Question about Home
Toilet does not flush. Handle is floppy, does not remain upright anymore
  • 21 Answers
Go to HD supply on line they have a wide variety of handels from generic to name brand to match your tank ,Dont skimp on quality purchase same model . Take my word for it and make sure it fits nice in square hole in tank arm should be aluminum or brass crome plate dont last under water very long and plastic well you get what you pay for.
Posted on Nov 06, 2010
Testimonial: "Thanks!"
Why won't my jacuzzi toilet flush
You just check the chain inside the water closet where the one end is connected into the flush handle,and the other end is connected to the flush valve (it is the rubber cap which is covering the outlet of the water passing into the toilet bowl itsef)..most common problem is the chain is cut,or sometimes it is just need to udjust shorter thats why it can tug the flush valve when you pull the flush handle.
Sep 12, 2014 | Home
Flapper valve closes too quickly
Fill the breather hole (1/8" hole) inside the flapper.This is designed to let air out so the flapper will sink. Now it floats longer letting in more water. 25%percent more in my case.
Apr 22, 2012 | Home
It will not flush properly .rudy
How to Troubleshoot a Flushometer
A flushometer consists of a metal pipe extending from the back of a toilet with a slender handle on the side that is used to flush a toilet. This type of flush valve is commonly used for toilets in commercial facilities to provide a durable and accurate flush delivery system. If the flushometer does not work properly, troubleshoot it and perform minor repairs. Common issues are often resolved quickly. If troubleshooting does not correct the problem, call a plumber for repairs.
Does Not Flush
1 Inspect the handle assembly. A broken handle or assembly will prevent flushing. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it with a handle repair kit
2 Open the main water supply valve to turn the water on fully. The water supply is normally turned on, but check to make sure it is turned on fully and has not been turned off inadvertently
3 Remove the flushometer's CP cover, the round cap on the very top of the pipe extending from the toilet. Then remove the inside cover directly underneath the cap. Inspect the relief valve. Replace it if it is visibly damaged.
Short Flush
1 Remove the CP cover and inside cover. The CP cover is located on the very top of the pipe extending from the back of the toilet. The inside cover is underneath the CP cover and the diaphragm assembly is located beneath the inside cover. Remove and inspect the diaphragm assembly. A damaged diaphragm assembly can cause a short and incomplete flush. Replace it if it is visibly damaged.
2 Replace or repair the handle assembly. A damaged handle can result in a short flush. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it using a handle repair kit.
3 Remove the CP cover and inside cover to remove the diaphragm assembly. If a low consumption diaphragm is installed on a water-saver fixture or a urinal diaphragm is installed on a toilet fixture, replace it with an appropriate diaphragm.
Mar 04, 2011 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Flush valve closes before toilet flushes completely?
lift off cover and adjust =shorten length= between flapper and handle lever
Apr 26, 2010 | American Standard Colony 2388.012.222...
Tilet want flush no pressure when depressing
Take off the top lid and look at the flush handle mechanism. You'll see a not that holds it onto the tank. Tighten the nut so it is snug. Don't overtighten it or you could crack the tank. Next inspect the chain that goes between the end of the flush handle rod and the flapper valve. It should lift the flapper all the the way up when you operate the handle.
Apr 11, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
Basement toilet won't flush. water fills the bowl and tank fills back up...but toilet doesn't flush
Check your flapper line to the flush handle. The flapper is in the tank on bottom. There shoiuld be a plastic line to handle or chain. :)
Sep 07, 2009 | Home
Toto toilet ultra max flush
Open the tank and examine the linkages between the handle and the flapper. If the handle is sticking, it sounds like there may be either mineral buildup or a stuck chain.
May 27, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Toilet flushing
you either have the wrong flapper or it is not adjusted right try moving the chain to shorter or longer lenght the other thing to check is that your handle is not loose if you have to tighten handle be careful it is a reversed thread also check water level in tank
Apr 07, 2009 | American Standard Cadet 3 Right Height...
Home Logo
200 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
