Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
How easy is it to replace the T-CON board in this model?
    President:
  • 2,777 Answers
I would say pretty easy, there is no soldering or anything required. If you know enough to know about a T-CON board and can locate it, then I'd say you can handle replacing it for sure.
Thanks
Tim
Posted on Oct 01, 2010
The answer to my question was to replace the T-Con Board. Looking at Shop Jimmy the only board for this model is BN44-00801E Power Supply/LED Driver Board. Is the T-Con board embedded in this board?
The T-Con board is embedded in the main board and not in the power supply/LED Driver board.
The Main board part number should be BN94-09124C but I would suggest to do more research or call Samsung for more info.
Sep 18, 2017 | Samsung Televison & Video
How to replace t-con board
Hi Joyce,
There are plenty of videos on YouTube showing how to replace the TCon board. It will be easy to do the job after watching these videos.
Good Luck
May 02, 2016 | Samsung Televison & Video
I have a 50" element tv. Model # ELEFT502 The picture went black but sound still works. when u take a flashlight to it u can still see the picture. Easy fix??? Also where/how much would the part be?!
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Jan 11, 2016 | Element Televison & Video
Jimmy shop.ccom has T-con board part #T500HVD0.0 500t10-C02 at the bottom in the description it list model PLDED5030A CRk my model is PLDED5066A-E since the parts # the same will it work in my tv?
If you see an image with a flashlight the T con board and power supply board are good. The back light controller board is the culprit.
Dec 18, 2015 | Televison & Video
I have a Samsung TV model UN50H6350AFXZA which has sound but no picture. Backlights work. Replaced t-con board with new one, but not fixed. What next?
Main board. T con board is only involved with video issues. Main board goes both ways and since you already replaced the T con board that is your only alternative. U got backlite so inverter board is good.
Nov 13, 2015 | Samsung Televison & Video
The color is pink and green and blurred
either t con board or the lcd panel is faulty. Only can confirm which on by replacing the t con board.normally the t con board is a separate board in almost all the tvs. in some models its integrated to the panel , if so you have to go fora new panel.
check the links bellow to know more about t con faults .
http://electro-medical.blogspot.in/2015/11/lcd-tv-t-con-board-troubleshooting.html
Nov 11, 2015 | Coby Televison & Video
Vertical colored lines on entire screen, sound ok
Hi.
Probably the t con board of your TV is faulty. T con board is the one which drive the lcd pixels. You have to replace the T con board to get it work properly.
Here i have added the picture of the T con board of your tv for reference.also added the video to know how to replace the T con broad.
RCA L32WD22 T-CON BOARD UT-5531T03088-76J
Samsung TV Repair How to Replace Con Board in LJ94 02 705E Model How to...
www.electro-medical.blogspot.com
Sep 09, 2015 | RCA L32WD22 32 in. LCD HDTV
Polaroid 3211-TLXB solarized / negative image
Just replace the T-Con board and you dont need any soldering at all. JUst be careful for the flex connector.
Jan 19, 2015 | Polaroid 3211TLXB 32 in. LCD Television
Sound with no picture
More than likely it is the T-CON board that went bad in your television set. Fairly easy to replace yourself you can buy online on ebay. Search T.V. model # followed by T-CON and one should be available. There are many youtube videos on how to replace step by step. GOODLUCK!
Jan 26, 2013 | Samsung LN-S4692D 46 in. LCD HDTV
Do you know the part number for the t con board.. samsung 32'' model number-LN32A450C1DXZC VERSION-CN03 Is the t con board easy to replace?? Any soldering or desoldering??
It is easy to replace, no soldering require, just have to carefully remove the delicate ribbon cables between the LCD panel and the T-CON, T-con and the main board.
It is mounted under the metal shield.
Please make sure to maych the part number as printed on the board. I look at thsi pleace but the number you have given did not quite match.See;
http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN32A450
What do you see on the screen anyway?
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 04, 2010 | Televison & Video
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
264 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
