Question about Whirlpool AD50USL Dehumidifier
House is a rental unit and water level bar has gone missing so unit won't run. Where can I find replacement? '
    Sergeant:
  • 168 Answers
Try looking in the next link: Whirlpool-Dehumidifier-Parts
I hope helps (remember to rate this asnwer).
Posted on Oct 01, 2010
My HB 40 is not collecting water as aggressively as when it was new. Now several days running only collects 1/2 inch. Is the unit done?
Dehumidifiers don't really have a lot of moving parts. Basically it cools the metal coils and a fan blows air across it.
They can usually be set to a specific range of humidity levels and the fan speeds can usually be adjusted.
If you are wondering if yours if working you need to look at the coils while its running they should be COLD and you should see water condensing on them.
The colder the coils get the better the unit works. If you suspect they are very cold then your unit may not be working very well.
It cost just as much to run a unit that isn't working as it does one that is working.
Do you have a gauge to measure humidity in the house? You really do need to see what the humidity level is before you get a new unit.
The amount of water from a dehumidifier has a much to do with the humidity level in your home as it does the operation of the unit.
The dryer the air is already..... the less water there is to take out when it passes over the coils
Oct 16, 2013 | Dehumidifiers
Basement smells musty, fan won't stay on continuous
Barbara, are you running the unit in a continuous mode (i.e Using a hose to drain the unit)? Or is the water draining into the water collection bucket?
If you are not using a hose for continual drainage, the fan will not run constantly. It requires that, for continual operation.
Also, you may have the humidity extraction level set to high. Lower it to 35%. Also, remove and check the air intake filter, as it may need cleaning.
Dehumidifiers that are not Low Temp models have a difficult time operating in basement applications. Because the air temp at floor level is colder than at shoulder level. At temperatures between 40 & 60 degree F, regular dehumidifiers struggle to keep up. Raising it up off the flow on to a sturdy table, counter top, etc that can handle the weight of the unit, plus a full bucket of water can really help.
I hope this was of assistance and thanks for choosing FixYa.
Jul 29, 2011 | LG LHD459EL Dehumidifier
I have a Fedders dehumidifer model # A70145D2A-A-R. It is a few years old and it's worked pretty great but now it just runs continuously and no moisture is gathered. What can I do to fix it? I was...
You'd be hard pressed to find a Fedders like yours. They've been out of business for several years.
There are several basic things that can cause what you described.
1. The humidity extraction level is improperly set. Lower the level to 32-35%
2. A dirty of clogged air intake filter. Turn the unit OFF unplug it and remove the filter for cleaning.
3. Obstructed air space. A dehumidifier requires a minimum of 12" clear air space around the entire
unit.
4. The ambient air temperature at floor level is between 40 & 60 Degrees F. Dehumidifiers do not work well in that temperature (Except low temp models). This especially true in a basement application, because the air temperature at floor level is colder than say, chest level. Raising the unit up off the floor onto a sturdy table, cabinet top, etc, that can handle the weight of the unit, plus a full tank of water, will normally resolve that problem.
5. The cooling coils are dirty and need to be cleaned.
Critical problems:
1 The humidity sensor has failed an needs to be replaced.
2.The compressor is low on refrigerant gas and needs to be recharged.
Sometimes the repairs (Time spent finding, the Parts & labor), if necessary, can cost almost as much or as much as a new unit, which would have a full warranty.
Hope this helped you troubleshoot the basic and solvable problems and you won't need to make any critical repairs. Please let me know. Thanks.
Jun 16, 2011 | Fedders R6DH45X Dehumidifier
Whirlpool dehumidifier ad35dssi runs, but doesn't collect any water, even in a wet area. Have cleaned filters, no luck.
Glad to hear that you thought to clean the filter, as that would have been one of my suggestions. Because, it's the most overlooked.
But, there is another one that equally overlooked and is probably the number cause of your humidifiers problem. The humidity extraction level is set to HIGH. Lower it to 32 - 35%. If your unit does not have an LED Screen readout, set the control on MINIMAL.
This is what gets confusing about the use of dehumidifiers. They work backwards from what most people think. The lower the setting, the more moisture/humidity is extracted from the house. The higher the setting/numbers, the more humidity remains in the house. The higher setting would be used only in the Winter, because removing all the moisture and humidity will make the house uncomfortable.
If this wet area, you mentioned is a basement. The ambient air temperature at floor level is colder than at chest level and dehumidifiers don't work well in temperatures between 40 & 60 degrees F.
If this is the case, placing the unit up off the floor on a sturdy table, counter, etc that can hold the weight of the unit, plus a full bucket of water will generally solve the problem.
Also, be sure that you're maintaining at least 12" of clear air space on all sides of the unit. If the air flow is obstructed, the unit will run all day and not extract any water.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 13, 2011 | Whirlpool AD35USS Dehumidifier
I purchased this unit brand new. It has never produced any water. It runs and after a few minutes it indicates that the bucket is full although it is bone dry. Did I miss something when setting it up...
