Question about Car Audio & Video
I have an Eclipse AVX2404 in dash DVD Player that I am installing in an antique vehicle that does not have a wired e-brake. How do I bypass the safety feature so I will be able to actually use the dvd player???? I tried the ground trick and it did not work.
SOURCE: how do i bypass the
if your tryin to get it to play movies will driven all u do is put the pink wire which should be the parking branke wire and connectit with the black ground wire ... i have the same radio and have done this and its worked perfect for me
Posted on Jul 02, 2009
SOURCE: blue screen will not go away
These methods have worked on a variety of Dual DVD systems (mainly XDVD8181, also XDVD710), unsuprisingly, since Dual stated to me that most installations have the same codes. WARNING! It is usually ILLEGAL and most of all UNSAFE to drive while watching video. I only watch video while parked, and I suggest you do the same. This is for demonstration purposes only, if you use these codes, you do so at your own risk. STEP ONE. Ground the E-Brake wire. No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground). 1. FACTORY RESET METHOD (Temporary) (This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.) ** Go to the Menu ** Get to the Settings Menu ** Select to Reset to Factory Settings. Credit: DKA Have recently heard complaints of this method not being permanent, as this is needed everytime they want to watch a DVD. Also, radio and screen angle presets are lost. ---------------- 2. AUDIO CD METHOD (Permanent) ** Insert Audio CD ** Press PLAY ** Press STOP twice on remote ** Enter 26604 on remote ** Press ENTER ** Take out Audio CD and Insert a DVD Credit: Myself via a DUAL Tech ---------------- 3. DVD METHOD (Permanent) ** Insert a DVD ** Let it play until you hear sound ** Press STOP twice on remote ** Enter 26604 ** Press ENTER Credit: Adam P. The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
Posted on Oct 01, 2007
SOURCE: XO Vision XOD1740BT in dash dvd player bypass code
I solved it By connecting the pink wire to a constant ground this acts as a bypass so the unit plays anytime.
Posted on Dec 17, 2007
dancandoit
  • 436 Answers
SOURCE: how do i bypass emergency brake wire on my clarion to play movies
connect the wire to a ground/negative point, please note this is a saftey feature.
Posted on Nov 15, 2009
  • 6 Answers
SOURCE: bypass parking brake for dvd player Kenwood kvt 512
Just connect the purple safety wire to the car's ground location or to the other ground wires.
Posted on Nov 17, 2009
How can i watch movies with car in motion
Hi, what you will need is a video bypass module
ALL ECLIPSE VIDEO NAVIGATION UNITS AUTOMATIC PARKING BRAKE BYPASS HACK...
I wouldn't really reccommend it, though, as the inability to watch videos while the car is moving is a safety feature built in your stereo for a reason.
Jul 23, 2014 | Eclipse AVN5435 Car DVD Player
BYPASS THE KENWOOD DDX8017
Im guessing since this is an in dash dvd player your trying to bypass the emergency brake so it will work with the vehicle in drive. If this is the case all you have to do is take the wire that goes to the emergency brake and ground it somewhere.
Mar 04, 2013 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
How do I bypass the emergency brake on my Eclipse AVN 7000
You will have to connect the brake wire which is pink to the the ground wire.
Apr 27, 2010 | Eclipse (AVN7000) Car DVD Player
What does pink/brake wire on dvd hook up to?! Ex: -LF- spkr or red power?! what?! I have a "Farenheit TID 580" car cd/dvd player. I have all the wires hooked up except the pink/brake. Is there a wire on my...
Hi all car dvd players have a emergency brake safety feature. The pink wire is to be spliced into your emergency brake wire, or there is a code you can purchase to bypass this feature.
Thank you for using fixya.com
Feb 09, 2010 | Eclipse (AVN7000) Car DVD Player
Bypassing E-Break
Just connect the emergency brake wire to earth (vehicle body)
Jun 17, 2009 | Jensen VM9410 Car DVD Player
Parking brake bypass
Tie the Parking break sensor to the ground wire, or ground it to a piece of the frame and your done ;)
Feb 11, 2009 | Pioneer AVH-P5000D Car DVD Player
Bypass parking brake wire
Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
May 20, 2008 | Boss DVD-7500 Car DVD Player
Pioneer avic-d3 in dash dvd player
By law you are not suppose to have video playing in the front of a vehicle becasue it is a distraction to the driver
Apr 25, 2008 | Car Audio & Video
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Parking brake hook up
This wire goes to the "Hot" side of the parking break switch... When the Parking Break is put on, a switch is closed, thus putting an "Earth" on this wire.. Ya can often bypass this by connecting to earth. Sometimes this wire can be "Hot" +12v so B4 doing anything with unit "On" check this wire for any Voltage.
Aug 05, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
195 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
