Question about Maytag Washing Machines
Machine fills but wont agitate. It makes absolutely no noise as the control knob advances. Then it will drain and spin. It will fill for the rinse cycle and then do nothing but the control knob will continue to move until the the cycle is over and you are left with a washer full of water.
  • dwcbuildit4u Oct 01, 2010
    The model # is LAT8804AAL.
  • 121 Answers
Without a model number all I can say is it is most likely the lid switch. Lid switches commonly fail on maytag washers. http://www.appliance-repair-it.com/clothes-washer-repair.html#Maytag
Posted on Oct 01, 2010
  • shawnryan111 Oct 01, 2010
    Yes, this is one of the ones that have the lid swich problems.
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
  • 20 Answers
SOURCE: machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Posted on Jan 19, 2009
  • 686 Answers
SOURCE: Washer fills, agitates in wash cycle, then stops.
you need a new timer
Posted on Apr 06, 2009
  • 89 Answers
SOURCE: 800 series Kenmore stops full of water, will not
you need to replace the timer
Posted on Jul 10, 2009
  • 57 Answers
SOURCE: The agitator will not spin
The problem will be in the pressure starter kindly check whether water stops after certain level and ready for washing,if it is OK means kindly check the wire connections from the operational panel to the motor, in most of the case the timer will not send signal to the motor for that kindly change the operational panel and check it
Posted on May 18, 2010
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Frigidaire washing machine gets stuck on cycles
Apr 01, 2009 | Frigidaire Washing Machines
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Machine fills and agitates, but won't drain
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Washer won't advance from cycle to cycle
    * It's the timer, if your washing machine fills with water and begins agitating, but the timer never
    the timer.
    * It may be a cold-water supply problem, if the washing machine fills with water, agitates,
    Nov 16, 2008 | Danby DDW1805W Designer Series...
    I have a whirlpool model LSR 8233JQ0 washing machine. The tub will fill and agitate but will not empty out or spin. I replace the lid switch without success. The machine makes a sort of ticking sound...
    you say it wont drain the water??? if it fills, agitates , and doesnt advance past the first rinse cycle, it does sound like a lid switch issue, can you hear the switch "clicking" when the door is just about closed??? if not then its not recognizing the door and wont advance for safety reasons.and when you replaced the switch were you sure to remember ot replug the harness before reassmbleing the unit
    Mar 25, 2008 | Washing Machines
    98702 Washer Drain/Spin Dead.
    My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
    Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
    Washing Machines Logo
    211 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
