Question about Sony Playstation 3 (PS3) Console
When i press the button the green light comes on then the light turns orange then bleebs and flashes red. whats happening can u help
  • 4,102 Answers
Hi, its not good news im afraid the reason it shuts down and gives you a ref light is due to damage being done to the circuit board inside the ps3.
it could be that it has over heated which is often the case this could be down to dust build up or if the heat sink paste on the gpu and cpu chip has gone brittle or if you have been using the ps3 on carpet or in top of anything else that gives off heat such as dvd or sky box, these cause it to over heat really quick.
right now you have a couple of options if you have any warranty left take it back and get a refund if your warranty has run out then you could try getting it repaired but their is no guarantee the repair will work or how long it will work after the reapir.
as you have got the red light this does mean the console has over heated and their is a fault with the board so its not going to work again the way it is.
now i repair these for 25 quid plus parts so you need to look around if you want it repaired and see what the best price you can get.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
z9
Posted on Oct 01, 2010
Danfoss rx1 thermostat shows 'of' ?
Remove batteries from room stat,turn off the electrical supply to reciever unit.
Turn back on the electric to reciever unit,the red light should be on,press the top "manual" button,the green light should come on and boiler should fire (assuming the programmer is in an "on" period)
Press the bottom button,and keep it pressed,then press the top button until the green light flashes,stand about 6 feet away,and refit the batteries to the stat while observing the reciever unit,either the red or green light (cant remember which) should flash to show the 2 units are syncronised.
Another basic test if all seems ok,when turning the stat up or down,when the green light on the reciever unit comes on or goes off,its usually accompanied by an audible "click" ive found,that if this is not happening, the reciever unit does not switch either on or off,may be intermittant.
Replacement is the only cure.
garden led light
Jun 04, 2012 | Garden
Canon IP5200R printer. Green & red led`s flash 20 times, pause & repeat. print head will not come out of park position on righthand side. Fault occurred while printing a photo error 6500 displayed
Hello!
Error 6500 or green and red flashes 20 times, mean hardware error. Particularly, the Logic Board Assembly
There are two possible fix: first is to reset the printer's waste ink counter and the second is to replace the Logic Board Assembly (part # QM2-2733)
Reset the Waste Ink Counter:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a
function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
For technical help:
  • For toll-free technical support, please call 1 (800) OK-CANON (1-800-652-2666) during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
Hope this helps!
May 18, 2011 | Office Equipment & Supplies
It wont charge it blinks three times then stops
Hi,Okay, well, I don't want to be a shill for Apple (I mean, heck, I had to buy my Shuffle, so it's not like they're sponsoring this in any way! :-) so let's talk about the color sequences and what they mean.
First off, there are a number of different functions that are denoted by different color sequences, so flashing green might mean one thing when you're listening to music, and something else entirely when it's plugged in and charging or syncing with your PC.
The primary functions are powering on, charging, syncing, and general feedback. Let's look at each.
When you turn on your ipod shuffle, the light will indicate your current charge level:
green = 30-100% charge, you're good to cruise
orange = 10-30% charge, low, but still good for a short workout
red = less than 10% charge, time to plug it in
no light = too late, you've run out of juice
If you see an alternating pattern of green-orange-orange then your Shuffle's crashed or otherwise needs to be restored. Needless to say, that's not a good thing, but probably easy to fix when you hook it up to your PC or Mac.
When you're charging up your shuffle, there are three possible light states:
orange = charging
green = fully charged, unplug whenever you're ready to go
flashing orange = busy, either syncing or in use as a remote disk
When you're playing some music, you can see visual feedback on what's happening and what state you're in:
Press play and
solid green = you're playing music
flashing green = you're in pause mode
Press and hold play and
green-orange-orange-orange = you've disabled your buttons
orange-green-green-green = you've reenabled your buttons
That's bound to be one where people panic and fear that they've broken their shuffles, I bet. If your buttons aren't working at all on your Apple iPod Shuffle 2nd Gen, then press and hold your Play button to see what light sequence you're given. This is also shown by the Shuffle flashing orange when you push a button too.
If your player flashes alternating green and orange, you have no music in the shuffle. This can be because it's fresh out of the box, or because, well, something's happened and the music has vanished. Either way, time to sync with your iTunes library.
If you're seeing a flashing red sequence, you're just about out of battery and just need to plug it in so it can charge up.
Finally, Apple has some good tech notes on the new Shuffle too that you might want to check out if you're still a bit baffled by this tiny engineering wonder: Understanding status light behavior, Shuffle Second Gen, Frequently Asked Questions and iPod Shuffle Support Overview.
Feb 17, 2011 | Apple iPod shuffle Second Gen. Silver (1...
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
I can't turn on my MP160. only alarm light is on, what can I do to switch it on? and why is this happening? thanks!
Hi
Also if you are using the Refillable ink cartilages stop they always cause major issues
1 With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Apr 10, 2010 | Canon PIXMA MP160 All-In-One Printer
Many issues, ie, Everything is flashing!
Hi there
yOU CAN ONLY TRY.
not know if it will work so you go to come back to let us know pleas.
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
button pressing
Mar 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My printer is an i550. The on button is flashing orange/green.What would be causing this. I cannot print.
Hi there ok try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Feb 04, 2010 | Canon BubbleJet i550 InkJet Printer
OPTICOM BT28VM BLUEETOOTH HEADSET
I have this one and it works in a different way so this may help everyone struggling.
1. Turn off the earpiece if it isn't already on
2. Press and hold the power key - when it comes on in about 5 seconds, keep pressing the button
3. About 3 seconds later, the light should change from a steady pulse to a solid light, you can then release your by-now-sore finger
4. Start searching for the device on your mobile (or other device)
5. Pair it when found (if this doesn't happen automatically) and enter the passcode 0000 when prompted.
6. All done
Hope this helps those struggling with Rob's solution,
Geoff
Feb 22, 2008 | Lands Phones
Sony Playstation 3 (PS3) Console Logo
71 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