Well, David, you may have. If the water collection bucket is not installed properly, it won't trigger the safety switch. Remove the buck and make sure that it is reinstalled squarely (top to bottom). Leave the unit ON when you do this. If it's reinstalled properly and the humidity extraction level is set low enough, (32 - 40%) the unit should turn ON automatically, within a few seconds. After you remove the bucket to reinstall it, look up in the cavity and you will see the safety trigger switch. This what you want the bucket to activate. Also, if your model as a float valve near the top of the bucket, make sure it's not locked in the up position.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 08, 2011 | Frigidaire FDF70S Dehumidifier
Lites up but does not run
First check the water collection bucket, to make sure it's properly seated and making contact with the safety switch. Also check the humidity level you have the unit set on. It may be to high for the humidity level in your house. Reset the humidity level to either minimum or if you have an LED screen 45%. Remember, the lower the setting, the more humidity will be removed.
To do an in home test of the unit, move it to a bathroom. Turn the unit ON and set the humidity level to it's lowest level. Turn the shower ON hot enough to generate steam. Do not turn the bathroom's exhaust fan on. As you exit the bathroom, close the door. Wait 15 to 20 minutes and turn the shower OFF. Allow the dehumidifier to run for several more minutes, before checking the water collection bucket for water. If you find any water in the bucket, it's working as it should. If not, it's time to replace the unit. Under most circumstances, I would suggest possibly repairing it. But, Fedders is out of business and replacement/repair parts are a scarce as hen's teeth.
Hope this helps you to further troubleshoot and solve the problem. Please let me know. Thanks.
May 24, 2011 | Fedders A7DH65B2A Dehumidifier
Dear Sir , the dehumidifier is running the motor is running, but not sending out any water. I have cleaned the filter.n Any recommendations?
Is it only the fan motor running that you hear? Or is it the compressor motor and the fan motor in combination?
If it's just the fan motor, it running to circulate the air, in an effort to sense humidity in the air, above the level you have the humidifier set on. Speaking of which, you may have the level set higher than what the humidity is in the house and the unit is just maintaining it. 50 to 60% is high, as opposed to 35%, which is what most folks want to maintain in the hot, humid, summer months.
If you want to test the unit, place in the bathroom, turn a hot shower ON, turn the humidifier ON and set it for 45% or minimum if your unit does not have a LED readout screen. Do Not turn the bathroom exhaust fan ON. As you leave the bathroom, close the door and don't return for 20 minutes. When you do, turn the shower OFF and check the humidifiers water collection bucket. If you see any water, the unit is working as it should. If you don't see any water, it's time to replace that unit. I say that because, at best, the parts and labor to repair the unit would be equal to or almost equal to, the price of a new dehumidifier.
May 20, 2011 | Fedders A7DH45B2A Dehumidifier
Our dehumidifier turns on for only a few seconds, then shuts off.
Wendy, it's probably because the humidity level on the unit is set higher than the humidity level in the house. Keep in mind, the humidity level you set the control to, is not the amount extracted from the air. It's the level you want it to maintain. The higher the percentage level, the more humidity stays in the house. The lower the percentage level, the more humidity it removes, until the lower humidity level is reached. Then the humidifier will automatically shut OFF and/or the unit shuts OFF, because the bucket is full. Once it's emptied and replaced, if the unit needs to continue to extract humidity, it will start running again.
Hope this helped you solve the problem. Please let me know. Thanks.
May 04, 2011 | Maytag M7DH45B2A Dehumidifier
Of our three 54501 Kenmore dehumidifiers, none produced water after two - three weeks. They run but no humidity is drawn out of the air.
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. For instance, if you have the dehumidifier set on 65 to 70%, that's a high level of humidity to maintain in a house. If you have it set for 35 or 45%, that's a low level of humidity to maintain in a house. Which, generally is what you want to maintain in the hot, humid summer months. I find it uncanny, that all 3 units are not collecting any water. So, it may simply be the case, that the humidity level on each unit is improperly set.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filters on a regular basis, not is the time to do so. And while your at it, clean the cooling coils too.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 30 to 40 minutes and check the water collection bucket. If there's water in it, it's working as it should.
Hope this helped you to solve the problem. Please let me know.
May 03, 2011 | Kenmore 54501 Dehumidifier
Plug it in turn it on and nothing in the bucket after several hours
Hi, Mindy! The following is an overall review of what causes the problem you listed.
If the room air is less than the set air, then there is no water in the bucket, because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water. In addition, if you set the humidity level you want to maintain higher the actual humidity level in the house or room, it won't pickup and collect any moisture. The fans on most of the dehumidifiers on the market today run almost constantly. They do this, so that the room air is always moving and if humidity is detected, it will extract it.
Hope this helps you understand how dehumidifiers function and what you can expect from them under given circumstances,. In fact, there may not be anything mechanically wrong with yours. But, to make sure, do what is suggested above to test the unit.
Apr 29, 2011 | Haier Dehumidifiers
Whirlpool AD50USL Dehumidifier Logo
43 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Terry Schneider
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
