Question about Car Audio & Video
I NEED TO KNOW THE NUMBER IC PREAMPLIFIER BLAUPUNKT CCP08
My blaupunkt car stereo mutes itself, so the sound is on and off
your promblem arrise at amplifier section...there are thermal runway ....time to change ic amplifier....and coupling ,gain capacitor....
Mar 27, 2012 | Blaupunkt IDC-A09 5-Disc CD Changer
Need 4 digit code for a aftermarket blaupunkt radio with warranty number B692400168 serial number 69001114. It is a SCR 475 cassette player.
This is an older Blaupunkt with a different type of Security Code system.
Try here for free further advice and code ....CLICK HERE
Apr 21, 2011 | Blaupunkt Santa Cruz CD31 CD Player
On sound
Check on the audio panel ouput IC for the main voltage . If absend checck the fusible resisitor/ regulator in the main board. Check on the speakers .If the out put is working then you will need to trace to the preamplifier and the SIF- sound intermediate frequency section. The IC can be faulty. However is you can use a signal tracer or an audio signal injector it will be easy to investigate.Hope you try. Good day
Aug 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Need the code for Blaupunkt IDC A09
Ask here for free advice and code
www.ukbookshelf.co.uk
Jun 12, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
GLI PRO preamplifier fuses burn
You shorted the main semicondutors and they have now got a short on them, so they are acting just like a piece of wire and drawing too much power so the fuses blow. You need to replace whatever is on the main heatsink. Did both channel wires make contact or just one? If only say the right did you might only need to replace the right side parts, unless it is an IC doing all the work!
Jan 20, 2010 | Audio Players & Recorders
I have stereo preamplifier and a tuner and
What you need is a power amp.Now if you have rca jacks for the preamp ouput you can use any power amp that has that type of connectors for input.Just try to match it with the power handling capabilities of your speakers, it should be written at the back of it along with the impedance(4 to 8 ohms standard)
Nov 01, 2009 | Audio Players & Recorders
AdcomGTP500ii Bad IC cross-reference
Contact ADCOM thru their website
Theyre very helpful
Jul 26, 2009 | Adcom GTP602 2-Channel Amplifier
I need a code for my BLAUPUNKT Radio serial no BP2015R7563321 which came with Rover 623
There is no info on the internet for the unlock. But, I do know if you contact blaupunkt and give them the serial number, they will unlock it for free.
Apr 30, 2009 | Audio Players & Recorders
I changed my battery and now my Blaupunkt Nashville CM40 ask me for a code. How do I get it?
To get this, you will need the code # that was on the card that came with the radio. It should be with your owner's manual or in the glove box. If you no longer have this card, I would visit a local Blaupunkt car stereo dealer. They may need the serial number from your radio and have to call the manufacturer to obtain the radio code using this #. You can get this serial number yourself by pulling the radio or sliding it out yourself. You may be able to contact Blaupunkt customer service (www.blaupunkt.com) to get a dealer listing or to call a toll-free customer support number. I hope this information was helpful.
Sep 28, 2008 | Blaupunkt Car Audio & Video
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
