Sony KDL-46S504 Need help with signal being out when try to play Ps3/Xbox360 Need to know how I can program it correctly.
  • 7 more comments
  • donscott1972 Oct 01, 2010
    Yes I'm using HDMI for gaming directly into the Tv from the games. They Tv works also.
    Yes I'm using HDMI for gaming directly into the Tv from the games. The Tv works also.
    Lately everytime I turn it on its says the signal is out. :-(
    Yes I am
    I use digital cable and HDMI conn for the games I have two cables.
    I did that. When the Ps3 works every things good until I select play game. Then its saids signal lost. Also if I use xbox 360 on the other port it works. I have both of them plugged in at the same time. I use only 1 at a time. Mostly Ps3
    Yes i've tried all ports. I will try to test it on another Tv. I hope thats the solution. Ps3 is much cheaper than a new TV LOL.
    I think the Ps3 is broken tried it on a different set :-(
    President:
  • 2,777 Answers
There is no programming necessary, you should be able to switch to that input and display what is on that input. Do all other inputs work, such as TV or a regular DVD player? Are you using HDMI for the gaming consoles? Directly into the TV?
Thanks
Tim
Posted on Oct 01, 2010
  • 2 more comments
  • Tim Grayson
    Tim Grayson Oct 01, 2010
    I see, it looks like it may be something wrong with the TV for sure... I am guessing you are not using HDMI for your TV connection? PLease confirm and I will know the issue here..
    Tim
  • Tim Grayson
    Ok well that's good news then, try plugging the xbox 360 into the port that the TV signal is currently using. If anything you may need to turn off the TV and turn it back on to get it to recgonize the signal.
    It should definitely display something in there, since it's currently displaying TV...
    Tim
  • Tim Grayson
    Strange, that almost sounds like a PS3 problem itself. It displays and everything works until you go to launch the game? And you have tried the PS3 in multiple HDMI ports to verify? Do you have another TV you can attach the PS3 to and see if it works there?
    Tim
  • Tim Grayson
    Sounds good, let me know!
    Tim
WHEN I TRY TO POWER ON THE LCD ONLY CLICKS AND TURN A GREEN LIGHT ON THE POWER SLOT,?ITS THE IP2 POWER SUPPLY BOARD OR THE BM3 MAIN BOARD? WICH ONE ,BE SPECIFIC.SONY KDL 46S504 LCD BRAVIA
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 06, 2016 | Televison & Video
I try and play dvd's in my playstation 3, and within about 5 seconds, it says 'loss of signal' i sent if back but they found no problem with it... yet the problem of not playing movies has not been fixed.
simple solution if you are using hdmi the tv must be on first and to the correct input then turn on the ps3 . also you may have a bad hdmi cable. try using a differnet connection to your tv. let me know asap if that works i have swome more solutions.
Mar 16, 2011 | Sony Playstation 3 (PS3) Console
No signal through hdmi ports
Check the hdmi cables be sure their in proper working condition, wiggle the cables around see if picture comes up. If not and the cables are good then the hdmi processor on the main board of your TV is defective. Alot of times hdmi ports tend to burn so see if you smell a burnt smell near or around the hdmi ports. but before you do anything be sure sure your TV settings are correct for hdmi....
Oct 18, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a sony bravia kdl-52v5100 the picture looks like a regular tv, I have digital hd signal (direct tv and ps3) they are connected thru hdmi 1.4 but I not happy with the image, how can I get a full...
Hi...
The manual will give you step-by-step help in getting the correct video mode for HD signals
If you dont have a manual , check the Sony Consumer website and download one
Oct 12, 2010 | Sony KDL52V5100 52 in. LCD HDTV
I cannot get a major tv channel on my new Sony Bravia KDL=46S504. I am thinking of returning it to Best Buy because I bought the tv so I could watch a football game on New Years day,
have you run setup in the cable mode digital ? if not you need to and that should solve your issue if not you could call sony support and they will walk you through it
Dec 17, 2009 | Televison & Video
My ps3 would connect to the internet
Try connecting to your router with a cable and see if that is able to get you online.
If it does, then 9/10 its a signal problem.
If it doesn't, then you have a settings problem.
Also, is your router close enough to the ps3 to supply sufficient signal to the console? From my experience, the router needs to be pretty close to the ps3 for it to get a good signal or if you have a wireless N type router. Wireless b/g routers usually need to be very close to their source for it to be fully effective as the ps3 requires.
Apr 16, 2009 | Sony Playstation 3 (PS3) Console
Sony bravia won''t play PS3
Try setting the resolution to a higher grade or a lower grade.. That solved the problem for me.. good luck!
Nov 24, 2008 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Cant acess ps3 Xbar menu,still plays games
it sounds like you haven't set the display settings correctly. turn off your ps3 and try using the red,white,yellow cables (make sure everything is plugged in correctly). if you get a signal, then change the display settings to whatever connection you will use.
hope that helps
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
