problem with the drive. To do this, follow these steps: If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc. If your computer does not have more than one disc drive, you can insert the disc in a different computer. If the other CD or DVD drive can read the disc, there may be a problem with your CD or DVD drive. Go to method 5. If the other CD or DVD drive cannot read the disc, the disc may not be compatible with the drive. Go to method 4. Method 4: Make sure that the disc is compatible with the drive Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive. A DVD disc is incompatible with a standard CD drive. A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs. A DVD disc is incompatible with a drive that does not have a DVD logo on the front. If the disc is compatible, go to method 5. If the disc is incompatible, use a compatible disc or contact the vendor for a compatible replacement. Back to the top Method 5: Use Windows Update to check for updated drivers If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing. To check for driver updates that you can install, visit the following Microsoft Web site: http://windowsupdate.microsoft.com If these methods do not resolve your issue, try the advanced troubleshooting steps in this article. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help, or you might want to contact Support. For information about how to do this, visit the following Microsoft Web site: http://support.microsoft.com/contactus/ If methods 1 through 5 did not resolve the issue, you can follow these methods to try to isolate and resolve the problem. Method 1: Test the disc by using the command prompt to copy files Try to copy files from the disc to the hard disk. If the hard disk cannot copy files, the disc might be damaged. If the files are copied successfully, there may be file types on the disc that the hard disk cannot read, or there may be a problem with the CD or DVD drive. To test the disc by using a command prompt to copy files, follow these steps: Create a test folder on the hard disk, and then give the folder a folder name such as "cdtest." This is the folder to which you will try to copy files. Click Start, and then click Run. Copy and paste (or type) cmd in the Open box, and then press ENTER. Copy the files from the CD or DVD drive to the test folder on the hard disk. To do this, type xcopy DiscDrive:*.* HardDiskDrive:cdtest /v /e at the command prompt, and then press ENTER. Make sure that you replace “cdtest” with the name of your test folder. Note In this step, DiscDrive is the drive letter of the CD or DVD drive with which you have problems. HardDiskDrive is the drive letter of the hard disk drive to which you want to copy these files. If you are asked whether cdtest specifies a file name or a directory name, press F. If you successfully copied the files from the disc to the hard disk, the disc is not damaged. To remove the copied files, type rd /s cdtest at the command prompt, and then press ENTER. If you cannot copy the files, the disc may be damaged. Contact the manufacturer of the damaged disc to obtain a replacement. To continue trying to isolate the problem and test the CD or DVD drive, go to method 2. Method 2: Test the CD or DVD drive in a "clean boot" state If the disc is readable and undamaged, there may be some hardware or software that is interfering with the CD or DVD drive. You can test this by inserting the disc into the drive after restarting your computer in a clean boot state. This helps you determine whether any hardware or software is interfering with the CD or DVD drive. To test this, follow these steps: Restart the computer in a clean boot state. Note For more information about how to start Windows with a minimal set of drivers, click the following article number to view the article in the Microsoft Knowledge Base: 310353 How to configure Windows XP to start in a "clean boot" state After the computer is restarted, exit all programs and applications that may be using the CD or DVD drive. First, right-click each icon in the notification area, and then click Exit. Note The notification area is located at the far right of the taskbar, near the clock. Some programs that are listed in the notification area do not have an Exitcommand. Therefore, you may have to click Quit, Close, or Disable, depending on the commands that are available for that program. Click Start, and then click Run. Copy and paste (or type) taskmgr in the Open box, and then press ENTER. Windows Task Manager opens. Click the Applications tab. If any programs appear in the Task list, click the name of the program to select it, and then click End Task. Repeat the previous step until the Task list is empty. Close Windows Task Manager. Reinsert the disc in the CD or DVD drive. If the CD or DVD drive can read the disc, there may be other programs preventing the drive from reading the disc. Go to method 3. If the CD or DVD drive still cannot read the disc, go to method 4. Or, if you are not specifically using a DVD drive, you may want to contact Support. For information about how to contact Support, go to the "Next Steps" section. Method 3: Change the CD or DVD drive configuration If there are programs that are preventing the drive from reading the disc, you can try to resolve this issue by configuring the drive to run in direct memory access (DMA) mode. DMA mode is a high performance mode for transferring data to and from devices. These include CD and DVD drives. To configure the CD or DVD drive to run in DMA mode, follow these steps: Configure the CD or DVD drive to run in DMA mode. For more information about how to switch your computer's disc drive controller to DMA mode, click the following article number to view the article in the Microsoft Knowledge Base: 310751 Device settings are hard to find in Windows XP Reinsert the disc in the CD or DVD drive. If the CD or DVD drive can read the disc, you are finished. If the CD or DVD drive still cannot read the disc, try to troubleshoot DVD components by using method 4. Or, if you are not specifically using a DVD drive, you may want to contact Support. For information about how to contact Support, go to the “Next Steps” section. Method 4: Troubleshoot DVD problems If the advanced troubleshooting methods 1 through 3 do not resolve the issue, and you have problems specifically with a DVD drive, follow these steps to try to isolate and resolve the problem. Prerequisite You must use a DVD drive with a DVD logo on the front, not a standard CD drive. Step 1: Unplug any cables that are connected Unplug any cables that are connected to the video outputs of the computer. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, you may have problems with the video hardware installed on your computer. Contact the manufacturer of the video hardware for support or for a replacement. If the DVD drive still cannot read the disc, go to step 2. Step 2: Update the DVD driver Contact the manufacturer of the DVD drive to obtain an updated driver for the DVD drive, and then follow the manufacturer's instructions to install the driver. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, the problem was caused by an outdated driver. You are finished. If the DVD drive still cannot read the disc, go to step 3. Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder Contact the manufacturer of the DVD drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer's instructions to install the decoder. Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, the problem was caused by an outdated DVD decoder. You are finished. If the DVD drive still cannot read the disc, make sure that the sound card in the computer is compatible with the DVD drive. To do this, contact the manufacturer of the sound card. Reinsert the disc in the DVD drive.
Feb 27, 2010 | Compaq Computers & Internet
Recording a dvd to the hard drive
look for an option in the DVD menu for dubbing this means to copy contents to hdd (usually cannot do it with copy protected discs but will be ok with a disc you made yourself)
Aug 30, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Dvd burner question
First off is the drive a read only drive or a Read/write drive? If you look at the front drawer check to see if there is a big RW(read/writable) on the front of the drawer. If it doesn't have the RW then you won't be able to burn discs. If it says RW then you will be able use it to copy DVDs. You accomplish this by using software to copy the disc you're interested in to your hard drive and then using the copy on the hard disc to copy back to a blank recordable DVD placed in to tray.
Jul 23, 2008 | Computers & Internet
DVD Burner will not burn
Read the front of your drive to see if you have a DVD-R or DVD-RW drive. A DVD-R will copy a DVD to your hard drive, but will not burn it. If you do have a DVD-RW drive, try a different brand of disc or a DVD-R disc, some drive are just temperamental.
Jun 13, 2008 | Toshiba Satellite A105 Notebook
Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Nov 18, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Disc loading problem
disk draw timing is probably out ( gear or mechanism jumped out of time
Jan 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Televison & Video Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
