Question about Amana Refrigerators
Hello. I have a 1988 Amana side-by-side freezer refrigerator model number SSD22NW. Moisture is accumulating on inside of the refrigerator door and drips on the floor. This happen shortly after I replaced the gasket of the refrigerator door. Can you help? Thank you. Mike Kutsy.
  • 1,041 Answers
You definitely have an air leak somewhere along the gasket. Check along the gasket for any place that is not sealed properly. It could be that you didn't quite get it in the right place as well. It might be off-centered along the edge of the door.
If you end up having to replace the gasket again with a brand new one, clean the area that the gasket will be applied, with alcohol before application.
Good Luck!
Jim
Posted on Oct 01, 2010
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
We have an Amana side by side. The freezer door
hi. First of all, finding the model number can be a bit of a challenge. here are the places to look:
  • Inside the refrigerator or freezer, on the upper left or right side wall
  • Behind the lower crisper drawer
  • Behind the lower toe kick-plate
  • On the face frame of the refrigerator body
  • Nov 17, 2009 | Refrigerators
    Whirlpool sideby side ref. ED5FHGXKQ02 condensation on walls of freezer causes accumulation of water on freezer floor
    Most times that is a defrost drain blockage behind the rear wall of your freezer back panel. Sometimes the door seals allow some moisture to accumulate if air is drawn in through the seals leaking or the door to the dispenser is stuck open. But when you say it has accumulated in a pool of ice on the bottom of the freezer then the drain is blocked. I'm going to send you to some links and I want you to read through most of what is said and just use the parts the refer to your refrigerators problem, Sea Breeze
    Sep 07, 2009 | Whirlpool ED5FHEXMQ Side by Side...
    Water on top of freezer door and rubber inside is getting moldy fridge temp is 43 and freezer products are fine amana BR22* bottom out freezer/refrigerator
    The seal is broken around the door and this requires total replacement to prevent the moisture, the cold air from escaping, the warm moist air from entering and causing your refrigerator to run more often than needed and running up your power bill. If I had your model number it would help me to help you find a door seal and fix the problem. So if you need my help you will need to locate the make and model number and write me a message here on Fixya that lets me know you have the number and are ready for help. There are 28 different versions of the BR22 so click HERE and then enter the complete model number. Thank you and if I can help you please let me know, If all else fails contact me at appliancepartsse@yahoo.com Thanks, Sea Breeze
    Aug 06, 2009 | Refrigerators
    Side by side Amana freezer/refrigerator thawing.
    The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
    Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
    Door gasket repacemrnt
    call marcone appl parts they will ship it to you give them mod #
    Jul 05, 2009 | Amana Refrigerators
    Amana bc21vc has bottom freezer- freezer works fine fridge is warm already melted the ice build up in back of freezer twice in the last six months, had a repair guy form sears the first time he replaced...
    The heater installed by Sears repair was probably an ANTI-CONDENSATION HEATER. The purpose of this part is to keep moisture from forming water drops (condensation) on the vertical surfaces of the refrigerator. There is usually an ENERGY SAVER switch somewhere inside the refrigerator so you can turn off the heater during dry weather. As for the refrigerator being too warm, try this: Purchase a REFRIGERATOR THERMOMETER from a hardware or appliance store. Place it inside the refrigerator, noting the temperature , then each day place it in a different spot inside the refrigerator, noting the temperature at each location. IDEALLY, THE TEMP SHOULD BE ABOUT 36 TO 38 DEGREES F,IN ANY LOCATION. Try using the temperature and usage controls in the ref to set the temp, and wait a day for the fridge to stabilize before reading the thermometer. IIf the temp cannot stay in adjustment, or is not uniform, call the repair man and show him your notes how the temp varies. This will allow him to pinpoint the problem more accurately.
    Aug 08, 2008 | Amana Refrigerators
    Frost accumulation on ice maker
    Normally the frost is taken away during defrost so if things get worse we need to look at the defrost timer.If freeze temps.begin to rise let me know, Thanks JT
    Oct 24, 2007 | Frigidaire FRS26KF5C Side by Side...
    Refrigerators Logo
    98 people viewed this question
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
