Question about HP Pavilion F1703 17" LCD Monitor
My monitor is cycling on for about 1 second and off for approx. 30 seconds?
  • 11,361 Answers
Look for codle solder joints on the four round inductors, bad caps (purple casing for bulging bottom seals, bad transistors.
http://s807.photobucket.com/albums/yy352/budm/HP F1703/
Posted on Oct 03, 2010
  • 732 Answers
Tom lundin, If pc is known to be ok, then go here and do some reading: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ After you research problem then and only then come back here and rate this response on fixya as to it's merit. You should also do some reading in the FIXYA PROFILES of "budmrtn" "buddymc" "12fixlouie" and other CCFL lcd monitor techs for more info.
By for now. 12fixlouie
Posted on Oct 01, 2010
Can't get online
Try power cycling the router:
1. unplug the power cord from the router
2. unplug the power cord from the modem
3. replug the power cord to the modem
4. replug the power cord to the router
for best results, wait approx. 30 seconds before re powering the devices.
Mar 03, 2011 | Computers & Internet
I am in need of some advise. I have a pellet stove and need to replace an obselete part, I am wondering what would be the best delay relay timer to use, it will operate an 6rpm/150lb torque auger that goes...
1) Pex supply sell the E502 OFF delay Paragon product: Timing cycle begins when switch is activated, and shuts down at end of timing cycle. 5 seconds to 3 hours
http://www.pexsupply.com/Paragon-E502-Electronic-Off-Delay-Timer-5-sec-to-3-Hrs
http://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hb
See manuals for Paragon product:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#percentage
2) Tork ACT120 cycle timer (minimum ON is 30 seconds)
http://www.grainger.com/Grainger/TORK-Adjustable-Cycle-Timer-4JNH8?Pid=search
http://www.nsi-sales.com/act_series.htm
See ACT manuals:
http://waterheatertimer.org/Tork-timers-and-manuals.html#cycle
3) Intermatic CT1000 cycle timer: cycle durations of 30 seconds to 30 minutes, with on-off durations from 1 minute to 29 minutes.
Click model number to access manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/percentage%20cycle%20timers.aspx
Drillspot sells indoor/outdoor 120V or 240V CT1000
http://www.drillspot.com/products/1325934/Cycle_Timer_CT1000_Cycle_Timer?s=1
4) Do a google search for 'electronic cycle timer' or 'percentage timer'
5) Timers listed above can be wired to a contactor (or relay) that turns on auger, if that's what project calls for.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Dayton off-delay timers require push-button operation
Feb 03, 2011 | Amperite Dayton Solid State Timer On Delay...
When i turn the computer on the power light turns on but dont hear ne thing powering up and the monitor screen stays blue
remove the power cord and hold the on button for approx. 30 seconds- 1 min., connect it, then turn it on. This is a little tech trick... see if it works.
Feb 02, 2011 | eMachines Desktop / Intel Celeron...
IBM L190 LCD - the LED beside the power button corner cycles green for 1 second, off for 1 second as soon as it is plugged in. The unit won't power up, the LED just cycles green/off whenever it is plugged...
It's clear the problem is the display, but you can still try these 1. unplug and replug while the both is on 2. turn on, off couple of times 3. keep the LCD on for about one hour these are anyway temporary fixes :(
Jan 30, 2011 | IBM ThinkVision L190 19" LCD Monitor
I have a model LDG712 gas dryer. The flame ignites and burns for about 20 seconds. The flame then stops burning and it about 1 minute and 30 seconds or more before it lights again. The glow bar...
The flame should cycle on for about 50 seconds on the first cycle and approx 20 sec each additional cycle. I would check your airflow out of the dryer it my be restricted not allowing the flame to pull through the burner tube causing the unit to "short cycle". Its not likely a thermostat issue but if you were to replace a thermostat I would replace the cycling thermostat should be part number 3387134. Hope this helps.
_MJ_
Dec 15, 2010 | Maytag Dryers
Kdfwe42655 Sony Picture on approx 45 seconds;
http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=19 <try this and good luck! let me know if it helps...
Jun 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Monitor goes black for a few seconds
Try swapping the monitor cable from the working monitor to the other video connection on your computer. Effectively reversing the connections to isolate whether your problem is the video card in your computer or the monitor itself. If you find the working monitor displaying similar symptoms, then check your video drivers and ensure that you have all power saving features, screen savers, etc... turned off.
Apr 06, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
LCD Screen problem
You have a failed inverter circuit. This is a very common fault with BenQ and other LCD monitors. I have seen more FP737 and FP731's and all their cousins in the last 2 years then I care to count.
You will be best to take it to a TV technician and have them do the repair. There are ways to fix it yourself, but the chances of success are not great without a decent amount of electronic knowledge.
Call several places and get approx quotes based on the inverter fault. A lot of TV techs will not work on LCD monitors and is another good reason to call around first.
One final thing, check the manufacture date on the back of the monitor, these normally come with a 3 year warranty and it will be either expired now, or very close to it. If it is still under warranty, then contact BenQ near you to facilitate the repairs.
BenQ support webpage.
Apr 15, 2008 | BenQ FP731 17" LCD Monitor
Works for three seconds at a time
Its becoz there is no signal from your PC. Check the input of LCD monitor i think there might be problem with that cable! ?Mostly the cable gets weired in long run. so check thoroughly! It might work. Or else you have to repair the LCD!
Dec 22, 2007 | Dell E173FP 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
50 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
