Question about SmartDisk NetDisk (END160) 160 GB Hard Drive
Ximeta ndas not connecting
Having trouble connecting new ximeta netdisk ndas drive enclosure to ethernet and wireless network. A red square in the management tool is indicating the drive is disconnected. Am using a D-LINK DSL-G604T WIRELESS ADSL ROUTER + 4 PORT SWITCH 54MBPS 802.11G.
Apprietiate any help thanks
  • Grantz Jun 01, 2008
    Thanks Shanat but I have already tried the driver download
    Doesn't seem to be a problem with fire wall or antivirus as status of ndas still the same with them all off
    Sergeant:
    Champion:
  • 359 Answers
try this site it may help
www.ximeta.com/web/support/download/windows_xp/drivers/v3x/index.php - 28k -
Posted on May 26, 2008
  • 19,396 Answers
Check the cables first, try a different one
  • Ginko
    Ginko May 26, 2008
    Once you are sure cables are ok, do the following.
    connect the disk to computer, using only the switch to build a mini network: PC-->switch-->Netdisk.
    See if the disk does connect in this way, if it does not search for a firewall installed on your PC (there should be at least Windows one), and set DIsk IP as an exception in firewall (allow all traffic) or disable firewall at all (better to configure than disable).
    Once the disk works on the mini network with the switch, attach the router to the switch to get internet.
    If you instead decide to connect the disk to the router instead, remember that router has an internal firewall, you may need to set up router firewall to have disk working in this case.
    To find out if disk is connected you can use ping command from command prompt.
    To find out IPs of network devices you can use 'ipconfig/all' from command prompt.
    To start command prompt go to start button, then run, then write CMD in run box.
  • Ginko
    Ginko Jun 01, 2008
    The router has his own internal firewall, test the disk with the switch, to find out if it can connect.
    Once you build a small network with switch connected to computer and and Ximeta do the following:
    go to command prompt (run from start menu and type in cmd).
    on command prompt type ipconfig/all, so that you can find out disk IP, or if you know your disk IP already do Ping.
    If you can Ping the disk and software still does not see it then it is a software problem.
    More likely you will have to reconfigure your network bypassing router or add disk IP in exceptions on router firewall.
    If you do not pass through this steps there is no way to troubleshoot a network device problem, no use to me knowing that you deactivated antivirus or Windows firewall.
    Regards
Win 7 64 bit freeze when starting XiMeta's NDAS NetDisk. I'm using newest version 3.72 from Ximeta website.
I have the same problem. I don't have the right solution but I discovered a workaround.
The problem occurs everytime when I install a windows 7 update.
My work around:
  1. When Windows determines an update I disable the NDAS service with msconfig
  2. The update is installed without the NDAS service operational.
  3. After update I enable the NDAS service with msconfig
  4. I restart my computer. Then it freezes.
  5. After a hard reset, the computer restarts in Safe modus. I restart my computer and my computer works, till the next windows 7 update. Then I start again van 1.
Very suboptimal, but it works.
Anton
Jul 08, 2011 | Ximeta (NDU10200CU)
Can't list files Listing under MyComputer says drive is not formated but I know I have files on there from previous use so I should be able to see a list of them Using an Ximeta NetDisk NDAS external 80GB...
Try to Run scandisk to repair the drive. Also check for virus in your computer due to which you are facing this issue. Clean the virus from any antivirus tool with latest virus defination will solve your problem.
Dec 15, 2009 | Ximeta NDU10-80 80 GB Hard Drive
Need a power cord
Hi Tatearian,
Ximeta, like many external drive manufacturers use a fairly custom AC adapter. Finding a replacement is not only difficult but often costs more than the enclosures are worth.
The simplest and cheapest thing to do is go to your local PC shop, ask the technicians there to remove the hard drive from the enclosure and put it in a new one. This won't cost any more than buying a replacement adapter and will be much simpler to do.
Hope this helps FixYa,
Chris
Sep 11, 2009 | Ximeta Technology NDU10-160 NetDisk 160MB...
Can usb substitute for the ethernet connection?
Perhaps buy one on eBay (possibly $60) and pull it's interface circuit board, to replace your bad one:
http://search.ebay.com/netdisk
Apr 10, 2008 | Ximeta NetDisk (NOWWL) 160 GB Hard Drive
NDAS is the utility
ahh..I see..so what precisely is your situation, and what's your questions?
Mar 26, 2008 | Ximeta NDU10-80 80 GB Hard Drive
NetDisk NDAS 80 GB.. SINGLE CLICK THEN I/O ERROR
can you boot from a cd..that may be the only way you'll get it back in the zone
XiMeta's NDAS NetDisk and Windows Vista Blue Screen
Take a look at this: http://www.ximeta.com/forum/viewtopic.php?t=13. The patch from Microsoft worked for me.
Feb 20, 2008 | Ximeta (NDU10200CU)
SmartDisk NetDisk (END160) 160 GB Hard Drive Logo
1,072 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
