Question about Encon Industries 78008 Art Metro Antique brass Ceiling Fan
Enron ceiling fan wiring for 3 speed fan whitein 1 others out and don't know
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Sep 16, 2011 | Speed Ceiling Fan 3-speed Switch By...
I have a westinghuse fan with light it has four wires on it green, blue, black, and red what are they ie live neutral etc
Question posted under 3-speed switch
1) Are you replacing the 3-speed switch?
This is a field with much discussion because Westinghouse 4-wire fan switches vary.
Process of elimination is needed to find hot line. From there you test each wire to the hot line wire to determine which wire or combination of wires makes up low, medium, and high speed.
Open following links for some resources:
http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php
http://www.atlantalightbulbs.com/ecart/catalog/westinghouse-6.html
2) Or are you looking at fan connection wiring at ceiling?
Green wire goes to bare ground.
Fan should have hot and neutral.
Hot line should be black.
Neutral should be white.
Red usually goes to light
Blue is normally not there.
Where is the white neutral wire?
Take multimeter set to read ohms and test black wire to each other wire.
Process of elimination should reveal correct wiring.
Aug 21, 2011 | Speed Ceiling Fan 3-speed Switch By...
I REPLACE SWITCH 77075 now IT HAS ONE SPEED IDID ONE WIRE AT TIME WHAT IS THE PROBLEM
I don't know your specific fan or switch.
Following link is TYPICAL illustration of 3-wire fan switch wiring:
http://waterheatertimer.org/images/Fan-motor-1-500.jpg
Three way switch is designed to match TYPICAL fan motor windings.
Motor windings are insulated copper wire wrapped around metal fan housing, similar to electromagnet you can make by wrapping wire around a nail.
Inside the fan motor are two windings.
Winding 1 for low speed.
Winding 2 for medium speed.
And when both windings are combined, that makes high speed.
You have to test your switch.
Usually the hot lead connects to red. So the red connects to each of the other wires.
Then pull the chain and use continuity tester between red wire and other wires to see how the switch is set up.
Jun 27, 2011 | Westinghouse Electric Westinghouse...
Replacing 3 speed 4 wire ceiling fan switch did not take note on what color wire goes L 1 2 3 wires colors are black grey brown and yellow need help to fix fan
Copy following link for 3-speed fan wiring:
Apr 27, 2011 | Solar Fan Impressions 3 Speed/4 Wire...
I have a 3 speed fan switch that i am replacing, b...
Hello. I really hope the 2nd grey is simply a faded purple or green. The most common configurations would be: L - Black, 1 - Grey, 2 - Brown, 3 - Purple or green. Here's a link to some troubleshooting advice: http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php and a link to diagrams: http://www.hurontel.on.ca/~taitg/pages/cfan.html
Hope these help clear up that nasty faded color for you, and don
May 21, 2010 | Speed Ceiling Fan 3-speed Switch By...
Ceiling fan capacitor hook up problem. I have a 3 speed fan. 4 switch. A 3 wire capacitor - CBB61. Kids lost wiring diagram. Any which way I try to wire it up only one of the speeds works. Any wiring...
The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
May 15, 2010 | Dryers
I don't know witch wires go where?
Hello. The most common configuration is: L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
Hope this helps, and don
Apr 15, 2010 | Speed Ceiling Fan 3-speed Switch By...
Encon Industries 78008 Art Metro Antique brass Ceiling Fan Logo
69 people viewed this question
Top Encon Industries Dryers Experts
Are you an Encon Industries Dryer Expert? Answer questions, earn points and help others
