Question about Dishwashers
Fisher & paykel Soft Touch
My dish washer does not appear to be filling up with water.. all the hoses are ok and if you disconnect and turn on the tap water comes out fin e but no filling up in the washer ??
  • 868 Answers
Un plug the dishwasher and plug it back in.This may re set a bad control board.
Posted on May 26, 2008
Smartdrive 601 leaking
If the tap is leaking replace the washer in hose end. It's a common garden hose washer. If you mean there is water in the tub your inlet water valve needs likely needs replaced.
Jan 11, 2013 | Fisher and Paykel Fisher & Paykel Washer
Looking for a water fill sensor for a fisher paykel gw11 The machine starts the cycle just fine, but when starts to fill, the water just trickles out and both water lines are open, whats wrong?
(sorry if this does not fully answer your question!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel smart drive 608 will not fill with water
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
John C
Jul 05, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel soft touch dish washer, motor is running, but no water coming through, no kinks in hose
I have Fisher paykel dish washer hardley use but now says motor problem F2 call for service anything I can do first
Nov 26, 2010 | Fisher and Paykel Dishwashers
Water fills really slow. When you push button to change water temperature the water comes out better for a tick better then back to slow. Is there anything to fix this?
Hi just read your posting.1st turn the taps off and remove the cold water hose from the tap and machine ends.Check the little filters at the ends of the hose for blockages.Also check the machine end where the hose attaches for a blocked filter in the water valve.Now once the filters are clean put the hose on the tap end and the other end of the hose into a bucket.Now turn the tap on and check to see if you have good water pressure.If you do then replace the hose to the machine.Now repeat on the hot hose.If you are still getting low water pressure into the machine and your water pressure is good from the taps then your water valve or valves are faulty.Please reply on how you got on.Looking forward to your reply.
Sep 26, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel washer won't fill - tap keeps turning off
if you mean the inlet valve turns the incoming water of before it fills then you have a fault with one of 2 things. - the water level hose is (blocked) or more so the lower p.c.b board is broken and needs to be replaced as its water level sensor is faulty.
Jul 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
GW712 Fisher & Paykel Washer. Cold water will not fill the machine only a trickle. Taps, water temprature and hose working correctly.
THE INLET VALVE FILTER COULD BE BLOCKED TURN WATER OFF UNDO PIPE AND CHECK IF NOT COULD BE A PROBLEM WITH VALVE ! IS YOUR WATER PRESSURE OK
Jan 11, 2010 | Washing Machines
Wont stop filling
If when you press pause while filling and it keeps filling then you have a faulty valve. If the filling stops then valve is ok.
If you filling keeps going until overfilling the machine which is what i understand is your problem, then most likely that you have a small pinhole in your pressure tube.
Apr 18, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Water is not filling up.
turn off water
disconnect fill hose from tap
examine screen inside hose end for 'muck' blockage
clean screen
reconnect hose
test washer
if no fill
replace water solenoid valve
note: cold water valve fails first, it gets most use,
if only using cold water, you can simply swap the hot and cold hoses at the tap, and swap the hot and cold electrical connectors on the solenoid valves, the hot solenoid is no the cold one and the washer can be used, cold only, for about as long as it has operated thus far..
Oct 14, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Mar 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Dishwashers Logo
176 people viewed this question
Top Dishwashers Experts
