Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
My Phillips 55in rear projection is HD compatible but the hdmi cable I bought ti hook my ps3 up won't fit in the back of the tv. Is there an adaptor that I can buy, if so where would I find one? The plug on the tv is bigger and looks like it has two rows of pins that plug in also two screw holes to hold it in place. Thanks, Lee
  • lee_bell40 Oct 01, 2010
    I did call radio shack though and they said my tv was not HD and that the VGA input had nothing to do with HD...... So I called best buy (Geek squad) and he said it was HD but only 720p and has the cord I need..... So don't call the radio shack in Turlock ca they will tell you stuff and have no clue what they are talking about!!!!!
    Problem Solver:
  • 10 Answers
That is not an hdmi cable input that is a vga type connector with the 2 rows of pins.Get the manual out then call "Radio Shack" to get the right connector.
Posted on Oct 01, 2010
Testimonial: "I'm a dummy , thanks"
Can't get picture after hooking ps3 up to jbc hd-56g647 by HDMI cord
If it works on another TV, make sure the correct HDMI port is connected.
Jan 09, 2015 | JVC HD-56G647 Compatible TV Lamp
When using PS3 on RCA D52W19 TV, the screen does not fit ( it is zoomed and off-center) in 1080i resolution.
hello!
Have you tried to toggle "format" or "screen size"? On those sets non HD and HD settings could be adjusted separately. Try that, first. If no luck, try similar settings on PS3. I bet, you will be able to match screen format there, as well. To me it looks, like picture formats are mismatched. Also: try to use "component" cables, instead of DVI adapter cable, if nothing works.
good luck,
Alex.
Feb 16, 2012 | RCA D52W19 52" Rear Projection Television
Bought new sony bravio blue ray dvd player hooked to hdmi port changed inout to digital one then tried changing port and trying in digital 2. same symptom on both sound perfect but no picture of any kind....
There are three only three possibility's here, one there is a problem with the HDMI HOOK UP ON THE BACK OF THE TV, SECONDLY IT COULD BE THE DVD PLAYER IS NOT COMPATIBLE WITH THAT TV, AND LASTLY YOU MIGHT NEED TO HAVE THE TV SERVICED FOR SYSTEM ISSUES
Mar 06, 2011 | JVC HD-70G886 70" Rear Projection HDTV
Hook up ps3 and appletv to my tv - i have a Sony receiver w/HDMI slots that i am using for the PS3 - i have hooked up the Appletv to the HDMI input 2 on the back of the TV. The PS3 will not show video - i...
There are generally three HDMI slots at the back panel of an HD TV. Make sure you have connected the PS3 and the Apple TV in two separate slots. Sound will work because you must have hooked it up in Audio IN at the back or if you have connected the red and white audio cables in the front panel , the audio will work only on the camera setting on your TV
Feb 06, 2011 | Hitachi 50VS810 50" Rear Projection HDTV
HDMI broken on JVC HD-56G786 TV
have you ever went thru your hdmi setup procedure that jvc recommends?
Sep 07, 2009 | JVC HD-56G786 56" Rear Projection HDTV
PS3 not working on reg tv's after HDMI use on LCD HD tv
Shelley,  the fix for this is simple! Hold down the power button for about 5 seconds and the system will beep. This resets the video setting for your ps3 from HD too whatever the current cables are that you are using too hook up too the tv. This works on my PS3 which I just bought about 3 months ago and should work with the older ones.
Jun 05, 2009 | LG 37LC2D Television
HD capability
yes, but you have to use digital cables to hook it up to the source in order for you to get HD.
For video, the best is HDMI or DVI input. The second best is S-video.
For audio, you need to use either digital or optical connections.
Analogue video and audio connections will not provide HD.
Sep 12, 2008 | Toshiba 43H71 43" Rear Projection...
I have a phillips 26pf5520d/10 model number, ive connected a dvi cable and hdmi cable to my playstation 3 and tv, but i have no sound, please any ideas. many thanks steph
I'm assuming you mean you have HDMI coming out of the PS3 and going in to the DVI port on the back of the TV, via an adaptor or cable with a different connector on either end.
I have the same TV, you need a separate audio connection between ps3 and tv. HDMI can transmit audio and video but DVI (which is what the TV has) can only do video.
You'll need a 2 x phono female to 3.5mm jack male adaptor cable. like this one to make the audio connection.
you could also try this adaptor but its a bit big and therefore may not fit into the space available.
after getting an adaptor do this (keep your original setup the same)
1. Put the ps3 AV cable into the back of the ps3. 2. then connect the red and white plugs (ignore the yellow) from the ps3 AV into the adaptor (discussed above). 3. then connect the 3.5mm jack (from the adaptor) into the small audio port right next to the DVI port on the back of the TV (I believe its called 'DVI Audio')
I've not tried this and I don't have a ps3, yet, but in theory it should work, as long as the ps3 will send audio to the av output at the same time as to the hdmi output.
if it works, then post a response, i'd like to know for the future.
good luck
Aug 01, 2008 | Televison & Video
WD-52725, Denon 1508 and a PS3
use the component cables that will be your best bet.
Apr 29, 2008 | Mitsubishi WD-52725 52". Rear Projection...
How do I get HD broadcasts on a Phillips 60PP9352 TV that's 'HD ready'?
Hi.
Im guessing your in the UK.
Asking about HD as you havent stated what country you are in.
Ok You will need the following to be able to watch HD pictures on your tv set.
Either Sky HD which involves having a dish fitted. Or Virgin cable system which is not available all over the country.
If you go to either of these systems you will need to pay a subscription to view the HD channels.
http://dysonmanuals.llc.nu/
Chris..
Jan 01, 2008 | Televison & Video
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
129 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
