Question about Standard Registar SD650 Color Copier
I am getting spots on my copies in the same place on each copy. why
Change your Drum
Posted on Sep 06, 2012
3 Suggested Answers
angelus316
  • 41 Answers
SOURCE: DARK SPOTS
Are the dark spots random and moves location with every copy or are they at exacly the same place on every copy? Random you will need to remove the drum/toner and use a blower to clean the inside of the machine,failing that replace the drum unit.If the spots don't move clean the top glass.Let me know
Posted on May 22, 2009
canontech
  • 1219 Answers
SOURCE: We are getting spots of toner on our copies.
Vacume the interior of copier, check the drum.If there is spots on drum, change the drum.
Also check the fixing section.
Posted on Jun 14, 2010
I'm a newbie and want to learn how to copy something from one page to another.
Highlight what you want -then right click on copy
Go to new page and place cursor at intended spot , right click and hit paste.
Aug 12, 2015 | Computers & Internet
May 25, 2010 | Canon PC-940 Black and White Copier
Black spots in the dram ricoh 450
Are the black spots on all copies. if they are only on teh copies done from teh glass scan then it could be dirt on the g;*** plate. if from all copies it is the dev or drum area.. are the dots moving across the page in the same place if you do lots of copies this means it is the drum that is damaged.. if they are blotchy marks it could be toner build up.. if the marks are in a line across the page open up the side door adn look at the hot roller in the fuser the coating could be damaged and the roller need replacing..GOOD luck A
Sep 29, 2009 | Ricoh Aficio 450 Copier
Paper when out put then see spot in middle page portate
I don't know the model of Canon Copier you have, and I don't know if your problem happens when you copy and print, or only when you copy, so it's hard to tell with the little information you've provided.
Let's assume the easiest solution is the correct one...
Is the "Spot" in the same location on every copy? Then clean glass.
does the spot move left to right across the page with each successive copy? Then replace the drum unit.
Sep 10, 2009 | Canon Office Equipment & Supplies
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
DARK SPOTS
May 21, 2009 | Sharp AL-1641CS Laser Digital Copier
Spots on master
THE DRUM THAT MAKE THE COPIES IS DURTY OR HAS DRYED INK ON IT AND IT TAKES A SPECAL CLEANER, I CAN NOT EVEN SAY THE WORD OR EVEN SPELL IT FOR YOU
TRI ETHI LINE, CALL A COPY MACHINE COMPANY OF GO ON LINE TYPE IN MANIFACTURE NAME ONLY RETURN ,
THE CORRONA WIRES THAT MAKE THE ELECTRO STATIC IMAGING MAY ALSO NEED TO BE CLEANS, Q-TIP AND ALCOLHAL WITH A VERY SOFT HAND OR YOU WILL BRAKE THE WIRE AND THAN YOU WILL BE WITHOUT A COPIER
CANDYMANGANDY
Jan 29, 2009 | Riso RZ310 Duplicator
White spots with a black dot in the centre
pls check the ibt belt. its geting any hole are bunch its come like this, or u will check and clean ibt assemply transfer rolleres. and 2nd btr also.
Jul 23, 2008 | Xerox DocuColor 12 Color Copier
Dark Copies
Jim, A couple of things: 1. OEM (Canon original) toner cartridge or remanufactured/compatible? The first place to start is always with the toner cartridge when image problems occur. Pull the cartridge out and draw back the drum cover. Check to see if the drum is a nice "clean" blue color or if the lines and spots are on it like you described. (These two areas should be handled by someone with experience in copy service) 2. The next thing would involved cleaning under the copy glass. Build up from dust, etc causes a "fogginess" that makes the machine try to adjust the intensity of the exposure lamp to conpensate for this. 3. Also could be a bad upper fuser roller if you started having any paper jams when to paper exits.
Jul 18, 2007 | Canon imageCLASS D320 Digital Copier
Black Spots all over my copies
There are lots of things that can cause this. Inspect the fuser assembly & verify that there isn't any teflon missing from the upper roller & that the lower roller is clean. The spots can also be caused by a build up of waste toner in the cleaning assembly, causing excess toner to be dropped on the copies as they pass under it. The cleaning assembly would need to be removed & cleaned to correct this. The spots are not always in the same place - but are they the same pattern? A worn drum assembly can cause spots that are usually a repeating pattern but located in different parts of multiple copies. Dirty corona wires can also cause random spots & rewiring the coronas would solve that.
Jun 11, 2007 | Toshiba DP2570 Printer
Standard Registar SD650 Color Copier Logo
67 people viewed this question
Top Standard Registar Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Standard Registar Office Equipment and Supply Expert? Answer questions, earn points and help others
