Question about Flotec 3.4 Hp Floodmate Submersible Sump Pump
I have a flotec shallow well pump i can not get it to pump the water it stays at 20 pounds did i hook it up wromg
    Scholar:
  • 150 Answers
Check your pressure tank. It sounds like it is water logged. This means there is no air pressure in it. If you're cut in pressure is set at 30 pounds you must have 30 psi of air pressure in the pressure tank.
Posted on Oct 01, 2010
Need manual for ACE5S 1/2hp well pump
https://inspectapedia.com/water/Water_Ace_Pump_Manual.pdf
Add Comment if this is not the manual. Your question is posed under Flotec Corrosion Resistant Shallow Well Jet Pump, but you requested a manual for ACE51 pump.
http://www.wellpumpsystem.com/tags/ace5s/
May 05, 2018 | Flotec Corrosion Resistant Shallow Well...
Why isn't my pump pumping any water
Flotec FP4012-10 1/2 HP Shallow Well Pump Jet ...
www.amazon-associate.com/Flotec-FP4012-10...Well.../B0002YXB14?...
Find helpful customer reviews and review ratings for Flotec FP4012-10 1/2 HP ... After realizing the failure was due to a high amount of sediment in my well I ...
Aug 30, 2015 | Flotec Pump FP4022-10
Flotec Model FP4012-D8 stopped pumping water. I took pump apart except for small impeller housing edge break I can see no reason for no suction?????
Hi jandh40...
You have an air leak somewhere in your piping, housing of the pump or maybe the mechanical seal and that is causing your pump not to pump.
Try to disconnect the piping and hook a water hose up to the pump and turn the pressure on, it should show you where the air leak is by spraying water out of the leak area.
Please take time to rate me
Aug 15, 2011 | Flotec Corrosion Resistant Shallow Well...
My flotec 1/2 hp shallow well pump pumps to 45# of pressure rapidly, takes longer to get to 49# pressure and then takes 30 - 45 minutes to reach the 50 psi shut off pressure. The pump is hooked up to a...
Those pumps will reach 50# when brand new, but soon the parts wear and then they will not make that pressure anymore...
Instead of replaceing the pump, just back the pressure down a tick or two to get it to shut off and not waste your electric....
Well Pressure Switch Adjustment Water Well Problems
heatman101
Jan 03, 2011 | Flotec Corrosion Resistant Shallow Well...
Pump will not stay running. motor gets warm. motor shuts down after running for about 10 to 20 seconds.
Check the voltage at the pump while its running. If the electric feed line is too long for the guage wire,
voltage drop will cause the motor to overheat and switch off.
Oct 07, 2010 | Flotec Corrosion Resistant Shallow Well...
How far will a 1/2 horse shollow well pump pull water from a sorce? Not vertical, but horizonal?
To be very effective 60 meters horizontal and 20 meters
vertical distance from a water source free from pipeline leaks.
Oct 03, 2009 | Flotec Corrosion Resistant Shallow Well...
Pump stopped working while pumping
Yes, most motors are thermally protected. It is usually bi-metallic, and resets itself.
--W/D--
Aug 08, 2009 | Flotec Corrosion Resistant Shallow Well...
I have a flotec water pump that sits on top of my pressure tank, pump worked ok last season, and when we tried to prime the pump to start this season, it wont pull water up from the well pipe, pump will...
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Apr 06, 2009 | Flotec Corrosion Resistant Shallow Well...
Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Jan 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Flotec 3.4 Hp Floodmate Submersible Sump Pump Logo
228 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
jasbo
jasbo
Are you a Flotec Garden Expert? Answer questions, earn points and help others
