Question about Mitsubishi VS-70707 70" Rear Projection Television
Periodically won't turn on but after sitting off for several hours, it will eventually turn on
    Problem Solver:
  • 10 Answers
First a TV repairman needs to diagnose the problem.There is so many issues with DLP TVS.An aging bulb,a wire short,or a circuit board issue could be causing the overheating in the unit then its cooling down allowing it to turn back on.The most typical issue is an aging lamp or bulb.An easy fix but depending on the unit could be costly call Mitsubishi get the bulb replacement part # for your TV model then go online and find it for a discounted price.
Posted on Oct 01, 2010
Model khm9qwh5 won't start
This particular model has some sort of internal electronics that require a charge before the unit will function. As a result, when allowed to sit in the cabinet for a long period of time it will simply not turn on. Instead, all you will hear is a "click" noise when you try to power it on. When you get the dreaded "click" noise leave plugged in for several hours and try again.
Nov 05, 2012 | KitchenAid Food Mixers
Any idea why it takes a few turns of the key to start my truck? There is 59000 miles on it and the last 2 mornings the truck did not want to turn over. it eventually did, and would start fine in the work...
You have to be specific about the engine turning over
That is done by the starter circuit
Some people call that cranking
Some people also say it won't crank, when they mean
it does crank, but won't start
Not turn over the engine -----
Old & Weak Battery
Dirty Battery Cables
Worn out Starter Solenoid -- you can buy & replace
without getting the entire starter
A bad Starter
Sep 22, 2011 | 2007 Lincoln Navigator Ultimate 4x4
We purchased a mantis 2 cycle garden tiller new and have only used it 3 times. it has only been used maybe 1 hour total and now it wont start at all. what can we do to get it to start?
Empty mantis fuel tank. Remove and check spark plug. Replace with Champion CJ8Y or NGK BPM7Y if necessary. Gap is .6mm - .7mm or .024" - .028". Prepare fresh fuel/oil mixture. Add fresh fuel to tank along with 2 ounces of 100% acetone (available at walmart) - this will remove deposits inside of mantis from sitting for prolonged periods. Try to start several times. If unsuccessful let mantis sit for a while. Do this several times if necessary. Eventually it will try to start. If it will not remain started then you are successful in completing the previous section. Next you need to watch this video and do what it says. It is actually quite simple.
http://www.alamia.us/mantis_parts_s/148.htm
Feb 04, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Inoperable Whirlpool dryer, Model LER7646EQ2
Good day,
Sorry, no reset you can get to. There is one embedded in the main motor itself, that if the motor draws too much current, and/or gets too hot.
If you shut the machine off for a 24 hour period, then it will many times appear to run normally again, but it's the motor getting weak.
It's usually a slow progressive problem, and if you choose,you can, at least for the short period use the machine by either lightening the loads, or spread the loads over a longer period of time.
Eventually the motor will need to be replaced.
Feb 21, 2010 | Whirlpool Dryers
Audi A6 Starting problem
Try starting without touching gas pedal
Oct 04, 2009 | 2000 Audi A6
Failure of the battery to charge while in the home cradle
Wall transformer is bad or was replaced with lower amp unit. Same thing can happen with aftermarket car charger. Possible solution without replacing transformer: turn off LCD backlighting....
Sep 03, 2009 | Tao XM2go Satellite Radio Receiver
Toshiba tz43v61 turns on then powers off
If it's failing to stay on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself but it will likely develop the same problem eventually unless they have altered the design.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Dec 20, 2008 | Toshiba TZ43V61 43" Rear Projection...
Have sound, lose picture. D52W23
sounds like a solder issue. try resoldering the Ics that are attached to heat sinks on the Board that has the flyback also resolder the flyback pin connections
Jun 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV will not turn on.
Bite the bullet, because it's time for Santa tech to work on this and find the reason for the power supply problem..accordianman
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
Mitsubishi VS-70707 70" Rear Projection Television Logo
130 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
