Question about LG 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Titanium
My fridge is only 3 years old. the freezer side is working great. The fridge side has stopped working. There is a small grid at the bottom ,i took it off to see if a possible filter was gummed up. it is not . it is clean under there. really no filter that i could see any way. Could the filter be in the back? what else could it be?
    Brigadier General:
  • 3,513 Answers
Check the back wall or floor of the freezer section for frost. Check the freezer/ evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with doors wide open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 01, 2010
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
We have a Frigidaire FRS202RG side by side fridge/freezer that is about 9 years old. In the last 3 months, it has begun frosting up in the bottom of the freezer with ice forming over the vents at the back....
Sounds like the fan behind the rear freezer panel has stopped working,therefore no air flow over evaporator coils causing ice built up and no cooling on refrigerator side. easy fix
Nov 30, 2010 | Frigidaire FRS26ZSG
Hotpoint fridge freezer ffa60 frost free bottom freezer has stopped working top fridge is ok 6 years old help!
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | Hotpoint HSS25GFP Side by Side...
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Jan 02, 2009 | Zanussi ZI921 / 8FF Bottom Freezer...
Amana bottom drawer fridge/freezer combo is only 3 years old. It sounds like it is trying to work but both the fridge and freezer are not working. Not cooling or freezing anymore.
hi. thanks for the question . it sounds like you have a compressor problem . wich is under warranty from amana. great news get in touch with amana thanks the appliance doc
Sep 28, 2008 | Amana Refrigerators
Fridge side not cold-freezer great
there is a three prong replay that hooks up to your compressor sounds like it needs to be replaced
Sep 01, 2008 | Refrigerators
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
LG 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Titanium Logo
67 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
