Question about Panasonic Lumix DMC-FS5 Digital Camera
When switched on the camera tries to open the lens. It is clearly being obstructed in some way, and after three attempts closes down with the message "Please turn camera off and on again". If tapped gently sometimes the lens will open, and if the lens is caught and encouraged to stay out then ooccasionally the camera opens as normal. If the lens does stay open the camera appears to function as normal.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 01, 2010
Fuji finepix
When a camera notice the lens does not move, it is afraid to damage gears or the motor, of it powers down everything involved the lens. It then gives a message as you read.
Because the camera can't know what is casing this, it only can warn.
It "hopes" if it did run the lens to an obstruction, powering it down will relieve the tension. That is way it says power down.
Remove the battery, check the lens barrel if any obstruction is limiting the free movement of the lens. and then replace the battery. switch it on again.
If you accidentally touched the lens, while it was coming out, it could have given the same error. When after switching on the camera, and you are sure you don't obstruct the free movement of the lens barrel, but it comes back with the same error, you should contact a certified repair centre for your camera.
Jul 20, 2014 | Fujifilm Finepix S2980
Camera keeps opening and closing, orange light comes on
Wow, Not even the manual knows this error. Must be serious. It can mean two things in my mind. The lens is obstructed some how. Inside or outside. Or the battery is not ok. If you can't see anything on the lens barrel outside, please try to charge the battery. The camera will shut down without warning, when the power is low. Be aware the camera won't work as you expect, when a USB cable is attached. Actually you are not allowed to connect the charger, when the camera is still switched on. Look how the charger reacts. See if the battery is charged as before, because if the signal battery full does not appear it could be you have to buy a new battery.
Success.
Jan 13, 2014 | Olympus Stylus 700 / 700 Digital Camera
After inserting lens it keeps saying lens not attached
I would help to know the error message, but here is what I can tell you.
Having a "Lens error " message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
  1. One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
  2. Remove and recharge and/or replace the battery. If the error does not clear up right away, leave the battery out of the camera overnight, and try again the next day.
Oct 31, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
When turning on there are several buzzes and the lens goes in and out then closes and screen reads "lens error!" in red
There is dirt or an obstruction in the lens telescoping mechanism or the lens cover that is preventing it from working properly.
Try clearing it with compressed air.
Otherwise, you need a professional to repair the camera. You can find a service center on the manufacturer's website.
If this helps, please vote for my solution.
Oct 12, 2009 | Nikon Coolpix S210 Digital Camera
Lens stays open, "turn..off and on again" message. print/play mode closes lens but problem & message return in picture modes. Holding "W" had no effect either
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Apr 28, 2009 | Panasonic Lumix DMC-FX10 Digital Camera
My lens is jammed and will not open all the way on my samsung L830 8.1 camera
Have you tried removing the batteries and starting again? Is the lens obstructed?
HAve you used the wide-telephoto switch to try to move the lens in and out? Is there an error message on the LCD?
Nov 19, 2008 | Cameras
Camera closes after power on
"E18" Error seems to be a code related to and barrel extension problems. I have broken down these problems into three categories which explain the variety of causes (or lack thereof) and solutions that people have reported. The solutions are referred to in the numbered paragraphs below, and then described in detail afterward. The three categories are:
  1. Batteries that run out of juice mid-extension. Problems such as these appear to be reset-able through either powering off and on or the A/V cable connection method.
  2. Physical obstructions preventing the full extension/retraction of the lens. These can include things like dust or sand in the mechanism. As the case (and lens barrel) are by no means impervious to the introduction of foreign matter, even if you are very careful with your camera, contamination is possible. Depending on the size of the obstruction, and how sticky it is, it may be dislodged by blowing air on it or tapping on the camera.
  3. Mis-alignment of the lens can also cause the E18. The cause of the alignment problem can be either blunt force (dropping) or substantial grime in the mechanism. These types of problems can sometimes be fixed by pushing the mechanism back into alignment, sometimes in combination with a cleaning method.
NOTE: Items 2-3 above may involve large and/or sticky grime that is difficult to impossible to remove from the outside of the camera (by blowing or tapping), and may require that the camera be opened.
Jan 23, 2008 | Canon PowerShot A75 Digital Camera
Lens error Help please
The Lens Error usually means the lens has sand or another obstruction stopping it from retracting.
Nov 07, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
"Cover Is Not Open" And The "Lens Cover" Is Open...
the lens cover switch of your camera have a poor contact that why that message is appearing...you have no choice but to disassemble the camera for repairing or cleaning that switch....i suggest you have to go the service center now and don't try open your camera if you are not a technician cause you may damage the flexwire of the lcd monitor if you not properly remove the cover...
Aug 30, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Zoom lens jammed
this is a protection mechanism against further damage when the zoom/lens mechanism is obstructed. It's a very delicate mechanism, and it's not easy or cheap to fix. The gears probably got misaligned or broken when you dropped the camera. You should get a repair estimate, and only if you decide you'd rather trash it try opening it up again. Good luck
Jun 22, 2006 | Samsung Digimax 420 Digital Camera
Panasonic Lumix DMC-FS5 Digital Camera Logo
89 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
