Question about SanDisk Sansa e250 MP3 Player
Batery wont charge. how do you change batteries
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
There are four small screws on the back. Remove those and carefully lift off the back cover. The battery is the biggest thing you'll see inside.
Posted on Oct 01, 2010
Can the internal battery be changed
yes it can be changed, you will find that it runs on a nokia 3310 batery old tech but somehow there was an overflow in the stuff when 3310's was discontinued so they are stuffing these batteries into just about anything
Jul 17, 2014 | Tablets & eReaders
Change or charge battery
Hi, depending on what happens when the batery is fully charged, does it go flat aftera day or two or does it stay charged? If it keeps going flat take it to a battery centre to test the amps that the batery makes. I f the amps is out the battery is dead.
But
If the batery is fine after charged and the amps is correct and the bike still makes the batery flat.
Then you have to replace the Stator and the magnitor.
Dec 09, 2010 | Yamaha YZF-R1 Motorcycles
My samsung rant keeps saying abnormal stae, charging disabled. What do I do?
It is a quick with the charger. Turn the phone off then try charging it. If that doesn't work, change the battery, and with the phone off, charge it.
Sep 11, 2010 | Samsung Rant Cell Phone
Changed batery in my 1997 oldsmobile cutlas and now it wont start
So everything was fine before you changed the battery and then after you installed the new battery the car wont start?
Did you double check that the battery was the correct model for your car?
Did you check that the battery cables and connectors are still in good shape (clean, tight, no signs of damage, fraying, or over-heating).
Did you check that the battery came fully charged?
Check the connections at the battery, starter, and engine block (ground).
May 14, 2010 | 1997 Oldsmobile Cutlass Supreme
Car is noy charging batery
check the wiring from the alternator to the battery there is a fusible link located in the wire to prevent the battery from being overcharged. if the fusible link has blown it will not charge the battery
May 04, 2010 | 1998 Pontiac Sunfire
It wont crank like not getting power
ok sounds like you have a dead battery
1) if turns but slowly:
posible causes:
1.1) old dead batery/
or underchaged battery >check altenator in this case
did you leave your headlights turnt on and drained the battery of its charge?if so get a jump start and then run the car for 30-45 mins to rechagre the battery
if you have at your disposal anothere batery that you know has a good charge
try starting your car with that batery(not using jumper cables) hook it up!
if the slugish turn over is still there
1.2) check your wire conections for corision this means completly disconecting 1 lead at a time (only on one end of that lead)and cleaning them with a wire brush or some sand paper.
(on the battery and the starter also the ground strap conection to the frame.)
2) WONT TURN OVER AT ALL:
posible causes:
2.0) dead battery >try charging it>get a jump start
2.1) blown turnkey igntion fuse
2.2) blow fuse for main har nes wires
2.3) bad starter
2.4) corosion on wire conection (most often the batery terminals)
2.5) starter replaced and hooked up incorectly.
2.6) alram system preventing the turnkey igntion system from getting power
Feb 24, 2010 | 1994 Mazda 626
It says "invalid battery" and wont take a charge
pls try to change the batery bfor invalid battery
Jul 11, 2009 | Motorola Mobility RAZR V3
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
BATTERY CHARGE
you need to change your battery. Most likely the circuit in the battery is no longer functioning properly
Apr 07, 2008 | Acer Aspire 3610 Notebook
ICOM IC-F11
Bad battery, Buy new one on ebay. Carl
May 17, 2007 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
