Question about Toys
How do you change the batteries on the evenflo portable fun ultrasaucer's little king & queen figures, so they make music?
5 Suggested Answers
SOURCE: I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Posted on Apr 19, 2009
SOURCE: i need instructions for evenflo ultrasaucer model 25803867
See my clarification above. You NEED to remove this as a solution because it's NOT a solution! And where is my vote? nate99 now has 2 votes and it still only shows one. Obviously this is a bogus site put here to sell advertising. What a waste of time!
Posted on Oct 03, 2009
  • 100 Answers
SOURCE: Need to put seat back on Evenflo saucer
Hello
If you click on this link https://plweb.evenflo.com/replacement_parts.aspx You will be able to type in your model number for your ultrasaucer you will need the manufacturerr date and it should allow you to get an instrctuion manual
Thank you
Posted on May 03, 2010
  • 239 Answers
SOURCE: How do I change the
According to the instruction manual you cannot replace the batteries.
Having said that it may be worth contacting the suppliers via their website to see if they can help
evenflo.com
Posted on Mar 06, 2011
How to convert evenflo exersaucer
Here's a step-by-step article for converting the Evenflo Exersaucer. It has photos and videos. How to Convert the Evenflo Exersaucer into Stage 3
Mar 01, 2015 | Evenflo Exersaucer Triple Fun Active...
How do I disasemble an Evenflo Ultrasaucer to throughly clean it?
Here is a link to the manual: file:///C:/Users/erwooster/Downloads/25707060.pdf
States batteries are not replaceable, which means that they are buried somewhere inside the main module. Proceed at your own risk.
Oct 30, 2013 | Evenflo Exersaucer Triple Fun Active...
How do I change the batteries in the evenflo ultrasaucer and what kind of batteries do we need to get. Where to find the batteries?
evenflo.com
Mar 06, 2011 | Evenflo Toys
I am needing an instruction manual for an Evenflo Exersaucer Triple Fun 25800496 08/06
hi
here is a page link to instruction download
near to bottom of the page
https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=6231883&txSearchDOM=1/1/2010
Oct 26, 2010 | Evenflo Exersaucer Triple Fun Active...
How do i put the seat back on my evenflo exersaucer
There are several models of exersaucers, but hopefully the seat attachments are similar. Here is a video from Evenflo showing how to assemble the product. This might help you.
http://www.evenflo.com/resource.aspx?id=467&rcid=19
Sep 29, 2010 | Evenflo Exersaucer Triple Fun Active...
Hello
Thank you
May 03, 2010 | Toys
Evenflo exersaucer with animals and a jeep which plays music. How do you change the batteries in the jeep?
It's a little tricky and you'll end up ruining a couple of hte stickers. This is what you'll need to do -
1. Pry the latches loose under the top that hold the jeep in place
2. Unscrew the 4 screws that hold the jeep to the base
3. 2 of the wheels have screws - use a small screwdriver to remove these
4. The window stickers on the same side as the wheel screws cover 2 more screw holes - you'll need to feel for these and poke holes through the stickers to get to the screws.
5. Once you remove all these 4 screws, the jeep should come apart in 2 halves. Dont exert too much pressure while separating them.
6.The inner assembly (purple with gorilla) slides out of the body of the truck. The base of this assembly has 3 batteries that you'll need to pry out and replace.
Sep 19, 2009 | Evenflo Exersaucer Triple Fun Active...
I need instructions for evenflo ultrasaucer model 25803867
Apr 19, 2009 | Evenflo ExerSaucer SmartSteps Active...
Lost instructions to the evenflo triple fun excersaucer
put the bottom and top togather where the 3 holes are on top put the springs put the caps on and turn them. You will have to use a little pressure but they will turn
Dec 21, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
Toys Logo
168 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
