Question about Canon L400 Fax
My fax is crushing my papers!!! Whay???? - Canon L400 Fax
    Problem Solver:
  • 10 Answers
If it is creasing and pressing the page, the fixing assembly, the heater unit and it surrounding parts need to be replaced.
Also check carefully from all areas to see if a piece of paper of any size is stuck in the paper path ( it should be visible if you open the correct doors and or covers. Often, if it is this problem that I describe, I saw it on the job today, a replacement fixing assy and its lower roller and plastic housing (all as 1 unit) fixed the problem as it has done on nearly every occasion. The fixing film and lower pressure roller do not have even pressure across the lower rollers surface. This is due to wear and tear and heat hardening some types of rollers occasionally, as well as heat slightly warping the fixing assy frame and causing the pressure or feed problem that way.
Hope this helps, oh yeah call for a technician as part are 99% likely to be required. Use canon tecnicians if possible, the parts will be genuine canon parts.
Posted on May 27, 2008
Paper jam in cannon lbp3300 printer
Unplug printer and check paper entry feed ,especially the right side,will probably be dirt or a piece of paper stuck in feed roller, use an air duster (aerosol) to blow out dust etc.
Jan 14, 2018 | Office Equipment & Supplies
DP80F FAX WILL NOT FEED ONE PAGE AT A TIME. IT WILL TAKE 1 PAGE , 5 PAGES , 2 PAGES . HOW DO I FIX THIS MACHINE TO FEED ONE PAGE AT A TIME
Potential solution: When putting in several sheets of paper, grab the sheets by one end, and fan the papers (spread them) at the other end. Reverse your grip and do the same thing to the other end.
Reason: paper is cut by a shear. If the blade of the shear is not perfectly sharp, it crushes fibers into the edges of the adjoining sheets. This causes the sheets to misfeed in the random way you describe. Ruffling the paper before putting it into the printer separates the pages so they will feed properly.
Nov 07, 2011 | Toshiba DP80F Printer
Sharp UX-340LM No dial tone ........Powers on ....Receiver has a slight buzz although mic and ear on receiver sound well... help
It's either a frayed phone cord, a poor phone jack, or the main circuit board. Try a different phone jack. Look at the phone cord to see if it's been crushed under something. This machine is 10 years old and isn't worth replacing the circuitboard. Faxes are quickly going the way of the dinosaur.
Dec 07, 2010 | Sharp UX 340LM Plain Paper Thermal...
The fax will not pull the paper through
What kind of fax? Is it a roll or plain paper. Pull the paper out and examine the roller that is pulling the paper in. If this roller has white paper dust on it wipe off with some water on a papertowel and try again.
Apr 13, 2010 | HP 1010 Plain Paper Inkjet Fax
Error light is alway on on lexmark e120
Besides refilling the cartridge with toner there is a chip in it that you should change so the printer will know that a new cartridge is installed.
Jun 15, 2009 | Lexmark E120n Laser Printer
Printer printed paper with crushing sounds, but
You need to continually press the paper feed button (next to power) while applying gentle pulling pressure to manually feed the paper all the way through the printer. Hope this helped
May 09, 2009 | HP LaserJet 1300 Printer
Fax will shows a Paper jam but no paper found in machine.
Are the all sensor flappers whole?Or it may be an PCB problem
Jan 26, 2009 | Canon LaserClass 9000L Plain Paper Fax
Which way to laod paper to fax on Brother 560 plain paper fax
Does not matter.
If you mean when sending, make a copy, then you'll be sure.
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Paper feed
Is your paper right in slot with grey flap over top of paper feeding into slot.
Apr 08, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
My Laser Panasonic Fax won't pick up papers when sending faxes
There is a sensor in paper tray .u will see just its lever at the other end of lever there is a sensor .i think it is dirty .just clean it properly.now when u will put paper u will listen beep.now sensor is working .fails to pick up mean that fax try to pick paper but not pick the paper .there is a ruler justclean it with cloth and some licquid.and properly check this ruler is movi ng or not moving.
Nov 16, 2007 | Panasonic KX-FL521 Plain Paper Laser Fax
Canon L400 Fax Logo
48 people viewed this question
old marine
old marine
