Hi just installed a split type fedders system but the red filter light continually flashes and can only start for a few seconds at a time models are outside eifc424n6g-p2 inside ehfe424n6d any suggestions??? thanks in advance
  • ollyboy929 Oct 01, 2010
    hi yes its brand new and hard wired thanks mark
  • ollyboy929 Oct 02, 2010
    hi just installed a split type fedders system but the red filter light continually flashes and can only start for a few seconds at a time models are outside eifc424n6g-p2 inside ehfe424n6d any suggestions??? thanks in advance
  • 10,865 Answers
Hello. Since this unit is brand new, the best advice is to work with the distributor where you got it. This item is under full warranty, and apparentl defective. IF you open it up you will void the warranty. Joe
Posted on Oct 02, 2010
    President:
  • 2,777 Answers
This is a brand new unit? Is the power hard wired in or is it plugged into a socket regularly?
Thanks let me know and I can help
Tim
Posted on Oct 01, 2010
  • Tim Grayson
    Tim Grayson Oct 01, 2010
    It almost sounds like a power fault, the way those lights are blinking indicates some kind of major "failure" of the unit so to speak. Check your wiring, and if it is definitely sound then you will want to immediately return this unit for another one. I have seen this units be "bad" right from the factory.
    Thanks
    Tim
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Jun 18, 2012 | Hitachi Heating & Cooling
Clean filter light on my Fedders model sfpeb08f2b is on. I have cleaned the filter in the back, is there another filter that I am missing? The light will not go off...
I had the same problem, remove the filter and wash with water and some soap, rinse well and dry well.
Place it again and turn the unit on, if the light does not turn off, unplug the unit and wait about 10 seconds, reconnect the unit and should disappear the red light.
This worked for me, hope it works for you ...
Good luck ...
Jul 05, 2011 | Fedders SFPEB08F2B Air Conditioner
Hi, We have a 42" hslc10668phz
generally when you get a constant green light all is ok. these different lights indicate different problems within the tv. so the pattern of lights you mention suggests there is a fault of some kind (is there a troubleshooting section in your manual)? either way it needs to be looked at.
Nov 28, 2010 | Hisense Televison & Video
Problem with reset switch on fedders split unit
This indicates a fault within the unit. Call a service technician and have the system repaired.
I take the time to help you with your problem, so please rate me.
Thankyou Mat
May 18, 2009 | Fedders C36ACD1VF Split System Air...
Red light won't go off
To RESET the Electronic Filter Check:
When the filter check light remains on,it is time to check/clean the HEPA-Type
filters and reset the filter check,if needed. With the unit powered on,insert the tip of a ball-point pen or
paperclip into the hole next to the LED filter check light and hold for approximately 5 seconds until the
light turns off (Fig 5). Depending upon your individual usage (environment and hours used),you may need
to check and clean the filters more or less frequently. If the HEPA-Type filters are cleaned before the filter
check light turns on,the filter check should be reset at the same time.
These cleaning intervals are intended as guidelines only. Performance of any filter media is dependent
upon the concentration of contaminates going through the system. High concentrations of contaminates
such as dust,pet dander and smoking will reduce the useful performance of the filter.
NOTE:The HEPA-Type filters are not washable.
Fig.5
May 24, 2008 | Honeywell HHT-090 Air Purifier
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
