Question about Frigidaire ATF6000ES Front Load Washer
Hi, The Rubber Boot came wrapped into a pair of jeans. I tried attaching it back but I cant remember how it goes on and when I tried it leaks and comes undone. hehe. I read the other post about putting on a completely new one but I keep getting lost. help please please
  • Frigidaire Master
  • 8,220 Answers
I have a link to some training videos.
User: service ----Password: tips
After you gain entry choose "training videos" then "laundry" then "washers"
and choose your gasket replacement video.
These are some nice videos.
Click HERE
Posted on Oct 01, 2010
New Danze D308340 faucet leaking under handle. Can't remove the capto get to retainer screw, which needs tightening.
is the capp colored red/blue? if yes, take a picky pointy knife (lmao) and peel it off,pick it off,The leak is probable just the adjustment under the handle, the fawcet originaly came with a tiny spud wrench (made like a 2 pick pitch fork, if you cant find one, i use a pair of channel locks pliers, but first wrap rubber glove or cloth around the top of fawcet so you dont scratch it.How old is this fawcet?
Nov 12, 2011 | Plumbing
After having the fuel filter changed, the service engine soon light came one. P0171 is the code. Any ideas? I found one vacuum leak, the rubber boot that goes attaches to the same point where the power...
try cleaning the MAF sensor the cleaner can be purchased at autozone or another store like it on about eight dollars and take just a few minutes hope this helps
Apr 06, 2011 | 1999 Pontiac Grand Prix
How do i stop my mr. heater from leaking fuel @ the drain plug? I have put a new drain plug in with rubber oring but it doesnt solve my problem.
Hi, try wrapping some plumbers tape around the threads, use about 4 to 5 wraps. This will stop the leak. Wrap the white tape the same direction the threads go, or the tape will come right off when you tighten it. You will no when you try it.If the fitting screws in cw, wrap the tape on the fitting ccw.
Shastalaker7
Mar 28, 2011 | Mr. Heater MH125KT Utility
I have LG WD -1050F Intellowasher 7kg front load washer, while operating time getting water leakage under front door. need solution.
The problem is due to the rubber boot is been torn that is causing you the leak. You have to check the rubber boot for leaks by removing the clamp assembly that secures the rubber boot to the outer lip of the door opening. Peel off the rubber boot then inspect it for any holes where it may be leaking. The rubber boot in your washer can be accessed only when you remove the front panel. This requires the removal first of the top panel then the console. Also check your inlet hoses on the outside of machine, also check the connections inside the panel in back.
Thank you !!
Jul 26, 2010 | LG Washing Machines
Leaking water from the front
Thank you !!
Jul 06, 2010 | LG WM-2277HW Front Load Washer
Leaking water from my lg front loader during washing cycle- wm2487hrm
Thank you !!
Jun 13, 2010 | LG WM-2277HW Front Load Washer
How do you replace a headlight bulb to a 2005 Mazda 3? Manual says you must bring it do the dealer. Is that really necessary?
First of all, the bulb you will need is probably going to be H-7. Just go to the auto parts store and find the bulb that says H-7 on it. Apparently you're not supposed to replace just one bulb. You should replace them both at the same time, so buy two bulbs ($27.00). Also, I needed a Flathead screwdriver and a pair of latex gloves. Don't try to do this at nighttime. You will need plenty of light.
If you're replacing the driver's side light, you'll have to remove a plastic shield from above the light. Not a big deal. Use a Philips head screwdriver and a pair of pliers (gently!). Remove the black plug that goes into the back of the bulb by squeezing the sides and pulling. Then remove the black rubber boot that goes over it. The Flathead screwdriver was helpful getting the boot off.
When removing the silver clip that holds the bulb in, you'll have to push in on the side of the clip closer to the driver's side of the car. (Please note that it is not necessary to unscrew any screws.) It swivels open like a door.
Next, remove the bulb. The bulb is attached to a black adapter thing. Use the Flathead screwdriver to pry that black thing off the bulb. Throw the old bulb in the garbage. Put your latex gloves on and put the new bulb into the black adapter thing. (Remember not to touch the glass part of the bulb with your fingers. It's not good for the bulb and you will decrease its lifespan.)
Put the bulb with the black adapter thing into the headlight. You may have to fiddle with it a little bit. (You're still wearing your latex gloves, right?) It only goes one way. There's a little notch that fits into the ten o'clock position. (Just rotate the bulb in the headlight. You'll see where it fits in.)
Close the silver clip back over the bulb. This part may be challenging. Remember, the bulb should have no wiggle to it when the silver clip is installed correctly. The end of the clip fits deep inside the headlight. Push it in and try and find where it clips in. It might be hard to do. Don't get frustrated- you're almost done.
Put the rubber boot back on. It has to be tight to protect the bulb from water. Then plug in the bulb. Replace the black plastic shield over the driver's side light. Finally, test the light.
Replacing both headlights took me about 60 - 90 minutes.
Dec 08, 2009 | 2005 Mazda 6
Lost Engaement ring in Washer
Non infield involvement rings are now pretty fashionable and a lot of women are point to realize their beauty. Amidst the knowingness of umpteen, non tract work rings were also the praise during the ancient and mediaeval nowadays. In fact, many gems are advised solon momentous than the diamonds. Emeralds for one were valued by ancient Moguls, business it their unspeakable designer. Rubies are also really rarified and are, until now, considered vocalist of all gems because of its unmated title and unrivaled exemplar.
Non Diamond Engagement Rings
Aug 17, 2009 | Frigidaire GLTF2940ES Front Load Washer
I have a 2004 Jeep Grand Cherokee limited edition and the drivers door control panel doesnt work at all(power windows, locks,mirrors) The controls on the other doors for the windows dont work either but...
I had same problem it is a ground wire broken in the harness rubber boot between dthe driver door. Peel back the rubber that protects wires and you will find broken ground wire(black) add a piece of wire solder and wrap with electrical tape put rubber boot back into door everything should work.
Mar 15, 2009 | 2004 Jeep Grand Cherokee
Sounds like a loose screw/bolt/nut during the spin cycle
There is nothing wrong with your machine. Don'f bother with the sound , You said you threw 2 pair of jeans, so its bottons are causing the sound against the drum during cycle. Finished your laundry and worry no more. To make sure, throw some another clothing asides form jeans, like shirts, and feel the normal silent of your machine.
Good Luck,
Eriez
Jun 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
