Question about Zanussi Washing Machines
What are the dimensions of the zanussi fl 828 washing machine?
  • 1294 Answers
SOURCE: WONT SPIN
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on May 10, 2008
  • 135 Answers
SOURCE: zanussi nexus FL 1081
Sounds like your water pipes are on the wrong way round so its rinsing in hot water.
Posted on Nov 07, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
lenwest
  • 150 Answers
SOURCE: softener still in dispenser after wash cycle
Sounds like you have a clogged tube.Try cleaning out the dispenser,pour hot water into it then run threw a cycle empty setting on hot this may clear it out.
Hope this helped.Please rate me
For more help go to live chat.
lenwest
Posted on Jan 30, 2009
SOURCE: Zanussi Washing Machine Troubleshooting, Problems BY EORR E40
E40 is code for the door being open. Try closing/slamming the door hard a few times
Posted on Mar 14, 2010
How do i take the timer off a zanussi fl 828 its the old clock work type been a fantastic machine its just the resistor on the top has blown
Most of these timer based on mechanical action is now being out of production. so only if you are able to get to salvage one from a repair store will this be recommendable as buying a new one for a higher price when the machine is old. The stepper motor or the supply to it can be checked and if this is working you can replace the resistor which seems to be blown.
Jan 20, 2013 | Washing Machines
How do i cahange a zanussi fl 1282 drain hose
tilt the machine back as far as possible to access underneath, then locate the drain pump an unclip the drain hose. Remember to have a basin or towels as water will come out.
Mar 02, 2011 | Zanussi Washing Machines
Replacing heating element in washing machine Zanussi FL 824 C How to dismantle the machine
check side of machine,if it has a line going down side then u split the cab in 2 remove back piece and all will be revealed
Dec 21, 2009 | Washing Machines
I don't have a problem. The machine was given to me and I don't have instrucciones. Were can I find inst. of how to use it. Thanks, Dina Washing machine Zanussi FL. 622 C
CLICK HERE
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 04, 2009 | Washing Machines
Drum won't turn, new belt fitted
Hi this is abhishek and welcome to fixya
see whther any coins or pins anything small stucked below tub ,,this will cause drum not turning ,if its not also timer may be the problem.....better to fix it
thank u....
May 03, 2009 | Washing Machines
Softener still in dispenser after wash cycle
lenwest
Jan 30, 2009 | Zanussi FJS1225W Front Load Washer
Zanussi nexus FL 1081
Nov 07, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
